F5000光电转换
  • 1收藏,983浏览
F5000设备是否支持光电转换,直接接光电转换模块起不来.
粉丝:144人 关注:1人
光转电视独立于设备的,纯硬件,起不来进系统检查是否识别
怎么查看有没有识别到?,光模块可以看到收发光,光电转换看什么
proposal 发表时间:2022-07-06
回复proposal:
dis interface x 看下media type里有没有内容,另外可以保持console插着的状态,插拔看日志
叫我靓仔 发表时间:2022-07-06
识别到了的
回复叫我靓仔:
%Jul 6 15:39:28:315 2022 ECL-10F-X04-F5000 OPTMOD/4/MODULE_IN: Ten-GigabitEthernet1/1/3: The transceiver is 1000_BASE_T_AN_SFP. %Jul 6 15:39:28:315 2022 ECL-10F-X04-F5000 OPTMOD/5/TX_ALM_OFF: Ten-GigabitEthernet1/1/3: Tx fault removed. %Jul 6 15:39:28:898 2022 ECL-10F-X04-F5000 OPTMOD/5/RX_ALM_OFF: Ten-GigabitEthernet1/1/3: Rx los removed. %Jul 6 15:41:52:841 2022 ECL-10F-X04-F5000 OPTMOD/4/MODULE_OUT: Ten-GigabitEthernet1/1/3: Transceiver absent. %Jul 6 15:43:49:660 2022 ECL-10F-X04-F5000 OPTMOD/4/MODULE_OUT: Ten-GigabitEthernet1/1/0: Transceiver absent. %Jul 6 15:43:59:542 2022 ECL-10F-X04-F5000 OPTMOD/4/MODULE_IN: Ten-GigabitEthernet1/1/0: The transceiver is 1000_BASE_T_AN_SFP. %Jul 6 15:46:18:234 2022 ECL-10F-X04-F5000 OPTMOD/4/MODULE_OUT: Ten-GigabitEthernet1/1/0: Transceiver absent. %Jul 6 15:46:22:280 2022 ECL-10F-X04-F5000 OPTMOD/4/MODULE_IN: Ten-GigabitEthernet1/1/0: The transceiver is 1000_BASE_T_AN_SFP. Ten-GigabitEthernet1/1/0 Current state: DOWN Line protocol state: DOWN IP packet frame type: Ethernet II, hardware address: 4ce9-e4ae-2810 Description: to-huawei-wangguan Loopback is not set Media type is optical fiber, loopback not set, promiscuous mode set Speed Negotiation, Duplex Negotiation, link type is force link Output flow-control is disabled, input flow-control is disabled 1000Mbps-speed mode, full-duplex mode Link speed type is force link, link duplex type is force link Flow-control is not enabled Maximum frame length: 9216 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 850 MDI type: Automdix Port link-type: Access Tagged VLANs: None Untagged VLANs: 850 Last link flapping: Never Last clearing of counters: Never Peak input rate: 0 bytes/sec, at 00-00-00 00:00:00 Peak output rate: 0 bytes/sec, at 00-00-00 00:00:00 Last 300 second input: 0 packets/sec 0 bytes/sec 0% Last 300 second output: 0 packets/sec 0 bytes/sec 0% Input (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, - throttles 0 CRC, 0 frame, 0 overruns, 0 aborts 0 ignored, - parity errors Output (total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output (normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses Output: 0 output errors, 0 underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions 0 lost carrier, 0 no carrier interface Ten-GigabitEthernet1/1/0 port link-mode bridge description to-huawei-wangguan port access vlan 850 speed 1000 duplex full
回复proposal:
你接PC看看有没有反应
回复叫我靓仔:
一样不行,你试过F5000使用光电转换模块吗?我看到有的设备是不支持的
回复proposal:
那就是不支持了
回复proposal:
你再确认下你手头这个光电模块是好的,也可以多找几个试试
5 个回答
粉丝:17人 关注:1人
看硬件规格和软件版本说明书有没有写适配吧,一般特殊要求都会写在这两个地方。
没看到
Qwj 二段
你的光电转换模块是否匹配
华三华为的都试过了,一样不行
回复proposal:
接口down的吗? 千兆万兆,接到防火墙相应的接口试试
zhiliao_sEUyB 发表时间:2022-07-06
回复proposal:
不行的话接到其他华三设备试试排除下是否是模块及对端问题
粉丝:126人 关注:8人
跟设备关系不大,调整下接口速率和双工,再不行检查模块
调整过了,不行,模块也换过了
F5000 接口支持千兆电口模块,请确定模块是否为原厂模块,非原厂模块可能不识别,如是原厂模块可咨询一下售后,可能是版本限制无法识别。
粉丝:226人 关注:0人
您好,支持的
你试过吗,用千兆华三光电转换有用?
用过啊
无名之辈 发表时间:2022-07-06
