s5130ei_e-cmw710重启bin文件无效了。。怎么处理
2018-09-05提问
  • 1收藏,2316浏览
Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd. Creation Date : Apr 13 2015, 14:45:33 CPU Clock Speed : 1000MHz Memory Size : 1024MB Flash Size : 512MB CPLD Version : 001 PCB Version : Ver.D Mac Address : 741f4abeda38 Press Ctrl+B to access EXTENDED BOOT MENU...0 Loading the main image files... Loading file flash:/s5130ei_e-cmw710-system-r3109p05.bin........................ ....................................Done. Image file flash:/s5130ei_e-cmw710-system-r3109p05.bin is invalid! Loading the backup image files... The image does not exist! Loading images fails. Loading the main boot and system image files... Loading file flash:/s5130ei_e-cmw710-system-r3109p05.bin........................ .....................................Done. Image file flash:/s5130ei_e-cmw710-system-r3109p05.bin is invalid! Loading the backup boot and system image files... The image does not exist! Loading images fails. Loading the main boot image... Loading file flash:/s5130ei_e-cmw710-boot-r3109p05.bin...........Done. Image file flash:/s5130ei_e-cmw710-boot-r3109p05.bin is self-decompressing...... ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ ................................................................................ .......................................Done.
寂东 九段
粉丝:225人 关注:3人
重启设备,按ctrl+b进入bootrom,看看设备里有没有 cmw710-system-r3109p05.bin这个文件,如果有,是不是主启动文件,如果没有,重新上传,如果不是主启动文件,设置成主启动文件
http://www.h3c.com/cn/Service/Document_Software/Software_Download/Switches/
去这个链接里找你设备所属系列,然后用yx800,密码01230123下载,里边有软件版本说明书,有教你怎么升级版本
粉丝:29人 关注:3人
重新导入一下吧这个系统文件试试,Image file flash:/s5130ei_e-cmw710-system-r3109p05.bin is invalid!
install显示 文件损坏了
zhiliao_70106 发表时间:2018-09-05
zhiliao_70106 知了小白
有什么方法导入吗
