imc 绿盟mib文件导入失败
2022-05-24提问
  • 1收藏,1024浏览
IMC导入绿盟的MIB文件时提示如下报错:
但相应的目录下是存在这两个文件的:
请问大神如何处理该问题?
版本信息:iMC PLAT 7.3 (E0705P06)
粉丝:11人 关注:2人
要选上使用系统MIB库
感谢回复,选择使用系统MIB库之后又提示编译MIB文件失败,Failed to resolve OID for internet
charlyq 发表时间:2022-05-24
charlyq 知了小白
截图如下:
-- File Name : IceEye -- Date : Mon Oct 24 15:27:07 CST 2005 -- Author : AdventNet Agent Toolkit C Edition - MibEditor 6 IceEye DEFINITIONS ::= BEGIN IMPORTS DisplayString FROM RFC1213-MIB enterprises,OBJECT-TYPE,NOTIFICATION-TYPE, Integer32, Unsigned32, Counter64 FROM SNMPv2-SMI; internet OBJECT IDENTIFIER ::= { dod 1 } private OBJECT IDENTIFIER ::= { internet 4 } enterprises OBJECT IDENTIFIER ::= { private 1 } nsfocus OBJECT IDENTIFIER ::= { enterprises 19849 } iceye OBJECT IDENTIFIER ::= { nsfocus 2 } comm OBJECT IDENTIFIER ::= { nsfocus 6 } iceyeinfo OBJECT IDENTIFIER ::= { iceye 2 } devinfo OBJECT IDENTIFIER ::= { comm 1 } devstat OBJECT IDENTIFIER ::= { comm 2 } netstat OBJECT IDENTIFIER ::= { devstat 4 } slotstatus OBJECT IDENTIFIER ::= { devstat 11 } slotinfo OBJECT IDENTIFIER ::= { slotstatus 2 } devtype OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devinfo 1 } devid OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devinfo 2 } hwinfo OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devinfo 3 } version OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devinfo 4 } product OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devinfo 5 } enterprise OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devinfo 6 } msgsource OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devinfo 7 } diskusageTable OBJECT-TYPE SYNTAX SEQUENCE OF DiskusageEntry MAX-ACCESS not-accessible STATUS current DESCRIPTION "Description." ::= { devstat 1 } diskusageEntry OBJECT-TYPE SYNTAX DiskusageEntry MAX-ACCESS not-accessible STATUS current DESCRIPTION "Description." INDEX { diskidx } ::= { diskusageTable 1 } DiskusageEntry ::= SEQUENCE { diskidx Integer32, diskusage Integer32 } diskidx OBJECT-TYPE SYNTAX Integer32 (1..20) MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { diskusageEntry 1 } diskusage OBJECT-TYPE SYNTAX Integer32 (0..100) MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { diskusageEntry 2 } cpuusage OBJECT-TYPE SYNTAX Integer32 (0..100) MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devstat 2 } memusage OBJECT-TYPE SYNTAX Integer32 (0..100) MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devstat 3 } bps OBJECT-TYPE SYNTAX Counter64 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { netstat 1 } pps OBJECT-TYPE SYNTAX Counter64 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { netstat 2 } tcpsession OBJECT-TYPE SYNTAX Counter64 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { netstat 3 } bps32 OBJECT-TYPE SYNTAX Unsigned32 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { netstat 31 } pps32 OBJECT-TYPE SYNTAX Unsigned32 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { netstat 32 } tcpsession32 OBJECT-TYPE SYNTAX Unsigned32 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { netstat 33 } hdspace OBJECT-TYPE SYNTAX Integer32 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devstat 5 } fanstatus OBJECT-TYPE SYNTAX Counter64 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devstat 9 } cputemp OBJECT-TYPE SYNTAX Integer32 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { devstat 10 } slotcount OBJECT-TYPE SYNTAX Integer32 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { slotstatus 1 } slotsn OBJECT-TYPE SYNTAX Integer32 MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { slotinfo 1 } slottype OBJECT-TYPE SYNTAX OCTET STRING MAX-ACCESS read-only STATUS current DESCRIPTION "Description." ::= { slotinfo 2 } icePps OBJECT-TYPE SYNTAX DisplayString ACCESS read-only STATUS mandatory DESCRIPTION "Packets per Second" ::= { iceyeinfo 1 } iceBps OBJECT-TYPE SYNTAX DisplayString ACCESS read-only STATUS mandatory DESCRIPTION "Bytes per Second" ::= { iceyeinfo 2 } iceTcpSession OBJECT-TYPE SYNTAX DisplayString ACCESS read-only STATUS mandatory DESCRIPTION "Tcp Sessions per Second" ::= { iceyeinfo 3 } iceyesysinfo OBJECT IDENTIFIER ::= { iceye 3 } iceCPU OBJECT-TYPE SYNTAX DisplayString ACCESS read-only STATUS mandatory DESCRIPTION "CPU usage (%)" ::= { iceyesysinfo 1 } iceMem OBJECT-TYPE SYNTAX DisplayString ACCESS read-only STATUS mandatory DESCRIPTION "Memory usage (%)" ::= { iceyesysinfo 2 } iceHdspace OBJECT-TYPE SYNTAX DisplayString ACCESS read-only STATUS mandatory DESCRIPTION "Available storage space (MB)" ::= { iceyesysinfo 3 } produce OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "produce" ::= {iceye 4} enterprise OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "enterprise" ::= {iceye 5} msgscource OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "message source" ::= {iceye 6} --alarm alarmobject OBJECT IDENTIFIER ::= {iceye 1} --msel msel OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "xxx" ::= {alarmobject 1} --acted acted OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "xxx" ::= {alarmobject 2} --sip sip OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "source ip" ::= {alarmobject 3} --sport sport OBJECT-TYPE SYNTAX Integer32 ACCESS read-only STATUS current DESCRIPTION "source port" ::= {alarmobject 4} --dip dip OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "destination ip" ::= {alarmobject 5} --dport dport OBJECT-TYPE SYNTAX Integer32 ACCESS read-only STATUS current DESCRIPTION "destination port" ::= {alarmobject 6} --smac smac OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "source mac" ::= {alarmobject 7} --dmac dmac OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "destination mac" ::= {alarmobject 8} --ruleid ruleid OBJECT-TYPE SYNTAX Integer32 ACCESS read-only STATUS current DESCRIPTION "rule id" ::= {alarmobject 9} --date date OBJECT-TYPE SYNTAX Integer32 ACCESS read-only STATUS current DESCRIPTION "date" ::= {alarmobject 10} --loghost loghost OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "xxx" ::= {alarmobject 11} --attacktype attacktype OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "attack type" ::= {alarmobject 12} --techtype techtype OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "xxx" ::= {alarmobject 13} --securetype securetype OBJECT-TYPE SYNTAX Integer32 ACCESS read-only STATUS current DESCRIPTION "xxx" ::= {alarmobject 14} --fashiontype fashiontype OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "xxx" ::= {alarmobject 15} --servicetype servicetype OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "service type" ::= {alarmobject 16} --msg msg OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "message" ::= {alarmobject 17} --ar ar OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "xxx" ::= {alarmobject 18} --ds ds OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "xxx" ::= {alarmobject 19} --user user OBJECT-TYPE SYNTAX OCTET STRING ACCESS read-only STATUS current DESCRIPTION "xxx" ::= {alarmobject 20} --Trap traptypeII OBJECT IDENTIFIER ::= {iceye 7} --SYSMSG sysmsg NOTIFICATION-TYPE OBJECTS {iceCPU,iceMem,iceHdspace} STATUS current DESCRIPTION "system information" ::= {traptypeII 1} --NetMsg netmsg NOTIFICATION-TYPE OBJECTS {icePps,iceBps,iceTcpSession} STATUS current DESCRIPTION "Net information" ::= {traptypeII 2} --AlarmMSG alarmmsg NOTIFICATION-TYPE OBJECTS {msel,acted,sip,sport,dip,dport,smac,dmac,ruleid,date,loghost,attacktype,techtype,securetype,fashiontype,servicetype,msg,ar,ds,user} STATUS current DESCRIPTION "xxx" ::= {traptypeII 3} --active active NOTIFICATION-TYPE OBJECTS {} STATUS current DESCRIPTION "alive" ::= {traptypeII 4} END
经检查是绿盟设备下载的mib文件有问题,在其报错的internet OBEJECT IDENTIFIER前添加: org OBJECT IDENTIFIER ::= { iso 3 } dod OBJECT IDENTIFIER ::= { org 6 } 保存后就可以了
charlyq 发表时间:2022-05-25
回复charlyq:
使用什么方法检查的MIB文件有问题?
zhiliao_H9EnVh 发表时间:2023-07-25
