H3C S5500V3-24P-SI vlan间不通信
2022-05-18提问
  • 1收藏,1229浏览
Zzhen 零段
三层交换机上联是路由器,路由上联是电信外网设备,在三层和路由器上做了静态路由,路由器在做nat,针对三层的valn5、valn30转换上网;三层划分了valn5、valn30、vlan100、vlan1等,每个vlan都配置了vlanif地址。
问题:在任意一个vlan下,ping网关可以通,ping其他vlan的网关也都可以通,但是ping其他vlan内的地址不通。
例如:192.168.5.2主机 ping192.168.30.1(vlanif网关地址),可以通;ping192.168.30.5 主机不通
求解一下是怎么回事。
  1. dhcp enabl
  2. lldp global enable
  3. password-recovery enable
  4. vlan 1
  5. vlan 5
  6. vlan 20
  7. vlan 30
  8. vlan 100
  9. stp global enable
  10. dhcp server ip-pool 192.168.5.X
  11. gateway-list 192.168.5.1
  12. network 192.168.5.0 mask 255.255.255.0
  13. dns-list 202.102.192.68
  14. interface NULL0
  15. interface Vlan-interface1
  16. service slot 1
  17. ip address 192.168.99.254 255.255.255.0
  18. dhcp server apply ip-pool smartmc
  19. undo dhcp select server
  20. dhcp client identifier ascii fc609bc97328-VLAN0001
  21. #
  22. interface Vlan-interface5
  23. ip address 192.168.5.1 255.255.255.0
  24. #
  25. interface Vlan-interface20
  26. ip address 192.168.20.1 255.255.255.0
  27. undo dhcp select server
  28. #
  29. interface Vlan-interface30
  30. ip address 192.168.30.1 255.255.255.0
  31. undo dhcp select server
  32. #
  33. interface Vlan-interface100
  34. ip address 10.10.10.1 255.255.255.0
  35. undo dhcp select server
  36. #
  37. interface GigabitEthernet1/0/23
  38. port link-mode route
  39. ip address 192.168.188.254 255.255.255.0
  40. undo dhcp select server
  41. #
  42. interface GigabitEthernet1/0/1
  43. port link-mode bridge
  44. port access vlan 5
  45. #
  46. interface GigabitEthernet1/0/2
  47. port link-mode bridge
  48. port access vlan 5
  49. #
  50. interface GigabitEthernet1/0/3
  51. port link-mode bridge
  52. port access vlan 5
  53. #
  54. interface GigabitEthernet1/0/4
  55. port link-mode bridge
  56. port access vlan 5
  57. #
  58. interface GigabitEthernet1/0/5
  59. port link-mode bridge
  60. port access vlan 5
  61. #
  62. interface GigabitEthernet1/0/6
  63. port link-mode bridge
  64. port access vlan 20
  65. #
  66. interface GigabitEthernet1/0/7
  67. port link-mode bridge
  68. port access vlan 100
  69. #
  70. interface GigabitEthernet1/0/8
  71. port link-mode bridge
  72. port access vlan 100
  73. #
  74. interface GigabitEthernet1/0/9
  75. port link-mode bridge
  76. port access vlan 100
  77. #
  78. interface GigabitEthernet1/0/10
  79. port link-mode bridge
  80. port access vlan 100
  81. #
  82. interface GigabitEthernet1/0/11
  83. port link-mode bridge
  84. port access vlan 100
  85. #
  86. interface GigabitEthernet1/0/12
  87. port link-mode bridge
  88. port access vlan 100
  89. #
  90. interface GigabitEthernet1/0/13
  91. port link-mode bridge
  92. port access vlan 100
  93. #
  94. interface GigabitEthernet1/0/14
  95. port link-mode bridge
  96. port access vlan 100
  97. #
  98. interface GigabitEthernet1/0/15
  99. port link-mode bridge
  100. port access vlan 5
  101. #
  102. interface GigabitEthernet1/0/16
  103. port link-mode bridge
  104. port access vlan 5
  105. #
  106. interface GigabitEthernet1/0/17
  107. port link-mode bridge
  108. #
  109. interface GigabitEthernet1/0/18
  110. port link-mode bridge
  111. #
  112. interface GigabitEthernet1/0/19
  113. port link-mode bridge
  114. #
  115. interface GigabitEthernet1/0/20
  116. port link-mode bridge
  117. port access vlan 30
  118. #
  119. interface GigabitEthernet1/0/21
  120. port link-mode bridge
  121. port access vlan 30
  122. #
  123. interface GigabitEthernet1/0/22
  124. port link-mode bridge
  125. port access vlan 30
  126. #
  127. interface GigabitEthernet1/0/24
  128. port link-mode bridge
  129. #
  130. interface GigabitEthernet1/0/25
  131. port link-mode bridge
  132. #
  133. interface GigabitEthernet1/0/26
  134. port link-mode bridge
  135. #
  136. interface Ten-GigabitEthernet1/0/27
  137. port link-mode bridge
  138. #
  139. interface Ten-GigabitEthernet1/0/28
  140. port link-mode bridge
  141. #
  142. ip route-static 0.0.0.0 0 GigabitEthernet1/0/23 192.168.188.1
  143. #
粉丝:154人 关注:1人
1、检查下其他VLAN内的地址有没有配置网关
2、检查下其他VLAN内的地址终端防火墙有没有关
3、你的配置都是基础配置,没啥问题,大概率还是终端的问题
谢谢找到问题了 ,是主机防火墙问题
Zzhen 发表时间:2022-05-19
回复Zzhen:
不客气
叫我靓仔 发表时间:2022-05-19
粉丝:3人 关注:0人
查看设备接口配置无问题,如果终端之间不能互通,建议配置流量统计查看交换机是否正常转发
接口配置没有问题,或者说接口基本没有配置都是默认的,三层一般设置vlanif地址,不就能和其他vlan内主机互通了吗。我看了几遍配置也没发现异常不知道问题出在哪。
Zzhen 发表时间:2022-05-18
连接其他主机的端口是否放行所有vlan通过
三层一般设置vlanif地址,不就能和其他vlan内主机互通了吗。走的是三层,跟放不放行vlan没关系吧。三层上联口是路由模式,直接配置的IP地址。
你直接将各主机接在三层交换机的端口了?没有经过二层交换机吗
zhiliao_OTt34q 发表时间:2022-05-18
没有二层交换
