交换机里端口下面没有指定类型,会怎么判断?
2018-09-03提问
  • 1收藏,1733浏览
大家好!interface GigabitEthernet1/0/17至21端口下面没有指定类型,当该接口下接有用户时,会怎么处理数据?
<huiju-12>disp cu
 version 5.20, Release 2220P02
 sysname huiju-12
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 domain default enable system
 telnet server enable
 undo ip http enable
 password-recovery enable
vlan 1
vlan 2 to 21
vlan 1000
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$Wu0o9A+z1Qa6aYjrf/tXCudktNcbqX0EQO1azhgrugDdUQ==
 authorization-attribute level 3
 service-type telnet
interface NULL0
interface Vlan-interface1000
 ip address 172.168.10.13 255.255.255.0
 port access vlan 20
 port access vlan 20
 port access vlan 20
interface GigabitEthernet1/0/4
 port access vlan 20
interface GigabitEthernet1/0/5
 port access vlan 20
interface GigabitEthernet1/0/6
 port access vlan 20
interface GigabitEthernet1/0/7
 port access vlan 20
interface GigabitEthernet1/0/8
 port access vlan 20
interface GigabitEthernet1/0/9
 port access vlan 20
interface GigabitEthernet1/0/10
 port access vlan 20
interface GigabitEthernet1/0/11
 port access vlan 20
interface GigabitEthernet1/0/12
 port access vlan 20
interface GigabitEthernet1/0/13
 port access vlan 20
interface GigabitEthernet1/0/14
 port access vlan 20
interface GigabitEthernet1/0/15
 port access vlan 20
interface GigabitEthernet1/0/16
 port access vlan 20
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
 shutdown
interface GigabitEthernet1/0/23
 port link-type trunk
 port trunk permit vlan all
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
 shutdown
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
 shutdown
 ip route-static 0.0.0.0 0.0.0.0 172.168.10.1
 load xml-configuration
user-interface aux 0
 authentication-mode scheme
user-interface vty 0 4
 user privilege level 3
user-interface vty 5 15
return
<huiju-12>
粉丝:32人 关注:5人
默认在vlan 1里面,如果带tag的报文过来,直接丢弃,不带tag的报文进入vlan 1
zhiliao_FJONg 知了小白
好的,谢谢
