.IPE格式的升级软件包必须要在设备上解压然后再指定bin为下次启动的系统文件?
2022-06-15提问
  • 1收藏,1043浏览
佚名 九段
粉丝:22人 关注:0人
可以直接指定,会自动解压
<Sysname>boot-loader file flash:/S7500X.ipe all main
Verifying the file flash:/S7500X.ipe on slot 0...........................Done.
H3C S7503X images in IPE:
S7500X-CMW710-BOOT-test.bin
S7500X-CMW710-SYSTEM-test.bin
S7500X-CMW710-FREERADIUS-test.bin
This command will set the main startup software images. Continue? [Y/N]:y
Add images to slot 0.
Verifying the file flash:/S7500X-CMW710-BOOT-test.bin on slot 0....Done.
Verifying the file flash:/S7500X-CMW710-SYSTEM-test.bin on slot 0............
............Done.
Verifying the file flash:/S7500X-CMW710-FREERADIUS-test.bin on slot 0...Done.
The images that have passed all examinations will be used as the main startup so
ftware images at the next reboot on slot 0.
Decompression completed.
Do you want to delete flash:/S7500X.ipe now? [Y/N]:y
<Sysname>
4 个回答
粉丝:111人 关注:1人
对的。
也可以从已经在设备解压
学道 七段
粉丝:5人 关注:1人
上传后直接指定,然后自解压
自解压,解压完成并校验通过后,这个.IPE文件会提示删除。
指定后会自动解压,无需先解压在指定。
