三层交换机登录要密码区别?
2018-09-07提问
  • 1收藏,1137浏览
大家好,以下两个交换机配置,A交换机进console要账号密码,B交换机进console不需要账号密码,下面命令区别在哪儿?
A交换机配置如下:
<sitang_jifang>disp cu
 sysname sitang_jifang
radius scheme system
domain system
local-user admin
 password cipher FS;$C300X+VHV_57`0MIPQ!!
 service-type telnet
 level 3
vlan 1
vlan 3 to 20
vlan 50
vlan 100
vlan 1000
interface Vlan-interface1
interface Vlan-interface1000
 ip address 172.168.10.53 255.255.255.0
interface Aux1/0/0
interface Ethernet1/0/1
 port access vlan 20
interface Ethernet1/0/2
 port access vlan 20
interface Ethernet1/0/3
 port access vlan 19
interface Ethernet1/0/4
interface Ethernet1/0/5
interface Ethernet1/0/6
interface Ethernet1/0/7
interface Ethernet1/0/8
interface Ethernet1/0/9
interface Ethernet1/0/10
interface Ethernet1/0/11
interface Ethernet1/0/12
interface Ethernet1/0/13
interface Ethernet1/0/14
interface Ethernet1/0/15
interface Ethernet1/0/16
interface Ethernet1/0/17
interface Ethernet1/0/18
interface Ethernet1/0/19
interface Ethernet1/0/20
interface Ethernet1/0/21
interface Ethernet1/0/22
interface Ethernet1/0/23
interface Ethernet1/0/24
 port link-type trunk
 port trunk permit vlan all
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
 undo irf-fabric authentication-mode
interface NULL0
 voice vlan mac-address 0001-e300-0000 mask ffff-ff00-0000
 ip route-static 0.0.0.0 0.0.0.0 172.168.10.1 preference 60
user-interface aux 0
 authentication-mode scheme
user-interface aux 1 7
user-interface vty 0 4
 user privilege level 3
return
<sitang_jifang>
<sitang_jifang>
B交换机配置如下:
Username:admin
Password:
<huiju-4>
<huiju-4>
<huiju-4>disp cu
 version 5.20, Release 2220P02
 sysname huiju-4
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 domain default enable system
 telnet server enable
 undo ip http enable
 password-recovery enable
vlan 1
vlan 2 to 20
vlan 50
vlan 100
vlan 1000
domain system
 access-limit disable
 state active
 idle-cut disable
 self-service-url disable
user-group system
 group-attribute allow-guest
local-user admin
 password cipher $c$3$yQQ7JjpoNJfm6zGTUCccFQ4Y5Pjt7Zwz
 authorization-attribute level 3
 service-type telnet
interface Bridge-Aggregation1
 port access vlan 100
interface Bridge-Aggregation2
interface NULL0
 ip address 172.168.10.5 255.255.255.0
 port access vlan 6
 port access vlan 6
 port access vlan 6
interface GigabitEthernet1/0/4
 port access vlan 6
interface GigabitEthernet1/0/5
 port access vlan 6
interface GigabitEthernet1/0/6
 port access vlan 6
interface GigabitEthernet1/0/7
 port access vlan 6
interface GigabitEthernet1/0/8
 port access vlan 6
interface GigabitEthernet1/0/9
 port access vlan 6
interface GigabitEthernet1/0/10
 port access vlan 6
interface GigabitEthernet1/0/11
 port access vlan 50
interface GigabitEthernet1/0/12
 port access vlan 50
interface GigabitEthernet1/0/13
 port access vlan 4
interface GigabitEthernet1/0/14
 port access vlan 4
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
 port link-aggregation group 1
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
 port link-aggregation group 2
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
 shutdown
interface GigabitEthernet1/0/25
 shutdown
interface GigabitEthernet1/0/26
 port access vlan 6
interface GigabitEthernet1/0/27
 shutdown
interface GigabitEthernet1/0/28
 shutdown
 load xml-configuration
 set authentication password cipher $c$3$Hd8Ui+angmAM+Bo63Qgzn8UIFYDmuyOUXg==
user-interface vty 5 15
return
<huiju-4>
粉丝:19人 关注:0人
A的配置里,在Aux用户线视图下(console的用户线),有指定认证模式是本地认证,如果这时再配置了本地用户,则需要console用户名密码才可进入,而B的没有
寂东 九段
粉丝:225人 关注:3人
默认情况下,control口是不需要密码的,登录consol口需要密码,进入consol口设置验证类型和密码:
user-interface con 0
authentication-mode password
set authentication password simple xxxx
