交换机S10506 端口VLAN环路
2022-06-23提问
  • 1收藏,1298浏览
%Jun 23 16:03:18:192 2022 SW-HeXin IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet0/0/24 changed to up.
%Jun 23 16:03:18:192 2022 SW-HeXin IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet0/0/24 changed to up.
%Jun 23 16:03:18:930 2022 SW-HeXin LLDP/6/LLDP_CREATE_NEIGHBOR: -MDC=1-Slot=0; Nearest bridge agent neighbor created on port Ten-GigabitEthernet0/0/24 (IfIndex 24), neighbor's chassis ID is 0440-a9e9-79b3, port ID is Ten-GigabitEthernet1/0/25.
%Jun 23 16:03:51:190 2022 SW-HeXin LPDT/4/LPDT_LOOPED: -MDC=1-Slot=0; Loopback exists on Ten-GigabitEthernet0/0/24.
%Jun 23 16:03:51:277 2022 SW-HeXin LPDT/4/LPDT_VLAN_LOOPED: -MDC=1-Slot=0; Loopback exists on Ten-GigabitEthernet0/0/24 in VLAN 201.
%Jun 23 16:03:51:893 2022 SW-HeXin IFNET/3/PHY_UPDOWN: -MDC=1; Physical state on the interface Ten-GigabitEthernet0/0/24 changed to down.
%Jun 23 16:03:51:303 2022 SW-HeXin LPDT/5/LPDT_VLAN_RECOVERED: -MDC=1-Slot=0; Loopback on Ten-GigabitEthernet0/0/24 in VLAN 201 recovered.
%Jun 23 16:03:51:304 2022 SW-HeXin LPDT/5/LPDT_RECOVERED: -MDC=1-Slot=0; Loopback on Ten-GigabitEthernet0/0/24 recovered.
%Jun 23 16:03:51:920 2022 SW-HeXin IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol state on the interface Ten-GigabitEthernet0/0/24 changed to down.
端口两边属于trunk端口,且放通了所有VLAN,同时一台交换机有开启STP功能,一台没有开启STP功能
粉丝:94人 关注:0人
Ten-GigabitEthernet0/0/24 对端设备有环路
可是对端设备只接了三台交换机,而且另外那台交换机日志也没有显示连接其他设备端口有环路。
zhiliao_JOkyea 发表时间:2022-06-23
可能对端没有开启环路检测功能
IT钟点工 发表时间:2022-06-23
%Jun 23 16:47:39:914 2022 WX-HuiJu IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/25 changed to up. %Jun 23 16:47:39:915 2022 WX-HuiJu IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/25 changed to up. %Jun 23 16:47:40:541 2022 WX-HuiJu LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/25 (IfIndex 25), neighbor's chassis ID is 600b-032a-8000, port ID is Ten-GigabitEthernet0/0/24.
粉丝:38人 关注:3人
如何配置IRF的话 看看是不是IRF 没有配置好
把互联接口断开 分段排查 接入交换机开启边缘端口和BPDU保护
