MSR36-40无法进去配置页面,怎么解决
2022-06-15提问
  • 1收藏,631浏览
突然断电后,路由接口灯不亮无法使用,登录后无法进去配置页面,怎么解决? ==================================================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Configuration | |<7> BootWare Operation Menu | |<8> Skip Authentication for Console Login | |<9> Storage Device Operation | |<0> Reboot | ============================================================================ Ctrl+Z: Access EXTENDED ASSISTANT MENU Ctrl+F: Format File System Ctrl+C: Display Copyright Enter your choice(0-9): 1 Loading the main image files... The image does not exist! Loading the backup image files... The image does not exist! Loading images fails. Loading the main boot and system image files... The system image does not exist! Loading the backup boot and system image files... The image does not exist! Loading images fails. Loading the main boot image... Loading file cfa0:/msr36-cmw710-boot-r0304p15.bin... The image does not exist! Loading the backup boot image... The image does not exist! Loading boot image fails. ==================================================== |<1> Boot System | |<2> Enter Serial SubMenu | |<3> Enter Ethernet SubMenu | |<4> File Control | |<5> Restore to Factory Default Configuration | |<6> Skip Current System Conf
粉丝:24人 关注:1人
版本丢失了,可以参考https://zhiliao.h3c.com/Theme/details/110612重新导入
粉丝:144人 关注:1人
系统丢了,重新刷机重新配置
粉丝:94人 关注:0人
版本丢失,官网下载重新刷入
版本
https://www.h3c.com/cn/d_202201/1523626_30005_40.htm
yx800
01230123
