OneStor 踢出异常盘后,无法增加至系统,提示“写缓存和读缓存分区不足”
  • 1收藏,1039浏览
粉丝:0人 关注:3人
OneStro版本:ONESTOR-R0328
因OSD磁盘异常,在Handy页面正常踢出,等数据平衡后,增加新硬盘,但发现没有加速盘,所以OSD无法加入。操作记录如下:
1、踢异常盘前
rootncvk04.
MAJ:MIN
—sdfl
149de237-934a-452f-993f-b2837e2d1f28
—sddl
8:18
8:23
8:17
8:24
8:22
—d2fa7323-948c-4504-899a-6412ba51aOe9
(dm-4)
(dm-3)
253:4
253:3
253: 7
8:16
8:96
8:97
253:o
8:64
8:65
253:5
8:32
8:34
SIZE RO TYPE
di sk
0 part
0 dm
di sk
0 part
0 dm
di sk
/var/lib/ ceph/ osd/ ceph-14
/var/lib/ ceph/ osd/ ceph-12
—360000000000000000eOOOOOOeb43d8dO (dm-7)
—3600507630082018d9800000000000001 (dm-2)
sdi
sdg
—e419cOfc-71e3-4505-872f-9a14ebd75967 (dm-O)
sde
—c21bc88a-936d-469b-b840-f60b6789c539 (dm-5)
0 446. IG O
100G
100G
15M
100G
100G
14T O
14T
14T O
14T
0 446. IG O
100G
100G
100G
ath /vms/2FuBen
di sk
0 part
0 part
0 part
0 part
0 part
di sk
0 ITpath /vms/FC SM102
di sk
sdc
—sdc2
—sdc7
—sdc8
—e419c0fc
-714-4505-872f-9a14ebd75967
(dm-3) 253:3
8:39
(dm-4) 253:4
8:40
(dm-O) 253:O
—c21bc88a-936d-469b-b840-f60b6789c539 (dm-5) 253:5
0 dm
0 dm
di sk
0 part
0 dm
0 part
0 dm
0 part
0 dm
0 dm
/var/lib/ce h/osd/ce h-15
/var/lib/ce h/osd/ce h-13
/var/lib/ce h/osd/ce h-12
/var/lib/ce h/osd/ce h-14
2、踢盘后数据已经平衡后
8:16
—s db2
8:18
8:28
8:17
—s db6
8:22
—8600507680082018d9800000000000001
sdi
s dg
sde
—sdel
(dm-2)
(dm-2)
0 446. IG O
100G
100G
15H
100G
14T O
14T
14T O
14T
1.7T O
1.7T O
0 446. IG O
100G
100G
15H
100G
di sk
0 part
0 part
0 part
0 part
di sk
0 rrpath /vms/FC_SM102
di sk
258:2
258:2
8:96
8:64
8:65
—c21bc88a-986d-469b-b840-f60b6789c589 (dm-5) 258:5
sdc
—sdc2
8:82
—d2fa7828-948c-4504-899a-6412ba51aOe9 (dm-8) 258:8
—sdc7
—149de287-9846-452f-998f-b2887e2d1f28 (dm-4) 258:4
—sdc6
di sk
di sk
0 part
0 dm
di sk
0 part
0 dm
0 part
0 dm
'var/ li b/ ceph/ osd/ ceph-18
—860000000000000000eOOOOOOeb42d8dO (dm-6)
258:6
f 4h18, ILceph—15tU'F
0 part
0 part
0 dm ,ivar/lib/ce h/ osd/ce h -18
di sk
0 rrpath /vms/8FuBen
3、无法添加硬盘,没有显示加速盘
ONEStor
源 管 理
主 机 管 理
速 盘
读 写 存 开 后 。
P 》 管 理
块 存 储
又
对 象 存 储
高 可 用
监 控 告 警
HOD: /dev/sdg
1 上 TB
已 选 中 1 块 数 盘
问题:
1、请问如何才能增加回硬盘?请各位大神给指点一下,要是有相关文档也可以,多谢,多谢!
2、要是清理现有系统里的相关信息,又如何清理呢?
3、是不是需要手动创建分区?与OneStor配置有什么关系吗
67 九段
粉丝:57人 关注:4人
后台执行partpobe试下呢,看看抱什么错,正常不需要再做什么操作
zhiliao_8f7cxH 知了小白
粉丝:0人 关注:3人
多谢
正常答案是:
echo 0> /sys/block/sdb/queue/rotational
echo 0> /sys/block/sdc/queue/rotational
SDG已经加入:
还有个大问题是,加速SSD如何更换,我先看文档,看能不能自己更换,如果不行,我还要麻烦大家。[坏笑]
echo 0> /sys/block/sdb/queue/rotational这个就是集群错误的把 SSD识别为HDD了,修改一下转速 ,居然是这个问题。我之前想到的也是一楼的答复重新探测一下。
发表时间:2022-05-12
正常踢出OSD后,所有的读写缓存都已收回,数据平衡后还看不到,我就在想是SSD配置问题,或者需要手动增加分区,后发现这个配置,试过就可以了。 如果还不可以的话,我计划把读写SSD手动分区试试。
zhiliao_8f7cxH 发表时间:2022-05-13
