HPE网卡固件fireware升级
  • 1收藏,2455浏览
网卡:10/25Gb 2-port 631sfp28
817718-B21
机器型号:dl380 gen9
需要固件的下载链接及升级步骤
三条 九段
粉丝:14人 关注:3人
建议确认操作系统,可以使用对应操作系统下的程序升级。如果没有系统,可以使用ilorest方式
HPESC Search Results
粉丝:28人 关注:25人
Software Details - HPE Broadcom NetXtreme-E Firmware Package for BCM5741x adapters | HPE Support
Installation:
Flash the PLDM firmware using any below methods
  1. Flash using iLOrest tool
  2. Flash using Smart Update Manager (SUM).
  3. Flash from iLO GUI
1. To flash this firmware package, use the following iLOrest command.  See http://www.hpe.com/servers/resttool to download the latest version of the iLOrest tool.
localhost OS example:
ilorest flashfwpkg <file_name.fwpkg>
remote example:
ilorest flashfwpkg <file_name.fwpkg> --url <iLO5_IP_Address> -u <iLO5_username> -p <iLO5_password>
2. This firmware package can also be installed with the latest version of Smart Update Manager (SUM).
Supplemental updates for supported ProLiant servers and options can be done by using SUM, which is found on the Service Pack for ProLiant (SPP) ISO.
  • Place the Service Pack for ProLiant on a USB key using the USB Key Creator Utility.
  • Place the desired firmware packages and components to be updated in the directory "\packages" on the USB key.
Update the firmware and software in the usual manner.
Reboot your system for the update to take effect immediately
  • Browse iLO IP using any browser and login using the credential
  • Make sure the PLDM supported adapter is present in the server
  • Go to iLO GUI -> Click on "Firmware and OS software" from left side  -> Click on "Update Firmware" -> Click on "Choose File" and browse to the supported PLDM file -> Then click on "Flash" button.
  • Update status will be show in the Top and a log entry can be seen in Integrated Managenment Log (IML)
  • Reboot the server for the firmware update to take effect.
