防火墙无法通过tracert
2022-05-12提问
  • 1收藏,2155浏览
有一台防火墙H3C F1050,防火墙上联一台路由器,下联一台交换机。这3台设备,tracert外网一台设备,IP:10.0.0.1,其中在路由器和防火墙上tracert,都可以获得完整的tracert数据;在交换机上tracert只能获得最后一跳(即10.0.0.1)的数据,中间的路径全部是*号;经过排查感觉问题是在防火墙上,但防火墙已经配置以下命令:
 ip unreachables enable
 ip ttl-expires enable
 session state-machine mode loose
仍然没有作用
以下是防火墙的配置,麻烦帮忙看看是什么原因导致
 version 7.1.064, Release 9313P1901
 sysname FW_F1050
 clock timezone Beijing add 08:00:00
 clock protocol ntp context 1
context Admin id 1
 telnet server enable
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 2
 irf member 2 priority 1
 lldp global enable
 password-recovery enable
vlan 1
vlan 100
irf-port 1/2
 port group interface GigabitEthernet1/0/15
irf-port 2/1
 port group interface GigabitEthernet2/0/15
object-group service Fang
 0 service tcp destination eq 69
 3 service tcp destination eq 1434
 5 service tcp destination eq 4444
 6 service tcp destination eq 5554
 7 service tcp destination eq 5444
 8 service tcp destination eq 1068
 9 service tcp destination eq 9996
 10 service tcp destination eq 1025
 11 service tcp destination eq 539
 12 service tcp destination eq 7995
 13 service tcp destination eq 6667
 15 service udp destination eq 1434
 17 service udp destination eq 4444
 18 service udp destination eq 5444
 19 service udp destination eq 9996
 20 service udp destination eq 1025
 21 service udp destination eq 539
 22 service udp destination eq 7995
 23 service udp destination eq 6667
 40 service tcp destination eq 3389
 50 service tcp source eq 445
 60 service udp source eq 445
 70 service udp destination eq 445
 80 service tcp destination eq 445
 90 service tcp source range 135 139
 100 service udp source range 135 139
 110 service udp destination range 135 139
 120 service tcp destination range 135 139
interface NULL0
interface Vlan-interface100
 ip address 10.X.X.X 255.255.255.0
interface GigabitEthernet1/0/0
 port link-mode route
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet2/0/0
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
interface GigabitEthernet2/0/6
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
interface GigabitEthernet2/0/10
interface GigabitEthernet2/0/11
interface GigabitEthernet2/0/12
interface GigabitEthernet2/0/13
interface GigabitEthernet2/0/14
interface GigabitEthernet2/0/18
interface GigabitEthernet2/0/19
interface GigabitEthernet2/0/20
interface GigabitEthernet2/0/21
interface GigabitEthernet2/0/22
interface GigabitEthernet2/0/23
 port link-mode bridge
 port access vlan 100
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet2/0/16
interface GigabitEthernet2/0/17
 description IRF_LINK—_GE1/0/15
object-policy ip Local-Trust
 rule 0 pass counting
object-policy ip Local-Untrust
object-policy ip Trust-Local
 rule 0 pass
object-policy ip Trust-Trust
 rule 100 pass counting
object-policy ip Trust-Untrust
 rule 15 pass service icmp-traceroute
 rule 5 drop service FangBingDu counting
 rule 5 comment FangBingDU
 rule 12 pass counting
object-policy ip Untrust-Local
 rule 0 pass
object-policy ip Untrust-Trust
 rule 56958 pass service icmp-traceroute
 rule 5 comment FangBingDu
 rule 9 pass counting
object-policy ip Untrust-Untrust
 rule 0 pass
security-zone name Local
 attack-defense apply policy test1
security-zone name Trust
 import interface Vlan-interface100
 import interface GigabitEthernet1/0/2 vlan 100
 import interface GigabitEthernet1/0/10 vlan 100
 import interface GigabitEthernet1/0/13 vlan 100
 import interface GigabitEthernet1/0/16 vlan 100
 import interface GigabitEthernet1/0/17 vlan 100
 import interface GigabitEthernet2/0/2 vlan 100
 import interface GigabitEthernet2/0/16 vlan 100
 import interface GigabitEthernet2/0/17 vlan 100
security-zone name DMZ
security-zone name Untrust
 import interface GigabitEthernet1/0/1 vlan 100
 import interface GigabitEthernet2/0/1 vlan 100
security-zone name Management
 import interface GigabitEthernet1/0/0
security-zone name tu
zone-pair security source Any destination Any
zone-pair security source Local destination Trust
 object-policy apply ip Local-Trust
zone-pair security source Local destination Untrust
 object-policy apply ip Local-Untrust
zone-pair security source Trust destination Local
 object-policy apply ip Trust-Local
zone-pair security source Trust destination Trust
 object-policy apply ip Trust-Trust
zone-pair security source Trust destination Untrust
 object-policy apply ip Trust-Untrust
zone-pair security source Untrust destination Local
 object-policy apply ip Untrust-Local
zone-pair security source Untrust destination Trust
 object-policy apply ip Untrust-Trust
zone-pair security source Untrust destination Untrust
 object-policy apply ip Untrust-Untrust
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class vty
line aux 0
line aux 1
line con 0
 set authentication password hash $h$6$6ec9UUhlpMd+4bIh$Bk5o9
line con 1
 authentication-mode scheme
line vty 0 63
 userlog flow export version 3
 time-range ceshi-dns from 16:30 9/8/2021 to 16:30 9/9/2021
 time-range test from 16:40 9/8/2021 to 16:42 9/8/2021
 sntp enable
 password-control history 3
 password-control login-attempt 5 exceed lock-time 5
domain system
 aaa session-limit ftp 16
 aaa session-limit telnet 16
 aaa session-limit ssh 16
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$HNHtkSUtAiUGx7xf$sFOWXcL34WyWPR4UENUTa
 service-type ssh https
 password-control aging 90
 password-control length 10
 password-control composition type-number 3 type-length 1
 password-control login-attempt 3 exceed lock-time 3
 session top-statistics enable
 session synchronization enable
 session synchronization dns http
 ip https enable
app-profile 5_3_56956_IPv4
 ips apply policy ceshi1 mode protect
 anti-virus apply policy default mode protect
inspect block-source parameter-profile ips_block_default_parameter
inspect capture parameter-profile ips_capture_default_parameter
inspect logging parameter-profile ips_logging_default_parameter
inspect redirect parameter-profile av_redirect_default_parameter
inspect redirect parameter-profile ips_redirect_default_parameter
inspect redirect parameter-profile url_redirect_default_parameter
ips policy default
anti-virus policy ceshi
 inspect smtp action block
 inspect pop3 action block
anti-virus policy default
return
4 个回答
粉丝:94人 关注:0人
防火墙能不能tracert,可能是中间设备没开tracert
 这条没生效  , 配置一条安全策略any到any全放通的,放在最前面,测试是不是策略阻挡
trust-untrust和untrust-trust的路径,都是有放通,应该不需要any-any吧
zhiliao_h6s6k 发表时间:2022-05-12
粉丝:119人 关注:1人
如果是回显开启,那就是策略或者路由的问题了
粉丝:25人 关注:7人
应该是被策略阻止了,你输入如下命令,允许防火墙回包icmp差错报文,再tracert看看是不是回显了一堆防火墙的地址。
其实昨天就跟你说过,用包过滤,不要用域间策略的traceroute服务,容易出问题。
