想将cisc o 设备配置变成H3C配置
2022-05-24提问
  • 1收藏,1176浏览
帮忙将cisco配置翻译成H3C配置
cisco
ip nbar port-map http tcp 80 8080
ip flow-cache timeout active 10
ip multicast-routing
mls ip multicast replication-mode ingress
ipv6 mfib hardware-switching replication-mode ingress
mpls label protocol ldp
mls flow ip interface-full
no mls flow ipv6
mls qos
no mls acl tcam share-global
mls cef error action freeze
multilink bundle-name authenticated
spanning-tree mode pvst
spanning-tree extend system-id
redundancy
 main-cpu
  auto-sync running-config
 mode sso
vlan internal allocation policy ascending
vlan access-log ratelimit 2000
interface Port-channel12
 mtu 1540
 ip address 10.0.0.1 255.255.255.252
 ip pim sparse-mode
 ip multicast boundary 3
 ip policy route-map test
 mpls ip
interface GigabitEthernet1/6
 no ip address
 channel-group 12 mode on
interface Vlan100
 ip address 172.26.0.1 255.255.248.0 secondary
 ip address 172.28.8.1 255.255.248.0 secondary
 ip address 10.11.12.254 255.255.255.0
 ip access-group 160 in
 no ip redirects
 ip pim sparse-mode
 ip policy route-map teda-cable
 ip igmp snooping fast-leave
 no ip igmp snooping
ip vrf weisheng
 rd 100:210
 route-target export 100:2100
 route-target import 100:2100
interface Vlan101
 ip vrf forwarding weisheng
router ospf 99 vrf weisheng
 log-adjacency-changes
 redistribute bgp 100 subnets
 network 192.168.1.1 0.0.0.255 area 0
router ospf 100
 router-id 10.10.10.1
 redistribute ospf 10 subnets route-map host
 passive-interface Loopback0
 network 7.7.7.0 0.0.0.255 area 0
default-information originate always
router bgp 100
 bgp router-id 200.200.200.1
 no bgp default ipv4-unicast
 bgp log-neighbor-changes
 neighbor 100.100.102.253 remote-as 65529
 neighbor 100.100.102.253 shutdown
 neighbor 200.200.200.2 remote-as 100
 neighbor 200.200.200.2 update-source Loopback0
address-family ipv4
  no synchronization
  network 200.200.200.1 mask 255.255.255.255
  neighbor 100.100.102.253 activate
  neighbor 200.200.200.2 activate
  neighbor 200.200.200.2 filter-list 1 out
address-family vpnv4
  neighbor 200.200.200.2 send-community both
address-family ipv4 vrf bo
  no synchronization
  redistribute connected
 exit-address-family
ip as-path access-list 1 deny _55466_
ip as-path access-list 1 permit .*
ip as-path access-list 2 deny _65529_
ip as-path access-list 2 permit .*
no ip http server
no ip http secure-server
ip pim rp-address 10.10.10.10
route-map test permit 10
 match ip address 107
 set ip default next-hop 10.10.101.2
route-map test permit 15
 match ip address 105
 set ip default next-hop 10.10.101.253
snmp-server enable traps module
monitor session 1 source interface g 2/1
monitor session 1 destination interface g 7/5
lmm 八段
粉丝:5人 关注:2人
可以用官网的标杆的神奇翻译,里面有转化工具
标杆的神器转化工具,对导入和文件有格式或者大小的要求吗?
萨拉zanetti 发表时间:2022-05-26
粉丝:144人 关注:0人
您好,试试标杆神器进行翻译
谢谢,试过,txt文档,显示转化失败
配置转换直接翻译的,有些私有协议可能转换不完全;
no mls flow ipv6
mls qos
stp mode pvst
redundancy
main-cpu
mode sso
mtu 1540
ip pim sparse-mode
mpls ip
no ip address
interface Vlan100
ip address 172.26.0.1 255.255.248.0 sub
no ip redirects
ip pim sparse-mode
no ip igmp snooping
ip vrf weisheng
rd 100:210
interface Vlan101
router ospf 100
router bgp 100
address-family ipv4
no synchronization
no synchronization
exit-address-family
no ip http server
route-policy test permit node 15
好像有点问题 我在去翻译一遍
DuangDuang 发表时间:2022-05-24
感觉像是基本没翻译, 我用标杆的神器工具翻译后,也差不多是这样。泪奔
回复萨拉zanetti:
我在给你翻译一个
DuangDuang 发表时间:2022-05-26
回复萨拉zanetti:
# # stp mode stp stp enable # multicast routing-enable # undo igmp-snooping enable # observe-port 1 interface g 7/5 # ip netstream timeout active 10 # undo http server enable undo http secure-server enable # ip vpn-instance weisheng route-distinguisher 100:210 ip binding vpn-instance weisheng ip address 192.168.1.1 255.255.255.0 vpn-target 100:2100 export-extcommunity # interface vlanif100 ip address 10.11.12.254 255.255.255.0 ip address 172.28.8.1 255.255.248.0 sub undo icmp redirect send pim sm ip address 172.26.0.1 255.255.248.0 sub # interface vlanif101 # interface Eth-Trunk12 ip address 10.0.0.1 255.255.255.252 jumboframe enable 1540 pim sm # interface GigabitEthernet1/0/6 eth-trunk 12 # bgp 100 router-id 200.200.200.1 undo default ipv4-unicast peer 100.100.102.253 as-number 65529 peer 100.100.102.253 enable peer 200.200.200.2 as-number 100 peer 200.200.200.2 enable peer 100.100.102.253 ignore peer 200.200.200.2 connect-interface Loopback0 # ipv4-family unicast peer 100.100.102.253 enable peer 200.200.200.2 enable undo synchronization network 200.200.200.1 255.255.255.255 peer 200.200.200.2 as-path-filter 1 export # ipv4-family vpnv4 peer 200.200.200.2 enable peer 200.200.200.2 advertise-community peer 200.200.200.2 advertise-ext-community # ipv4-family vpn-instance bo import-route direct undo synchronization # ospf 99 vpn-instance weisheng import-route bgp permit-ibgp enable log area 0 network 192.168.1.1 0.0.0.255 # ospf 100 router-id 10.10.10.1 default-route-advertise always silent-interface Loopback0 enable log area 0 network 7.7.7.0 0.0.0.255 # route-policy test permit node 10 if-match acl 3707 # route-policy test permit node 15 if-match acl 3705 # pim static-rp 10.10.10.10 # ip as-path-filter 1 deny _55466_ ip as-path-filter 1 permit .* ip as-path-filter 2 deny _65529_ ip as-path-filter 2 permit .* # return
