H3C S5830V2&S5820V2 IPv6 over IPv4 GRE隧道典型配置
2018-09-05提问
  • 1收藏,2090浏览
各位好~
    我严格按照配置实例配置,使用相同的组网,设备顺序不一样,发现pcA ping ipv6 不通pcB,到各自ipv6的网关都通,设备1到设备3的ipv6的网关2001::1是通的,设备3到设备1001::1也是通的,求助。
设备1配置:# service-loopback group 1 type tunnel # vlan 10 # vlan 20 # interface Vlan-interface10 5 ip address 192.13.2.2 255.255.255.0 # interface Vlan-interface20 ipv6 address 1001::1/64 # interface Ten-GigabitEthernet1/0/1 port link-mode bridge port access vlan 20 # interface Ten-GigabitEthernet1/0/2 port link-mode bridge port access vlan 10 # interface Ten-GigabitEthernet1/0/3 port link-mode bridge port service-loopback group 1 # interface Tunnel0 mode gre ipv6 address 3001::1/64 source 192.13.2.2 destination 131.108.5.2 # ip route-static 131.108.5.2 255.255.255.0 192.13.2.1 # ipv6 route-static 2001:: 64 Tunnel 0
设备2配置:vlan 10 to 11 # interface Vlan-interface10 ip address 192.13.2.1 255.255.255.0 # interface Vlan-interface11 ip address 131.108.5.1 255.255.255.0 # interface Ten-GigabitEthernet1/0/1 port link-mode bridge port access vlan 10 # interface Ten-GigabitEthernet1/0/2 port link-mode bridge port access vlan 11 #
设备三配置:service-loopback group 1 type tunnel # vlan 11 # vlan 20 # interface Vlan-interface11 ip address 131.108.5.2 255.255.255.0 # interface Vlan-interface20 ipv6 address 2001::1/64 # interface Ten-GigabitEthernet1/0/1 port link-mode bridge port access vlan 20 # interface Ten-GigabitEthernet1/0/2 port link-mode bridge port access vlan 11 # 6 interface Ten-GigabitEthernet1/0/3 port link-mode bridge port service-loopback group 1 # interface Tunnel0 mode gre ipv6 address 3001::2/64 source 131.108.5.2 destination 192.13.2.2 # ip route-static 192.13.2.2 255.255.255.0 131.108.5.1 # ipv6 route-static 1001:: 64 Tunnel 0
粉丝:29人 关注:3人
老哥,这个问题有点复杂,还要看转发表项等。建议收集故障时候诊断信息拨打400求助可能更快解决。
zhiliao_c489l 知了小白
这个是在实验环境下做的,HCL模拟器做的实验,ipv6 over ipv4 gre 实例,一模一样做的,结果pca ping ipv6 不通pcb,ipv6路由表也检查了,也是不可以。
