uis登录界面报错404
2022-05-14提问
  • 1收藏,768浏览
uis登录界面报错404,这个是什么原因?
系统版本是:0750P05
粉丝:3人 关注:0人
查看tomcat8
service tomcat8 status
重启tomcat8
service tomcat8 restart
使用上面那个命令后再查看下tomcat8的状态买几本就解决了这个问题。
您好,能给付个具体操作步骤吗
十年寒如雪 发表时间:2022-05-14
也没找到 看的这个帖子https://zhiliao.h3c.com/questions/dispcont/141811
zhiliao_Lyfcmg 发表时间:2022-05-14
[root@cvknode ~]# service tomcat8 status Redirecting to /bin/systemctl status tomcat8.service ● tomcat8.service - Apache Tomcat Web Application Container Loaded: loaded (/usr/lib/systemd/system/tomcat8.service; enabled; vendor preset: disabled) Active: active (running) since Sat 2022-05-14 14:29:22 CST; 33min ago Process: 9101 ExecStart=/var/lib/tomcat8/bin/startup.sh (code=exited, status=0/SUCCESS) Main PID: 9219 (java) Tasks: 283 Memory: 1.8G CGroup: /system.slice/tomcat8.service └─9219 /usr/bin/java -Djava.util.logging.config.file=/var/lib/tomcat8/conf/logging.properties -Djava.util.logg... May 14 14:30:00 cvknode sudo[18068]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/opt/bin/ms_get_status.sh May 14 14:30:00 cvknode sudo[18193]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/ls /etc/redhat-release May 14 14:30:00 cvknode sudo[18235]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/[ -d /home/sysadmin/.ssh/ ] May 14 14:30:01 cvknode sudo[18247]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/cp /root/.ssh/id_rsa.../.ssh/ May 14 14:30:01 cvknode sudo[18254]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/cp /root/.ssh/id_rsa.../.ssh/ May 14 14:30:01 cvknode sudo[18260]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/cp /root/.ssh/known_.../.ssh/ May 14 14:30:01 cvknode sudo[18267]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/cp /root/.ssh/author.../.ssh/ May 14 14:30:01 cvknode sudo[18273]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chmod 600 /home/sysa...sa.pub May 14 14:30:01 cvknode sudo[18280]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/chown -R sysadmin:ro...n/.ssh May 14 14:30:02 cvknode sudo[18626]: root : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/sbin/iptables-restore Hint: Some lines were ellipsized, use -l to show in full. [root@cvknode ~]# [root@cvknode ~]# service tomcat8 restart Redirecting to /bin/systemctl restart tomcat8.service
我试了 还是不行。。。
400问问
开局,我重装吧。。。
