AC板卡 QOS封堵6633端口,不生效
2022-07-15提问
  • 1收藏,826浏览
traffic classifier liutong-1 operator or
 if-match acl 3000
traffic classifier lutong-3 operator or
 if-match acl 3001
 traffic behavior liutong-2
 filter permit
 traffic behavior liutong-4
 filter deny
qos policy 1
 classifier liutong-1 behavior liutong-2
 classifier lutong-3 behavior liutong-4 #
acl number 3001
 rule 1 deny tcp destination 61.132.70.195 0 destination-port eq 6633
acl number 3000
 rule 0 permit tcp source 10.114.0.0 0.0.3.255 destination 61.132.70.195 0 destination-port eq 6633
 rule 1 permit tcp source 10.114.4.0 0.0.3.255 destination 61.132.70.195 0 destination-port eq 6633
interface Bridge-Aggregation1
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 4094
 qos apply policy 1 inbound
 dhcp snooping trust
只能使用QOS封堵,VLAN接口下的包过滤,会影响到用户的业务转发
聚合口下调用QOS策略
粉丝:94人 关注:0人
配置有问题,参考
流量过滤配置举例
Host通过接口GigabitEthernet1/0/1接入设备Switch。
配置流量过滤功能,对接口GigabitEthernet1/0/1接收的目的端口号等于21的TCP报文进行丢弃。
图7-1 流量过滤配置组网图
定义高级ACL 3000,匹配目的端口号等于21的数据流。
<Switch> system-view
[Switch] acl advanced 3000
[Switch-acl-ipv4-adv-3000] rule 0 permit tcp destination-port eq 21
[Switch-acl-ipv4-adv-3000] quit
定义类classifier_1,匹配高级ACL 3000。
[Switch] traffic classifier classifier_1
[Switch-classifier-classifier_1] if-match acl 3000
[Switch-classifier-classifier_1] quit
定义流行为behavior_1,动作为流量过滤(deny),对数据包进行丢弃。
[Switch] traffic behavior behavior_1
[Switch-behavior-behavior_1] filter deny
[Switch-behavior-behavior_1] quit
定义策略policy,为类classifier_1指定流行为behavior_1。
[Switch] qos policy policy
[Switch-qospolicy-policy] classifier classifier_1 behavior behavior_1
[Switch-qospolicy-policy] quit
将策略policy应用到端口GigabitEthernet1/0/1的入方向上。
[Switch-GigabitEthernet1/0/1] qos apply policy policy inbound
允许哪些地址可以访问某台设备的6633端口,这个策略应该怎么写
zhiliao_9KJOL 发表时间:2022-07-15
粉丝:144人 关注:0人
您好,taffic 3中缺少配置,加 filter deny
