cad或pdf扫描文件会被网络拦截
2022-05-12提问
  • 1收藏,936浏览
H3C F1050防火墙 配置如下 想咨询一下是哪里配置有问题。内部网络上传没有问题。谢谢
[BEGIN] 2022-05-11 10:15:43
Connecting to 10.10.10.4:23...
Connection established.
To escape to local shell, press 'Ctrl+Alt+]'.
* Copyright (c) 2004-2018 New H3C Technologies Co., Ltd. All rights reserved.*
* Without the owner's prior written consent,                                 *
* no decompiling or reverse-engineering shall be allowed.                    *
login: admin
Password:
login: admin
Password:
<ZZDS-FW>dis cur
 version 7.1.064, Release 9323P19
 sysname ZZDS-FW
 clock timezone Lisbon add 00:00:00
 clock protocol none
context Admin id 1
ip vpn-instance management
 route-distinguisher 1000000000:1
 vpn-target 1000000000:1 import-extcommunity
 vpn-target 1000000000:1 export-extcommunity
 telnet server enable
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 10
 irf member 2 priority 5
 security-zone intra-zone default permit
 security-policy disable
 session synchronization dns http
track 1 nqa entry admin test reaction 1
 dialer-group 1 rule ip permit
 dialer-group 2 rule ip permit
 dialer-group 3 rule ip permit
 dialer-group 4 rule ip permit
 dialer-group 5 rule ip permit
 dialer-group 6 rule ip permit
 dialer-group 7 rule ip permit
 dialer-group 8 rule ip permit
 dialer-group 9 rule ip permit
 ip unreachables enable
 ip ttl-expires enable
 dns proxy enable
 ip host ***.*** 192.168.0.16
 ip host ***.*** 192.168.0.8
 lldp global enable
 lldp compliance cdp
 password-recovery enable
vlan 1
vlan 10
vlan 12
vlan 14
vlan 16
vlan 18 to 19
vlan 140
vlan 200
irf-port 1/1
 port group interface GigabitEthernet1/0/22
 port group interface GigabitEthernet1/0/23
irf-port 2/2
 port group interface GigabitEthernet2/0/22
 port group interface GigabitEthernet2/0/23
object-group ip address 192.168.0.0
 description server-ip-group
 0 network subnet 192.168.0.0 255.255.255.0
object-group ip address 192.168.0.7
 description 192.168.0.7
 0 network host address 192.168.0.7
object-group ip address 192.168.9.111
 description 192.168.9.111
 0 network host address 192.168.9.111
object-group ip address add-server
 70 network host address 192.168.0.5
object-group ip address add_server
 0 network host address 192.168.0.8
 10 network host address 192.168.0.7
 20 network host address 192.168.0.31
 30 network host address 192.168.0.20
 40 network host address 192.168.0.30
 50 network host address 192.168.0.16
 60 network host address 192.168.0.13
 80 network host address 192.168.0.14
 90 network host address 192.168.11.4
 100 network host address 192.168.100.1
 110 network host address 202.202.202.226
 111 network host address 113.106.95.197
 120 network host address 192.168.0.9
 130 network host address 192.168.0.5
 140 network host address 192.168.0.6
 150 network host address 192.168.0.218
 160 network host address 192.168.0.207
 170 network host address 192.168.0.32
 180 network host address 192.168.0.18
 190 network host address 192.168.0.200
 200 network host address 192.168.0.12
 210 network host address 192.168.0.17
 220 network host address 10.10.10.5
 230 network host address 192.168.0.22
 240 network host address 192.168.0.19
 250 network host address 192.168.0.228
 260 network host address 192.168.0.33
object-group ip address "vlan 10"
 description 192.168.0.0
object-group ip address "VLAN 12"
 description VLAN 12 (192.168.2.0θ¶̩
 0 network range 192.168.2.100 192.168.2.240
 0 network exclude 192.168.2.101
 0 network exclude 192.168.2.105
 0 network exclude 192.168.2.200
object-group ip address "vlan 14"
 description zztzkg wifi network
 0 network subnet 192.168.4.0 255.255.255.0
 0 network exclude 192.168.4.0
object-group ip address "vlan 16"
 description zzds wifi network
 0 network host address 192.168.7.37
object-group ip address "Vlan 19"
 description vlan19 £¨192.168.9.0£©
 0 network range 192.168.9.100 192.168.9.131
 10 network range 192.168.9.133 192.168.9.240
object-group ip address vlan18
 description vlan18 £¨192.168.8.0£©
 0 network range 192.168.8.100 192.168.8.240
object-group service service_port
 0 service tcp destination eq 8080
 10 service tcp destination eq 5656
 20 service tcp destination eq 9999
 30 service tcp destination eq 8081
 40 service tcp destination eq 5367
 50 service tcp destination eq 81
 60 service tcp destination eq 8888
 70 service tcp destination eq 3389
 80 service tcp destination eq 443
 90 service tcp destination eq 5555
 100 service tcp destination eq 1222
 110 service tcp destination eq 10010
 111 service tcp destination eq 10011
 112 service tcp destination eq 10012
 113 service tcp destination eq 10013
 114 service tcp destination eq 10014
 120 service tcp destination eq 10004
 130 service tcp destination eq 8889
 140 service tcp destination eq 6888
 150 service tcp destination eq 11034
 160 service tcp destination eq 10086
 170 service tcp destination eq 3307
 180 service tcp destination eq 8089
 190 service tcp destination eq 5757
 200 service tcp destination eq 6802
 210 service tcp destination eq 23
 220 service tcp destination eq 80
 230 service tcp destination eq 4433
 240 service tcp destination eq 4009
 250 service udp destination eq 4009
 260 service tcp destination eq 4430
 270 service tcp destination eq 6666
 280 service tcp destination eq 8443
 281 service tcp destination eq 5280
 282 service tcp destination eq 5222
 283 service tcp destination eq 7777
 284 service tcp destination eq 5269
 285 service tcp destination eq 5369
 286 service tcp destination eq 5469
 287 service tcp destination eq 8010
 288 service tcp destination eq 8050
 289 service tcp destination eq 8060
 290 service tcp destination eq 445
 291 service tcp destination eq 7805
 292 service tcp destination eq 22
 293 service tcp destination eq 3999
 294 service tcp destination eq 5366
 stp global enable
policy-based-route pbr_internet permit node 10
 if-match acl 3010
 apply output-interface Dialer6
policy-based-route pbr_internet permit node 20
 if-match acl 3020
 apply output-interface Dialer8
policy-based-route pbr_internet permit node 50
 if-match acl 3050
 apply output-interface Dialer7
policy-based-route pbr_internet permit node 60
 if-match acl 3060
policy-based-route pbr_internet permit node 80
 if-match acl 3080
 apply output-interface Dialer5
policy-based-route pbr_internet permit node 90
 if-match acl 3090
 apply output-interface Dialer4
policy-based-route pbr_internet permit node 100
 if-match acl 3100
policy-based-route pbr_internet permit node 110
 if-match acl 3110
 apply next-hop 111.111.111.111
policy-based-route pbr_internet permit node 120
 if-match acl 3200
 type icmp-echo
  destination ip 111.111.111.111
  frequency 100
  next-hop ip 111.111.111.111
  reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
 nqa schedule admin test start-time now lifetime forever
interface Bridge-Aggregation1
 port access vlan 200
 link-aggregation mode dynamic
interface Bridge-Aggregation2
 port access vlan 10
interface Dialer0
 mtu 1492
 ppp chap password cipher $c$3$YYjK/TZbs3u7yK65Z8AZlLstflQg+vZios3j
 ppp chap user 075501313047@163.gd
 ppp ipcp dns admit-any
 ppp ipcp dns request
 ppp pap local-user 075501313047@163.gd password cipher $c$3$++rcGFHOoXpjwq/G2pokradymqUJEp21yFTA
 dialer bundle enable
 dialer-group 1
 dialer timer idle 0
 dialer timer autodial 5
 ip address ppp-negotiate
interface Dialer1
 bandwidth 500000
 mtu 1492
 ppp chap password cipher $c$3$SrjBfLeosATN4m6MDatJBGu01kB1Q1Cp+G0e
 ppp chap user 075504184000@163.gd
 ppp pap local-user 075504184000@163.gd password cipher $c$3$wdQEye99p3oY64IQ93Vy4NATrR8bhtDXNhMf
 dialer-group 1
 dialer timer idle 0
 dialer timer autodial 60
 tcp mss 1024
 nat outbound 3000
interface Dialer2
 bandwidth 500000
 mtu 1492
 ppp chap password cipher $c$3$Tx2PTTCzOF3upoiSlt8j1p8WpGWqOAZOXOH8
 ppp chap user 075504116487@163.gd
 ppp pap local-user 075504116487@163.gd password cipher $c$3$gzNw4n7L/J3HExYyWxs5t9Bl2R435vvnn7Uz
 dialer-group 1
 dialer timer idle 0
 tcp mss 1024
 nat outbound 3000
interface Dialer3
 description FOR USE
 bandwidth 500000
 mtu 1492
 ppp chap password cipher $c$3$UtjmGK7eKjZa9x4b1+4083W4oFUhCpP4KYmv
 ppp chap user 075505866480@163.gd
 ppp pap local-user 075505866480@163.gd password cipher $c$3$c8cnQeWAx5y/UsUwr2dYTzkHytT4WQEb+Vks
 dialer-group 1
 dialer timer idle 0
 tcp mss 1024
 nat outbound 3000
interface Dialer4
 description FOR USE
 bandwidth 500000
 mtu 1492
 ppp chap password cipher $c$3$77DMDuNHhazhZ83jGNT1QwIX5xn2+IGwbT28
 ppp chap user 075507557551@163.gd
 ppp pap local-user 075507557551@163.gd password cipher $c$3$MCUyfCIVGbq/Xcxi0Zcq7aK6a8LMunk01sDD
 dialer-group 1
 dialer timer idle 0
 tcp mss 1024
 nat outbound 3000
interface Dialer5
 description FOR USE
 bandwidth 1000000
 mtu 1492
 ppp chap password cipher $c$3$WnOE3aiLe0SHp35cUPI1zHF465nTrgvfJb8R
 ppp chap user 075505424374@163.gd
 ppp pap local-user 075505424374@163.gd password cipher $c$3$z6A4dH74ncGFZoQIXgKo93h+k7Ta9BXLpZnV
 dialer-group 9
 dialer timer idle 0
 tcp mss 1024
 nat outbound 3000
interface Dialer6
 description FOR USE
 bandwidth 500000
 mtu 1492
 ppp chap password cipher $c$3$jahymyz7+wn6Qrn1D/BQpyaMfk6zhubjG7Hj
 ppp pap local-user 075501313047@163.gd password cipher $c$3$FSlrBxgtKxDsvQdyVZ7mA3O9rISDf4ndYt2c
 dialer-group 7
 dialer timer idle 0
 tcp mss 1024
 nat outbound 3000
interface Dialer7
 description FOR USE
 bandwidth 500000
 mtu 1492
 ppp chap password cipher $c$3$Z2bGuLHGv1bXrx6Wyb1M2ONB/U6qmr6Xr2JX
 ppp chap user 075503480872@163.gd
 ppp pap local-user 075503480872@163.gd password cipher $c$3$UL8Fka5LCTc8q21qcmKuV3KeBU9zyGVYhV5g
 dialer-group 1
 dialer timer idle 0
 tcp mss 1024
 nat outbound 3000
interface Dialer8
 description FOR USE
 bandwidth 500000
 mtu 1492
 ppp chap password cipher $c$3$yvuYNnmSN1+SCH46mFuSwi0MM9hbylHcaomo
 ppp chap user 075503082136@163.gd
 ppp pap local-user 075503082136@163.gd password cipher $c$3$zXXFlAg/2jxjrAW7Jg6yK9K4f2G1Dd0zjXxk
 dialer-group 1
 dialer timer idle 0
 tcp mss 1024
 nat outbound 3000
interface Dialer9
 mtu 1492
 dialer-group 8
 dialer timer idle 0
interface NULL0
interface Vlan-interface1
interface Vlan-interface10
 nat hairpin enable
 ip policy-based-route pbr_internet
interface Vlan-interface19
interface Vlan-interface140
 pppoe-client dial-bundle-number 4
interface Vlan-interface200
 ip address 10.10.10.4 255.255.255.0
 nat hairpin enable
interface GigabitEthernet1/0/0
 port link-mode route
 ip binding vpn-instance management
 description dialer 1 075504184000@163.gd
 pppoe-client dial-bundle-number 1
 description dialer 2  075504116487@163.gd
 pppoe-client dial-bundle-number 2
 description dialer3 075505866480@163.gd
 pppoe-client dial-bundle-number 3
interface GigabitEthernet1/0/5
 pppoe-client dial-bundle-number 0
interface GigabitEthernet1/0/6
 description link to 40M special line
 shutdown
 ip address 202.202.202.226 255.255.255.224
 tcp mss 1024
 nat outbound 3000
 nat server protocol tcp global 202.202.202.228 80 inside 192.168.0.8 80
 nat server protocol tcp global 202.202.202.228 81 inside 192.168.0.8 81
 nat server protocol tcp global 202.202.202.228 4430 inside 192.168.0.6 443
 nat server protocol tcp global 202.202.202.228 5222 inside 192.168.0.8 5222
 nat server protocol tcp global 202.202.202.228 5269 inside 192.168.0.8 5269
 nat server protocol tcp global 202.202.202.228 5280 inside 192.168.0.8 5280
 nat server protocol tcp global 202.202.202.228 5367 inside 192.168.0.32 5367
 nat server protocol tcp global 202.202.202.228 5369 inside 192.168.0.8 5369
 nat server protocol tcp global 202.202.202.228 5469 inside 192.168.0.8 5469
 nat server protocol tcp global 202.202.202.228 5656 inside 192.168.0.8 5656
 nat server protocol tcp global 202.202.202.228 7777 inside 192.168.0.8 7777
 nat server protocol tcp global 202.202.202.228 8007 inside 192.168.0.21 8007
 nat server protocol tcp global 202.202.202.228 8060 inside 192.168.0.8 8060
 nat server protocol tcp global 202.202.202.228 8080 inside 192.168.0.8 80
 nat server protocol tcp global 202.202.202.228 8081 inside 192.168.0.32 8081
 nat server protocol tcp global 202.202.202.228 8443 inside 192.168.0.8 8443
 nat server protocol tcp global 202.202.202.228 8888 inside 192.168.0.8 8888
 nat server protocol tcp global 202.202.202.228 9999 inside 192.168.0.8 9999
 nat server protocol tcp global 202.202.202.229 80 inside 192.168.0.13 5757
 nat server protocol tcp global 202.202.202.229 88 inside 192.168.0.33 88
 nat server protocol tcp global 202.202.202.229 3999 inside 192.168.0.7 3999
 nat server protocol tcp global 202.202.202.229 4009 inside 192.168.0.6 4009
 nat server protocol tcp global 202.202.202.229 4430 inside 192.168.0.6 4430
 nat server protocol tcp global 202.202.202.229 5222 inside 192.168.0.218 5222
 nat server protocol tcp global 202.202.202.229 5269 inside 192.168.0.218 5269
 nat server protocol tcp global 202.202.202.229 5280 inside 192.168.0.218 5280
 nat server protocol tcp global 202.202.202.229 5366 inside 192.168.0.20 5366
 nat server protocol tcp global 202.202.202.229 5367 inside 192.168.0.20 5367
 nat server protocol tcp global 202.202.202.229 5369 inside 192.168.0.218 5369
 nat server protocol tcp global 202.202.202.229 5469 inside 192.168.0.218 5469
 nat server protocol tcp global 202.202.202.229 5555 inside 192.168.0.8 5555
 nat server protocol tcp global 202.202.202.229 5656 inside 192.168.0.19 5656
 nat server protocol tcp global 202.202.202.229 6666 inside 192.168.0.31 6666
 nat server protocol tcp global 202.202.202.229 7777 inside 192.168.0.218 7777
 nat server protocol tcp global 202.202.202.229 8050 inside 192.168.0.33 80
 nat server protocol tcp global 202.202.202.229 8060 inside 192.168.0.33 80
 nat server protocol tcp global 202.202.202.229 8080 inside 192.168.0.218 8080
 nat server protocol tcp global 202.202.202.229 8081 inside 192.168.0.20 8081
 nat server protocol tcp global 202.202.202.229 8443 inside 192.168.0.218 8443
 nat server protocol tcp global 202.202.202.229 8889 inside 192.168.0.30 8889
 nat server protocol tcp global 202.202.202.229 9999 inside 192.168.0.218 9999
 nat server protocol tcp global 202.202.202.230 5656 inside 192.168.0.228 5656
 nat server protocol tcp global 202.202.202.230 5757 inside 192.168.0.13 5757
 nat server protocol tcp global 202.202.202.230 6802 inside 192.168.0.5 6802
 nat server protocol tcp global 202.202.202.230 8010 inside 192.168.0.17 8010
 nat server protocol tcp global 202.202.202.230 8050 inside 192.168.0.17 8050
 nat server protocol tcp global 202.202.202.230 8060 inside 192.168.0.17 8060
 nat server protocol tcp global 202.202.202.230 8089 inside 192.168.0.5 8089
 nat server protocol tcp global 202.202.202.230 8888 inside 192.168.0.13 8888
 nat server protocol tcp global 202.202.202.231 80 inside 192.168.0.16 80
 nat server protocol tcp global 202.202.202.231 8010 inside 192.168.0.16 8010
 nat server protocol tcp global 202.202.202.231 8050 inside 192.168.0.16 8050
 nat server protocol tcp global 202.202.202.231 8888 inside 192.168.0.16 8888
 nat server protocol tcp global 202.202.202.232 21 inside 192.168.0.22 21
 nat server protocol tcp global 202.202.202.232 5757 inside 192.168.0.12 80
 nat server protocol tcp global 202.202.202.232 8080 inside 192.168.0.12 80
 nat server protocol udp global 202.202.202.229 4009 inside 192.168.0.6 4009
interface GigabitEthernet1/0/7
 description new 50M special line
 ip address 113.106.95.197 255.255.255.128
 nat outbound 3000
 nat server protocol tcp global 113.106.95.198 80 inside 192.168.0.8 80
 nat server protocol tcp global 113.106.95.198 81 inside 192.168.0.8 81
 nat server protocol tcp global 113.106.95.198 4430 inside 192.168.0.6 443
 nat server protocol tcp global 113.106.95.198 5222 inside 192.168.0.8 5222
 nat server protocol tcp global 113.106.95.198 5269 inside 192.168.0.8 5269
 nat server protocol tcp global 113.106.95.198 5280 inside 192.168.0.8 5280
 nat server protocol tcp global 113.106.95.198 5367 inside 192.168.0.32 5367
 nat server protocol tcp global 113.106.95.198 5369 inside 192.168.0.8 5369
 nat server protocol tcp global 113.106.95.198 5469 inside 192.168.0.8 5469
 nat server protocol tcp global 113.106.95.198 5656 inside 192.168.0.8 5656
 nat server protocol tcp global 113.106.95.198 7777 inside 192.168.0.8 7777
 nat server protocol tcp global 113.106.95.198 8007 inside 192.168.0.21 8007
 nat server protocol tcp global 113.106.95.198 8060 inside 192.168.0.8 8060
 nat server protocol tcp global 113.106.95.198 8080 inside 192.168.0.8 80
 nat server protocol tcp global 113.106.95.198 8081 inside 192.168.0.32 8081
 nat server protocol tcp global 113.106.95.198 8443 inside 192.168.0.8 8443
 nat server protocol tcp global 113.106.95.198 8888 inside 192.168.0.8 8888
 nat server protocol tcp global 113.106.95.198 9999 inside 192.168.0.8 9999
 nat server protocol tcp global 113.106.95.199 80 inside 192.168.0.13 5757
 nat server protocol tcp global 113.106.95.199 88 inside 192.168.0.33 88
 nat server protocol tcp global 113.106.95.199 3999 inside 192.168.0.7 3999
 nat server protocol tcp global 113.106.95.199 4009 inside 192.168.0.6 4009
 nat server protocol tcp global 113.106.95.199 4430 inside 192.168.0.6 4430
 nat server protocol tcp global 113.106.95.199 5222 inside 192.168.0.218 5222
 nat server protocol tcp global 113.106.95.199 5269 inside 192.168.0.218 5269
 nat server protocol tcp global 113.106.95.199 5280 inside 192.168.0.218 5280
 nat server protocol tcp global 113.106.95.199 5366 inside 192.168.0.20 5366
 nat server protocol tcp global 113.106.95.199 5367 inside 192.168.0.20 5367
 nat server protocol tcp global 113.106.95.199 5369 inside 192.168.0.218 5369
 nat server protocol tcp global 113.106.95.199 5469 inside 192.168.0.218 5469
 nat server protocol tcp global 113.106.95.199 5555 inside 192.168.0.8 5555
 nat server protocol tcp global 113.106.95.199 5656 inside 192.168.0.19 5656
 nat server protocol tcp global 113.106.95.199 6666 inside 192.168.0.31 6666
 nat server protocol tcp global 113.106.95.199 7777 inside 192.168.0.218 7777
 nat server protocol tcp global 113.106.95.199 8050 inside 192.168.0.33 80
 nat server protocol tcp global 113.106.95.199 8060 inside 192.168.0.33 80
 nat server protocol tcp global 113.106.95.199 8080 inside 192.168.0.218 8080
 nat server protocol tcp global 113.106.95.199 8081 inside 192.168.0.20 8081
 nat server protocol tcp global 113.106.95.199 8443 inside 192.168.0.218 8443
 nat server protocol tcp global 113.106.95.199 8889 inside 192.168.0.30 8889
 nat server protocol tcp global 113.106.95.199 9999 inside 192.168.0.218 9999
 nat server protocol tcp global 113.106.95.200 5656 inside 192.168.0.228 5656
 nat server protocol tcp global 113.106.95.200 5757 inside 192.168.0.13 5757
 nat server protocol tcp global 113.106.95.200 6802 inside 192.168.0.5 6802
 nat server protocol tcp global 113.106.95.200 8010 inside 192.168.0.17 8010
 nat server protocol tcp global 113.106.95.200 8050 inside 192.168.0.17 8050
 nat server protocol tcp global 113.106.95.200 8060 inside 192.168.0.17 8060
 nat server protocol tcp global 113.106.95.200 8089 inside 192.168.0.5 8089
 nat server protocol tcp global 113.106.95.200 8888 inside 192.168.0.13 8888
 nat server protocol tcp global 113.106.95.201 80 inside 192.168.0.16 80
 nat server protocol tcp global 113.106.95.201 8010 inside 192.168.0.16 8010
 nat server protocol tcp global 113.106.95.201 8050 inside 192.168.0.16 8050
 nat server protocol tcp global 113.106.95.201 8888 inside 192.168.0.16 8888
 nat server protocol tcp global 113.106.95.202 21 inside 192.168.0.22 21
 nat server protocol tcp global 113.106.95.202 5757 inside 192.168.0.12 80
 nat server protocol tcp global 113.106.95.202 8080 inside 192.168.0.12 80
 nat server protocol udp global 113.106.95.199 4009 inside 192.168.0.6 4009
interface GigabitEthernet1/0/8
 description dialer6 500M
 pppoe-client dial-bundle-number 6
interface GigabitEthernet1/0/9
 description dialer7 500M
 pppoe-client dial-bundle-number 7
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
 description dialer5 500M
 pppoe-client dial-bundle-number 5
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
 description dialer8 500M
 pppoe-client dial-bundle-number 8
interface GigabitEthernet1/0/15
 description dialer9
interface GigabitEthernet1/0/21
interface GigabitEthernet2/0/0
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet1/0/4
 port link-mode bridge
 port access vlan 140
interface GigabitEthernet1/0/14
 description to_SW-CORE_G1/3/0/1
interface GigabitEthernet1/0/16
 port access vlan 19
interface GigabitEthernet1/0/17
 port access vlan 12
interface GigabitEthernet1/0/18
 port access vlan 18
interface GigabitEthernet1/0/19
 port access vlan 14
interface GigabitEthernet1/0/20
 port access vlan 16
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/14
 description to_SW-CORE_G2/2/0/1
interface GigabitEthernet2/0/15
 port access vlan 10
 port link-aggregation group 2
object-policy ip any_to_trust
 rule 0 pass
object-policy ip local_to_trust
 rule 0 pass
object-policy ip local_to_untrust
 rule 0 pass
object-policy ip trust_to_local
 rule 0 pass
object-policy ip trust_to_untrust
 rule 0 pass
object-policy ip untrust-trust
object-policy ip untrust_to_trust
 rule 0 pass destination-ip add_server service service_port logging counting
security-zone name Local
security-zone name Trust
 import interface Vlan-interface10
 import interface Vlan-interface19
 import interface Vlan-interface200
 import interface Bridge-Aggregation1 vlan 200
 import interface Bridge-Aggregation2 vlan 10
 import interface GigabitEthernet1/0/14 vlan 200
 import interface GigabitEthernet1/0/16 vlan 19
 import interface GigabitEthernet1/0/17 vlan 12
 import interface GigabitEthernet1/0/18 vlan 18
 import interface GigabitEthernet1/0/19 vlan 14
 import interface GigabitEthernet1/0/20 vlan 16
 import interface GigabitEthernet2/0/14 vlan 200
 import interface GigabitEthernet2/0/15 vlan 10
security-zone name DMZ
security-zone name Untrust
 import interface Dialer1
 import interface Dialer2
 import interface Dialer3
 import interface Dialer4
 import interface Dialer5
 import interface Dialer6
 import interface Dialer7
 import interface Dialer8
 import interface GigabitEthernet1/0/6
 import interface GigabitEthernet1/0/7
 import interface GigabitEthernet1/0/9
 import interface GigabitEthernet1/0/11
 import interface GigabitEthernet1/0/13
 import interface GigabitEthernet1/0/15
 import interface GigabitEthernet2/0/5
 import interface GigabitEthernet2/0/6
 import interface Vlan-interface140
 import interface GigabitEthernet1/0/4 vlan 140
 attack-defense apply policy policy
security-zone name Management
 import interface GigabitEthernet1/0/0
zone-pair security source Any destination Any
zone-pair security source Local destination Trust
 object-policy apply ip local_to_trust
zone-pair security source Local destination Untrust
 object-policy apply ip local_to_untrust
zone-pair security source Trust destination Local
 object-policy apply ip trust_to_local
zone-pair security source Trust destination Untrust
 object-policy apply ip trust_to_untrust
zone-pair security source Untrust destination Trust
 object-policy apply ip untrust_to_trust
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class vty
line aux 0
line aux 1
line con 0 1
line vty 0 4
 authentication-mode scheme
line vty 5 63
 ip route-static 0.0.0.0 0 Dialer4
 ip route-static 0.0.0.0 0 Dialer6
 ip route-static 0.0.0.0 0 Dialer7
 ip route-static 0.0.0.0 0 111.111.111.111 track 1 preference 1
 ip route-static 0.0.0.0 0 Dialer8
 ip route-static 0.0.0.0 0 Dialer5
 ip route-static 10.10.0.0 16 10.10.10.1
 ip route-static 10.10.110.0 24 10.10.10.1
 ip route-static 192.168.0.0 16 10.10.10.1
 ip route-static 192.168.52.0 24 10.10.10.3
 ip route-static 192.168.53.0 24 10.10.10.3
 undo info-center enable
 snmp-agent
 snmp-agent local-engineid 800063A203703D15B78190
 snmp-agent community write system!@#$%^&*
 snmp-agent sys-info location ZZDS
 snmp-agent sys-info version all
 snmp-agent target-host trap address udp-domain 192.168.9.108 params securityname system!@#$%^&* v2c
 ssh server enable
 arp static 192.168.100.253 d461-fec4-9718
acl advanced 3000
 rule 20 permit ip
acl advanced 3010
 description dialer1
 rule 40 deny ip source 202.202.202.228 0 destination 192.168.3.0 0.0.0.255
 rule 45 deny ip source 202.202.202.228 0 destination 192.168.4.0 0.0.0.255
 rule 50 deny ip source 202.202.202.228 0 destination 192.168.5.0 0.0.0.255
 rule 55 deny ip source 202.202.202.228 0 destination 192.168.6.0 0.0.1.255
 rule 60 deny ip source 202.202.202.229 0 destination 192.168.3.0 0.0.0.255
 rule 65 deny ip source 202.202.202.229 0 destination 192.168.4.0 0.0.0.255
 rule 70 deny ip source 202.202.202.229 0 destination 192.168.5.0 0.0.0.255
 rule 80 permit ip source 192.168.7.0 0.0.0.255
 rule 85 permit ip source 192.168.3.0 0.0.0.255
 rule 95 permit ip source 192.168.5.0 0.0.0.255
acl advanced 3020
 rule 20 permit ip source 192.168.2.0 0.0.0.255
acl advanced 3040
acl advanced 3050
 description dialer2 for wifi zzkgtz36
 rule 50 permit ip source 192.168.6.0 0.0.0.255
acl advanced 3060
 description dialer3 for 36f chengfa
 rule 80 permit ip source 192.168.8.0 0.0.0.255
acl advanced 3070
 rule 0 permit ip source 192.168.52.0 0.0.0.255 logging
 rule 5 permit ip source 192.168.53.0 0.0.0.255 logging
acl advanced 3080
 description wifi "ZZDS" NETWORK
 rule 90 permit ip source 192.168.4.0 0.0.0.255
 rule 100 permit ip source 192.168.7.37 0
 rule 110 permit ip source 192.168.6.141 0
acl advanced 3090
 description FOR subnet 90
 rule 10 deny ip source 192.168.9.122 0
 rule 30 permit ip source 192.168.9.0 0.0.0.255
acl advanced 3100
 description for wifi zzgroup
 rule 10 permit ip source 192.168.3.0 0.0.0.255
acl advanced 3110
 description special 50M
 rule 30 permit ip source 192.168.0.0 0.0.0.255
acl advanced 3200
 description use 9.122 test network
 rule 10 permit ip source 192.168.9.122 0
domain system
 aaa session-limit ftp 16
 aaa session-limit telnet 16
 aaa session-limit ssh 16
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$e9SQGgK5B30z2IBh$17sWFYGClk9Zc/tucy23+1eVkAy8VnvgueTtOwb19tYNbEuACmONqlLziax0Z76N13hsaZ4V9pzh5CW2t2RdpA==
 service-type ssh telnet terminal https
 authorization-attribute user-role level-3
 ip https enable
attack-defense policy policy
 scan detect level medium action drop logging
 syn-flood detect ip 202.202.202.228 threshold 1000 action logging drop
 syn-flood detect ip 202.202.202.229 threshold 1000 action logging drop
 syn-flood detect ip 202.202.202.230 threshold 1000 action logging drop
 syn-flood detect ip 202.202.202.231 threshold 1000 action logging drop
 syn-flood detect ip 202.202.202.232 threshold 1000 action logging drop
url-filter policy teamview
 default-action permit
 category teamview action drop logging
 add blacklist 1 host text ***.***
url-filter category teamview severity 2000
 rule 1 host text teamviewer
 description teamview
app-profile 0_IPv4
 url-filter apply policy teamview
inspect block-source parameter-profile ips_block_default_parameter
inspect block-source parameter-profile url_block_default_parameter
loadbalance action ##defaultactionforllbipv4##%%autocreatedbyweb%% type link-generic
 forward all
loadbalance policy ##defaultpolicyforllbipv4##%%autocreatedbyweb%% type link-generic
 default-class action ##defaultactionforllbipv4##%%autocreatedbyweb%%
virtual-server ##defaultvsforllbipv4##%%autocreatedbyweb%% type link-ip
 virtual ip address 0.0.0.0 0
 lb-policy ##defaultpolicyforllbipv4##%%autocreatedbyweb%%
 service enable
traffic-policy
 rule name "vlan 10"
  action qos profile "vlan 10"
  source-address address-set "vlan 10"
 rule name "vlan 12"
  action qos profile other
  source-address address-set "VLAN 12"
 rule name oher
  source-address address-set "vlan 14"
  source-address address-set "Vlan 19"
  source-address address-set vlan18
 rule name wifi
  action qos profile wifi
  source-address address-set "vlan 16"
 profile name other
  bandwidth upstream maximum per-ip 10000
  bandwidth downstream maximum per-ip 15000
 profile name vlan12
  bandwidth downstream maximum per-ip 10000
 profile name "vlan 10"
  bandwidth downstream guaranteed 50000
  bandwidth downstream maximum 50000
  bandwidth upstream guaranteed 50000
  bandwidth upstream maximum 50000
  traffic-priority 7
  bandwidth upstream maximum per-ip 20000
  bandwidth downstream maximum per-ip 20000
 profile name wifi
  traffic-priority 7
  connection-limit count per-ip 1000
  bandwidth upstream maximum per-ip 8000
security-policy ip
 rule 0 name 192.168.0.7
  action pass
  counting enable
  profile 0_IPv4
  source-zone Trust
  destination-zone Untrust
 rule 1 name ips
  action pass
  counting enable
  source-zone Untrust
  destination-zone Trust
 rule 2 name trust2local
  action pass
  counting enable
  source-zone Trust
  destination-zone Local
 rule 3 name local2trust
  action pass
  counting enable
  source-zone Local
ips policy ips
 object-dir server client
 action block-source drop permit reset
 signature override all drop logging
 protect-target OperationSystem Windows
 protect-target NetworkDevice Other
 protect-target NetworkDevice Cisco
 protect-target OfficeSoftware MicrosoftOffice
 protect-target WebServer Any
 protect-target WebServer Other
 protect-target WebServer WebLogic
 protect-target Database MS-SQL
 protect-target Database MySQL
 protect-target Database Oracle
 protect-target Database ACCESS
 protect-target WebApplication Any
 protect-target WebApplication Other
 protect-target WebApplication PHP
 protect-target ApplicationSoftware Other
 protect-target ApplicationSoftware IM
 protect-target ApplicationSoftware Security
 protect-target Browser InternetExplorer
 protect-target NetworkProtocol HTTP
 protect-target NetworkProtocol FTP
 protect-target Other Other
 attack-category Vulnerability SQLInjection
 attack-category Vulnerability XSS
 attack-category Vulnerability RemoteCodeExecution
return
<ZZDS-FW>quit
Connection closing...Socket close.
Connection closed by foreign host.
[END] 2022-05-11 10:16:09
三层交换机做网关,F1050防火墙做外网出口
粉丝:148人 关注:1人
有些软件的开发者瞎几把写代码,不管什么错就先报网络错,你测试下你到打印服务的联通行,端口是否政策开放
