路由器文档配置
2022-06-20提问
  • 1收藏,718浏览
不知道这个文档里面都有哪些配置?
可以指教下吗?哪些是必须配的,哪些是不需要的,请大神看下
<MSR830>dis cu
# version 5.20, Release 2513P09
# sysname MSR830
 # domain default enable system
 # dns proxy enable dns server 223.5.5.5
 # telnet server enable
# dar p2p signature-file flash:/p2p_default.mtd
 # ndp enable
 # ntdp enable
 # lldp enable
# cluster enable
# port-security enable
# loopback-detection enable
 # ip http port 8888
 # password-recovery enable
# acl number 2000 rule 100 permit
# vlan 1
# vlan 20
# domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
traffic classifier group_web operator or
traffic classifier group_web_oper operator or
 # traffic behavior behaviorfordeny
 filter deny
 traffic behavior group_web
 traffic-policy group_web
traffic behavior group_web_band
# qos policy PolicyLimitOut
 classifier group_web behavior group_web
 qos policy group_web
 classifier group_web_oper behavior behaviorfordeny
# dhcp server ip-pool vlan1
 network 192.168.1.0 mask 255.255.255.0
 gateway-list 192.168.1.1
 dns-list 222.85.85.85
 expired day 0 hour 2
# dhcp server ip-pool vlan20
 network 192.168.10.0 mask 255.255.255.0
 gateway-list 192.168.10.1
 dns-list 222.88.88.88
# user-group system
 group-attribute allow-guest
 # local-user admin password cipher $c$3$yr9bg5iwlit1RKMxJcYzSiCGHbr469ZbNFXJMw==
 authorization-attribute level 3
 service-type telnet
 service-type web
 # stp enable
# cwmp
 undo cwmp enable
 # interface Cellular0/0
 async mode protocol
 link-protocol ppp
 qos apply policy PolicyLimitOut outbound
# interface NULL0
 # interface Vlan-interface1
 # interface Vlan-interface20
 ip address 192.168.10.1 255.255.255.0
# interface GigabitEthernet0/0
 port link-mode route
 nat outbound 2000
 shutdown
 ip address 120.194.187.23 255.255.255.240
 dns server 211.138.24.66
 dns server 211.138.101.66
# interface GigabitEthernet0/1
 nat outbound
 nat server protocol tcp global 123.160.218.196 any inside 192.168.10.254 any
 ip address 123.160.218.196 255.255.255.192
 dns server 222.88.88.88
 dns server 222.85.85.85
# interface GigabitEthernet0/9
 ip address 1.1.1.1 255.255.255.0
# interface GigabitEthernet0/2
 port link-mode bridge
 port access vlan 20
 # interface GigabitEthernet0/3
 port access vlan 20
# interface GigabitEthernet0/4
# interface GigabitEthernet0/5
 port access vlan 20 loopback-detection enable
# interface GigabitEthernet0/6
 port access vlan 20
# interface GigabitEthernet0/7
 port access vlan 20
 # interface GigabitEthernet0/8
 port access vlan 20
# ip route-static 0.0.0.0 0.0.0.0 GigabitEthernet0/1 123.160.218.193
 ip route-static 172.16.1.0 255.255.255.0 192.168.10.250
# info-center loghost 192.168.1.6
 # dhcp server forbidden-ip 192.168.1.1
 dhcp server forbidden-ip 192.168.10.1
 dhcp server forbidden-ip 192.168.10.254
 dhcp server forbidden-ip 192.168.10.250
 dhcp server forbidden-ip 192.168.1.6
 dhcp server forbidden-ip 192.168.1.233
# dhcp enable
# arp static 192.168.10.247 fcaa-14dc-e572 arp static 192.168.10.238 00e0-4ceb-2154 20 GigabitEthernet0/5
 # ip https enable
 # nms primary monitor-interface GigabitEthernet0/1
# load xml-configuration
# load tr069-configuration
 # user-interface con 0
user-interface tty 13
user-interface vty 0 4
 authentication-mode scheme
# return
粉丝:119人 关注:1人
1、打#的是不需要的
2、接口IP
3、路由
4、NAT
5、QOS
6、DHCP
谢谢
zhiliao_4DdOn0 发表时间:2022-06-20
不客气
叫我靓仔 发表时间:2022-06-20
