有一台cisco2800的设备需要更换为华三RT-MSR3640
2022-09-12提问
  • 0收藏,1192浏览
粉丝:0人 关注:5人
#密码 Fcrou925 .Jul 13 14:53:15: %SYS-5-CONFIG_I: Configured from console by console erchang#show run Building configuration... Current configuration : 4110 bytes ! !
 Last configuration change at 14:53:15 beijing Wed Jul 13 2022 !
NVRAM config last updated at 09:31:59 beijing Tue Aug 7 2018 by wanggt !
version 12.4
 service timestamps debug datetime msec
service timestamps log datetime localtime
 service password-encryption
boot-start-marker boot system flash c2800nm-advsecurityk9-mz.124-22.T.bin boot-end-marker !
 logging message-counter syslog
logging buffered 1000000
enable secret 5 $1$iNPH$cZ9q0YZXl7mpbZ.hWF85e1
enable password 7 06121C2842491D180A !
 aaa new-model ! ! aaa authentication login ssh local !
 ! aaa session-id common clock timezone beijing 8 ! dot11 syslog ip source-route !
 ! ip cef !
! no ip domain lookup ip domain name ***.*** !
 multilink bundle-name authenticated !
! ! key chain Tsingta0_2012 key 10 key-string 7 09785D00170203135B33567A7A76 ! !
! crypto isakmp policy 2 hash md5 authentication pre-share crypto isakmp key keyforqingpi address 0.0.0.0 0.0.0.0 !
! crypto ipsec transform-set to_zhongxin esp-des esp-md5-hmac mode transport ! crypto ipsec profile vpn set transform-set to_zhongxin ! !
! ip ssh time-out 30 !
! ! interface Loopback1314
 no ip address
! interface Tunnel0 ip address 172.30.255.5 255.255.255.0
 no ip redirects ip mtu 1400
 ip authentication mode eigrp 100 md5
 ip authentication key-chain eigrp 100 Tsingta0_2012
 ip nhrp authentication dmvpn
 ip nhrp map multicast 10.220.2.14
 ip nhrp map 172.30.255.6 10.220.2.14
 ip nhrp network-id 10
 ip nhrp holdtime 300
 ip nhrp nhs 172.30.255.6 delay 1000
 shutdown
 tunnel source GigabitEthernet0/0 tunnel mode gre multipoint tunnel key 12345 !
interface GigabitEthernet0/0
 description QD-MSTP-erchang
 ip address 172.18.2.2 255.255.255.248
 ip ospf authentication message-digest
 ip ospf message-digest-key 1 md5 7 113D0A0C19151F0D541579747961
 duplex full speed auto !
interface GigabitEthernet0/1
ip address 172.18.100.254 255.255.255.0
 ip flow ingress
router eigrp 100 redistribute static
 network 2.2.2.0 0.0.0.255
 network 172.18.0.0
 network 172.30.255.0 0.0.0.255
 network 192.168.1.0
 no auto-summary
 no eigrp log-neighbor-changes
! router ospf 100 router-id 172.18.2.2
 log-adjacency-changes
 area 9002
authentication message-digest redistribute static subnets route-map redis network 10.100.8.0 0.0.7.255
 area 9002
 network 172.18.2.0 0.0.0.255
area 9002
 network 172.18.100.0 0.0.0.255
area 9002 !
 ip forward-protocol nd
ip route 10.0.0.0 255.0.0.0 10.232.0.193
ip route 10.100.8.0 255.255.248.0 172.18.100.252
 ip route 192.168.1.0 255.255.255.0 172.18.100.253
ip route 192.168.2.0 255.255.255.0 172.18.100.253
 no ip http server ip http access-class 23
ip http authentication local
 no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000 !
ip flow-export version 5
 ip flow-export destination 172.18.100.6 65535 !
! logging trap notifications logging facility local1 logging source-interface GigabitEthernet0/1
logging 172.16.1.239
 logging 172.16.1.31
 access-list 10 permit 10.100.8.0 0.0.7.255
snmp-server community Pubtsin9 RO
snmp-server community Precisc0 RW snmp-server enable traps tty ! ! !
 route-map redis permit 10 match ip address 10 ! ! !
 control-plane ! ! line con 0 password 7 105A1A100B10060A03 logging synchronous line aux 0 line vty 0 4
 exec-timeout 0 0
 password 7 0030160A075218055F logging synchronous login authentication ssh transport input ssh line vty 5 15
 exec-timeout 0 0 password 7 0030160A075218055F
line vty 16 988
 transport input ssh !
 scheduler allocate 20000 1000
 ntp server 172.16.1.61
 end
粉丝:19人 关注:3人
基本都是简单的配置个IP、日志主机、snmp还有一点OSPF,不确定里面有没有用eigrp,不过eigrp是思科私有的,也没有办法换成华三
有没有 搬迁的工具 把思科的转为华三命令
zhiliao_WHEXUE 发表时间:2022-09-12
我没有用过,可能有吧,但是你想接口编号啥的也都不一样,一般都是看看思科这个命令是什么意思,然后去查华三的命令
求求给个采纳 发表时间:2022-09-12
zhiliao_2NBFfK 知了小白
你这是个假网工吧
粉丝:150人 关注:1人
1、syslog配置
2、snmp配置
3、静态路由配置
4、0/0口去往二厂“erchang”的专线配置+OSPF配置
==========“1-4”是可以直接翻译的,很简单,没啥特殊的===========
5、0/1到内部的ERIGRP路由协议是思科私有的,H3C不支持,可以沟通使用静态代替或者其它路由协议
NHRP的tunnel配置是失效的,可以不用管,这个大概率是以前没有专线,后来拉了专线就不用了
