请老大看看我的路由器授权了,为什么ap离线?附上部分代码
2022-05-12提问
  • 1收藏,1109浏览
粉丝:0人 关注:5人
dhcp server ip-pool lan1 gateway-list 10.1.254.100 network 10.1.254.0 mask 255.255.255.0 address range 10.1.254.50 10.1.254.200 dns-list 10.1.254.100 forbidden-ip-range 192.168.1.254 192.168.1.254 option 43 ip-address 10.1.254.100 # dhcp server ip-pool vlan1 # dhcp server ip-pool vlan-interface230 gateway-list 192.168.70.1 network 192.168.70.0 mask 255.255.255.0 address range 192.168.70.2 192.168.70.254 dns-list 192.168.70.1 202.96.128.86 forbidden-ip-range 192.168.70.1 192.168.70.1 option 43 ip-address 10.1.254.100 wlan service-template h3c789f ssid H3C789F vlan 230 akm mode psk preshared-key pass-phrase cipher cipher-suite ccmp cipher-suite tkip security-ie rsn security-ie wpa service-template enable 庆: interface Vlan-interface1 description LAN-interface tcp mss 1280 ip subscriber l2-connected enable ip subscriber initiator dhcp enable ip subscriber initiator unclassified-ip enable ip subscriber dhcp domain ipoeenabledomain ip subscriber unclassified-ip domain ipoeenabledomain # interface Vlan-interface230 description LAN-interface ip address 192.168.70.1 255.255.255.0 wlan ap-group default-group vlan 1 ap-model WA5320E-WiNet   radio 1   radio 2   radio enable   service-template 1   gigabitethernet 1   gigabitethernet 2 ap-model WA5320E-WiNet   radio 1   radio enable   service-template h3c789f   radio 2   radio enable   service-template h3c789f   gigabitethernet 1   gigabitethernet 2 # wlan ap 8F-4 model WA5320E-WiNet  serial-id 219801A1FF8187 vlan 1 radio 1 radio 2 gigabitethernet 1 gigabitethernet 2
知了小白
粉丝: 关注:
看你写了option 43 你的是三层注册,你换了路由器后,地址有没有改过,路由配置和之前一致么
你登录AC或者是AP上,重启AP,后开始crt 上打印的信息是什么,根据打印出来的提示在排查
粉丝:11人 关注:6人
ap离线了说明之前上线过,在不动配置的情况下,配置应该没有太大问题,主要是检查一下是不是授权是临时的到期了display license可以查看,或者有可能ap故障了离线
zhiliao_DBj3XY 知了小白
粉丝:0人 关注:5人
我换了路由器,这个路由器在三层ip,以前是在vlan1 ip
那要看一下能否ping通ap,已经新设备有没有授权
vxlan的弟弟vlan 发表时间:2022-05-12
