同一交换机两个网段能互ping通,但访问不了web服务。
2018-08-20提问
  • 1收藏,1586浏览
宋璟 零段
同一交换机有两个网段 192.168.14.0/24 vlan 14  和192.168.20.0/24 vlan 20 两个网段可以ping通,vlan14网段一台电脑主机开了web服务端口号8008,同网段可以访问,但是vlan 20内的主机访问不了vlan14内的这台web服务器,请问是交换机默认所有基于端口的互访关掉了吗?要如何设置才能让两个网段基于端口的服务可以互通
version 5.20, Release 1513P15
 # sysname H3C
 # irf mac-address persistent timer irf auto-update enable undo irf link-delay
 # domain default enable system
 # vlan 1
# vlan 14
 # vlan 20 to 22
# vlan 30
# vlan 60
 # domain system access-limit disable state active idle-cut disable self-service-url disable
 # dhcp server ip-pool vlan14 network 192.168.14.0 mask 255.255.255.0 gateway-list 192.168.14.1 dns-list 192.168.1.2 202.96.128.86 120.196.165.24 8.8.8.8 expired day 0 hour 8
 # dhcp server ip-pool vlan20 network 192.168.20.0 mask 255.255.255.0 gateway-list 192.168.20.1 dns-list 192.168.1.2 202.96.128.86 120.196.165.24 8.8.8.8 expired day 0 hour 8
# dhcp server ip-pool vlan21 network 192.168.21.0 mask 255.255.255.0 gateway-list 192.168.21.1 dns-list 192.168.1.2 202.96.128.86 120.196.165.24 8.8.8.8 expired day 0 hour 8
 # dhcp server ip-pool vlan30 network 192.168.30.0 mask 255.255.255.0 gateway-list 192.168.30.1 dns-list 192.168.1.2 202.96.128.86 120.196.165.24 8.8.8.8 expired day 0 hour 8
 # dhcp server ip-pool vlan60 network 192.168.60.0 mask 255.255.255.0 gateway-list 192.168.60.1 dns-list 192.168.1.2 202.96.128.86 120.196.165.24 8.8.8.8 expired day 0 hour 8
 # interface NULL0 # interface Vlan-interface1 ip address 192.168.1.5 255.255.255.0
 # interface Vlan-interface14 ip address 192.168.14.1 255.255.255.0
 # interface Vlan-interface20 ip address 192.168.20.1 255.255.255.0
# interface Vlan-interface21 ip address 192.168.21.1 255.255.255.0
 # interface Vlan-interface30 ip address 192.168.30.1 255.255.255.0
# interface Vlan-interface60 ip address 192.168.60.1 255.255.255.0
 # interface GigabitEthernet1/0/1
# interface GigabitEthernet1/0/2
# interface GigabitEthernet1/0/3 port access vlan 20
# interface GigabitEthernet1/0/4 port access vlan 20
 # interface GigabitEthernet1/0/5 port access vlan 20
# interface GigabitEthernet1/0/6 port access vlan 20
# interface GigabitEthernet1/0/7 port access vlan 20
 # interface GigabitEthernet1/0/8 port access vlan 20
 # interface GigabitEthernet1/0/9 port access vlan 20
# interface GigabitEthernet1/0/10 port access vlan 20
 # interface GigabitEthernet1/0/11 port access vlan 21
# interface GigabitEthernet1/0/12
# interface GigabitEthernet1/0/13
# interface GigabitEthernet1/0/14
# interface GigabitEthernet1/0/15
# interface GigabitEthernet1/0/16
 # interface GigabitEthernet1/0/17
# interface GigabitEthernet1/0/18
 # interface GigabitEthernet1/0/19 port access vlan 21
# interface GigabitEthernet1/0/20 port access vlan 21
# interface GigabitEthernet1/0/21 port access vlan 21
 # interface GigabitEthernet1/0/22
 # interface GigabitEthernet1/0/23 port access vlan 14
# interface GigabitEthernet1/0/24
# interface GigabitEthernet1/0/25
# interface GigabitEthernet1/0/26
 interface GigabitEthernet1/0/27
# interface GigabitEthernet1/0/28
# ip route-static 0.0.0.0 0.0.0.0 192.168.1.1
 # dhcp server forbidden-ip 192.168.14.1 192.168.14.99 dhcp server forbidden-ip 192.168.20.1 192.168.20.99 dhcp server forbidden-ip 192.168.21.1 192.168.21.99 dhcp server forbidden-ip 192.168.30.1 192.168.30.99 dhcp server forbidden-ip 192.168.60.1 192.168.60.99
 # dhcp enable
 # load tr069-configuration
 # user-interface aux 0 user-interface vty 0 4 authentication-mode scheme user-interface vty 5 15
粉丝:19人 关注:0人
交换机对发过来的报文一般做硬件转发,看配置也没有过滤策略,是不会对基于端口的互访关掉的,这种情况下最好看看 vlan 20内的主机的web服务的端口是不是开启了,之后可以通过抓包确认一下这个http的报文是丢哪了
同一个网段都可以访问,不成在没有开启端口的问题,抓包请问在那里抓呢,使用什么工具
宋璟 发表时间:2018-08-20
在交换机上做端口镜像,然后用wireshark进行抓包,确认这个http的访问报文是不是丢在交换机上了
时光记忆srp 发表时间:2018-08-20
