华三无线控制器WX5560H
2022-07-11提问
  • 1收藏,1289浏览
在AC的probe视图下查看:display system internal wlan client history-record mac-address bc9f-ef81-c109   查看该终端下线的reason-code代码
通过命令查看display system internal wlan client history-record help reason-code xxxx     将上一步收集到的代码填入xxxx,查看下线原因
还有什么别的错误代码吗?
粉丝:111人 关注:1人
CodeReason
0Reserved
1Unspecific Reason
2Previous authentication no longer valid
3Deauthenticated because sending STA is leaving (or has left) IBSS or ESS
4Disassociated due to inactivity
5Disassociated because AP is unable to handle all currently associated STAs
6Class 2 frame received from nonauthenticated STA
7Class 3 frame received from nonassociated STA
8Disassociated because sending STA is leaving (or has left) BSS
9STA requesting (re)association is not authenticated with responding STA
10Disassociated because the information in the Power Capability element is unacceptable
11Disassociated because the information in the Supported Channels element is unacceptable
12Reserved
13Invalid information element.
14Message integrity code (MIC) failure
154-Way Handshake timeout
16Group Key Handshake timeout
17Information element in 4-Way Handshake different from (Re)Association Request/Probe Response/Beacon frame
18Invalid group cipher or Association denied due to requesting STA not supporting all of the data rates in the BSSBasicRateSet parameter
19Invalid pairwise cipher
20Invalid AKMP
21Unsupported RSN information element version
22Invalid RSN information element capabilities
23IEEE 802.1X authentication failed
24Cipher suite rejected because of the security policy
25-31Reserved
32Disassociated for unspecified, QoS-related reason
33Disassociated because QoS AP lacks sufficient bandwidth for this QoS STA
34Disassociated because excessive number of frames need to be acknowledged, but are not acknowledged due to AP transmissions and/or poor channel conditions
35Disassociated because STA is transmitting outside the limits of its TXOPs
36Requested from peer STA as the STA is leaving the BSS (or resetting)
37Requested from peer STA as it does not want to use the mechanism
38Requested from peer STA as the STA received frames using the mechanism for which a setup is required
39Requested from peer STA due to timeout
45Peer STA does not support the requested cipher suite
45-65Reserved
535Reserved
您好 可以给下连接吗 ? 我想知道所有的错误代码 因为错误代码报的是5025等
zhiliao_RJDMrS 发表时间:2022-07-11
粉丝:119人 关注:1人
无线客户端下线原因code:
        #define    WMAC_REASON_RES1                        0            保留位,我们系统未使用
常见    #define    WMAC_REASON_UNSPECIFIED                 1            下线原因未描述,属于默认下线原因
        #define    WMAC_REASON_AUTH_EXPIRED                2            认证超时前,未认证成功
常见    #define    WMAC_REASON_AUTH_LEAVING                3            sta主动发送deauth要离开    *****3和8都表示主动离开,3发的是deauth报文,而8是deassication报文
常见    #define    WMAC_REASON_INACTIVE                    4            sta保活超时,AC的动作 idle time-out
        #define    WMAC_REASON_TOOMANY_ASSOC               5            基站资源不足,因此解除连接,我们系统未使用
        #define    WMAC_REASON_CLASS2                      6            处于unauthenticated状态的STA 收到了与当前状态不符的报文
        #define    WMAC_REASON_CLASS3                      7            处于unassociated 状态的STA 收到了与当前状态不符的报文
常见    #define    WMAC_REASON_ASSOC_LEAVING               8            sta处于assoc状态下离开,
