报错: blocked FC remote port time out
2022-05-19提问
  • 1收藏,1368浏览
型号:HBA卡:32Gb 2-Port PCIe Fiber Channel Host Bus Adapter (With Two SFP+ Transceivers)(FIO)*2
OS:Centos 7
Server: H3C R4900 G3
报错截图:
1.目前服务器未链接 fc swith.
2.单机状态
3.仅配置了bond 0 和ip地址。
粉丝:22人 关注:25人
  • A remote port (rport) is logging into and out-of the HBA which causes a rport tracking resource first to be created and then deleted. When the rport data structure is reclaimed, the message results.
    • Typically this is caused by a SAN appliance or some other remote port on the SAN (other than a storage port) being present within the configuration.
    • Most often happens one time at boot -- after an HBA logs into the SAN it becomes visible to other ports in its zone and these may ping it one time to ascertain its port type/capability. With some SAN appliances however, the "pinging" of the HBA may be more frequent
参考https://access.redhat.com/solutions/65596
linux 系统进不去了?
对头
zhiliao_AOQyuU 发表时间:2022-05-19
是装完系统了,还是没有装完
zhiliao_GeOM0O 发表时间:2022-05-19
粉丝:139人 关注:0人
您好,建议根据RedHat官方指导意见进行升级multipath至75版本。
粉丝:0人 关注:2人
这个问题后来解决了吗?
