我有1台H3C 5560S-52P-SI,信息如下
Slot 1: Uptime is 0 weeks,0 days,0 hours,44 minutes
S5560S-52P-SI with 1 Processor BOARD TYPE: S5560S-52P-SI
DRAM: 512M bytes FLASH: 256M bytes
PCB 1 Version: VER.A
Bootrom Version: 134
CPLD 1 Version: 001
Release Version: H3C S5560S-52P-SI-6312P03
Patch Version : None
Reboot Cause : UserReboot [SubSlot 0] 48GE+4SFP
<H3C>
我想升级软件版本,但是发现会出错
我直接升到R6335会报错,
错误如下 :
The device type is incorrect! Now rebooting ...
但是下载IPE文件和做交换机启动引导文件的时候,正常解压没有报错
<S5560S-52P-SI>boot-loader file flash:/S5560S_SI-CMW710-R6335.ipe slot 1 main
Verifying the file flash:/S5560S_SI-CMW710-R6335.ipe on slot 1.....Done.
H3C S5560S-52P-SI images in IPE: s5560s_si-cmw710-boot-r6335.bin s5560s_si-cmw710-system-r6335.bin This command will set the main startup software images. Continue? [Y/N]:y
Add images to slot 1. Decompressing file s5560s_si-cmw710-system-r6335.bin to flash:/s5560s_si-cmw710-system-r6335.bin..................................
..........Done.
Decompressing file s5560s_si-cmw710-boot-r6335.bin to flash:/s5560s_si-cmw710-boot-r6335.bin.......Done.
Verifying the file flash:/s5560s_si-cmw710-boot-r6335.bin on slot 1...Done.
Verifying the file flash:/s5560s_si-cmw710-system-r6335.bin on slot 1.....Done.
The images that have passed all examinations will be used as the main startup software images at the next reboot on slot 1.
<S5560S-52P-SI>%Jan 1 02:53:00:062 2013 S5560S-52P-SI PKG/5/PKG_BOOTLOADER_FILE_SUCCESS: -IPAddr=**-User=**: Executed the boot-loader file command successfully
后来我用R6318P01也是一样会报同样的错误.
我看了一下软件升级说明书,书上说要求bootrom version必须143及以上,请问这怎么升级bootrom版本,我在官网下的ZIP文件里面只有2个bin文件和1个ipe文件.
(0)
我今天也升级了同型号的交换机(S5560S-52P-SI),也是升级失败,下载的就是链接内最新的版本R6335,原固件为6126P20。是不是官网的固件有问题?
(0)
把它配成启动文件后,它会频繁重起,显示The device type is incorrect! Now rebooting ...
我清空了所有配置,恢复出厂状态的情况下还是升级不成功,我也不知道该怎么弄了.设备还过了1年保修期.
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
