H3C WX3024E+ap的SSID搜不到?
2018-08-25提问
  • 1收藏,1276浏览
大家好!为什么移动设备搜索不到ap的SSID?是配置有问题吗?
配置如下:
<ap>disp cu
 version 5.20, Release 3507P22
 sysname ap
 domain default enable system
 telnet server enable
 port-security enable
 oap management-ip 192.168.0.101 slot 0
 wlan auto-ap enable
 password-recovery enable
vlan 1
vlan 4000 to 4001
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
dhcp server ip-pool vlan4000
 network 10.80.255.0 mask 255.255.255.0
 gateway-list 10.80.255.254
dhcp server ip-pool vlan4001
 network 10.80.254.0 mask 255.255.255.0
 gateway-list 10.80.254.254
 dns-list 218.201.4.3 61.128.192.68
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$8xKWRHUPd5zq8q0oa34NOyPJ7ijpZod3
 authorization-attribute level 3
 service-type telnet
wlan rrm
 dot11a mandatory-rate 6 12 24
 dot11a supported-rate 9 18 36 48 54
 dot11b mandatory-rate 1 2
 dot11b supported-rate 5.5 11
 dot11g mandatory-rate 1 2 5.5 11
 dot11g supported-rate 6 9 12 18 24 36 48 54
wlan service-template 2 crypto
 ssid xxk
 bind WLAN-ESS 1
 cipher-suite tkip
 security-ie wpa
 service-template enable
wlan ap-group default_group
 ap cqzc
 ap 7425-8a8b-0ba0
interface Bridge-Aggregation1
 port link-type trunk
 port trunk permit vlan all
interface NULL0
interface Vlan-interface4000
 ip address 10.80.255.254 255.255.255.0
interface Vlan-interface4001
 ip address 10.80.254.254 255.255.255.0
 port link-aggregation group 1
interface WLAN-ESS1
 port access vlan 4001
 port-security port-mode psk
 port-security tx-key-type 11key
 port-security preshared-key pass-phrase cipher $c$3$Z+1S5gua91CIURxi+h5CEC3F9Mi
L4/774hf/ew==
wlan ap 7425-8a8b-0ba0 model WA2620i-AGN id 2
 serial-id 219801A0CNC141002960
 radio 1
  service-template 2
  radio enable
 radio 2
  service-template 2
  radio enable
wlan ap cqzc model WA2620i-AGN id 1
 serial-id auto
 radio 1
  service-template 2
  radio enable
 radio 2
  service-template 2
  radio enable
wlan ips
 malformed-detect-policy default
 signature deauth_flood signature-id 1
 signature broadcast_deauth_flood signature-id 2
 signature disassoc_flood signature-id 3
 signature broadcast_disassoc_flood signature-id 4
 signature eapol_logoff_flood signature-id 5
 signature eap_success_flood signature-id 6
 signature eap_failure_flood signature-id 7
 signature pspoll_flood signature-id 8
 signature cts_flood signature-id 9
 signature rts_flood signature-id 10
 signature addba_req_flood signature-id 11
 signature-policy default
 countermeasure-policy default
 attack-detect-policy default
 virtual-security-domain default
 ip route-static 0.0.0.0 0.0.0.0 10.80.254.252
 dhcp enable
user-interface con 0
user-interface vty 0 4
 authentication-mode scheme
 user privilege level 3
return
<ap>
配置没有问题啊,在看看ap是不是运行状态
<H3C>display wlan ap all
看state是不是R/M,不是的话,就是ap没有上线,检查ap与ac之间的线路,为什么ap注册不上ac
你好,显示如下: <ap>disp wlan ap all Total Number of APs configured : 2 Total Number of configured APs connected : 0 Total Number of auto APs connected : 0 Total Number of APs connected : 0 Maximum AP capacity : 24 Remaining AP capacity : 24 AP Profiles State : I = Idle, J = Join, JA = JoinAck, IL = ImageLoad C = Config, R = Run, KU = KeyUpdate, KC = KeyCfm M = Master, B = Backup -------------------------------------------------------------------------------- AP Name State Model Serial-ID -------------------------------------------------------------------------------- cqzc I WA2620i-AGN auto 7425-8a8b-0ba0 I WA2620i-AGN 219801A0CNC141002960 ------------------------------------------------------------------------------- <ap> <ap>
zhiliao_FJONg 发表时间:2018-08-25
zhiliao_FJONg 知了小白
你好,显示如下:
                                  AP Profiles
<ap>
<ap>
那就是ap不在线了,排查一下线路或者网络问题吧,看看ap有没有获取到地址,和ac能不能通
哈配哈哈配 发表时间:2018-08-25
