dhcp-snooping arp detection开启后内网共享问题
2018-09-03提问
  • 1收藏,1668浏览
在S5100交换机做如下的配置后,PC1和PC2的局域网共享文件不正常,是开启DHCP-snooping 和arp detection之后,内网就不能共享文件了吗?
交换机GE1/0/20上联路由器的LAN口,路由器LAN IP 192.168.88.1/24,路由器开启DHCP服务,PC1连交换机的GE1/0/18,PC2连接交换机的GE1/0/19
问题状况是,有时能打开共享文件夹,但是慢,打开共享文件夹后,进行拷贝文件就会断.在终端下显示交换机的上联口即GE1/0/20时断时通,只上外网时一切正常.
如果把交换机恢复出厂配置,就一切正常
H3C]dis cu
sysname H3C
radius scheme system
domain system
vlan 1
vlan 2
arp detection enable
interface Vlan-interface1
interface Aux1/0/0
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
dhcp-snooping trust
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
port access vlan 2
interface GigabitEthernet1/0/11
port access vlan 2
interface GigabitEthernet1/0/12
port access vlan 2
interface GigabitEthernet1/0/13
port access vlan 2
interface GigabitEthernet1/0/14
port access vlan 2
interface GigabitEthernet1/0/15
port access vlan 2
interface GigabitEthernet1/0/16
port access vlan 2
interface GigabitEthernet1/0/17
port access vlan 2
interface GigabitEthernet1/0/18
port access vlan 2
interface GigabitEthernet1/0/19
port access vlan 2
interface GigabitEthernet1/0/20
port access vlan 2
dhcp-snooping trust
arp detection trust
interface GigabitEthernet1/0/21
port access vlan 2
interface GigabitEthernet1/0/22
port access vlan 2
interface GigabitEthernet1/0/23
port access vlan 2
interface GigabitEthernet1/0/24
port access vlan 2
interface GigabitEthernet1/0/25
shutdown
port access vlan 2
interface GigabitEthernet1/0/26
shutdown
port access vlan 2
interface GigabitEthernet1/0/27
shutdown
port access vlan 2
interface GigabitEthernet1/0/28
shutdown
port access vlan 2
interface NULL0
dhcp-snooping
ip route-static 0.0.0.0 0.0.0.0 192.168.88.1 preference 60
user-interface aux 0
user-interface vty 0 4
return
internet--普通路由器--S5100--PC1,PC2
粉丝:32人 关注:5人
那应该是某些终端是静态的IP地址,不是通过DHCP-snooping形成的表项,所以ARP detection检查不通过导致不通。可以手工配置ip-source bin表项,让arp  detection检查通过。
寂东 九段
粉丝:225人 关注:3人
vlan 2 开启 arp detection后,把 18、19口加入arp的信任端口试试
PC1,PC2都是自动获取IP的,不是静态IP
另外,现在发现只上外网时,交换机的1/0/20口也会时通时断,确认网线和路由器都是正常的,因为不对交换机配置DHCP-snooping 和arp detection时,网络一切正常
如果将18.19接口也设为DHCP-SNOOPING TRUST和ARP DETECTION TRUST,那是不是意味着在这两个接口上就没有了ARP防御功能
