HCL启动设备失败
2022-09-15提问
  • 0收藏,2408浏览
新下载的HCL软件,安装正常,单添加一个主机就启动失败
日志:
2022-09-15 10:40:26,266 - ERROR: PopWindow_PopNewProject 2022-09-15 10:40:42,238 - INFO: Check the project name: 1 2022-09-15 10:40:42,241 - INFO: Check the project is open: f:\1\1 2022-09-15 10:40:42,795 - INFO: Send normal_close to the simware server, closeEvent: False 2022-09-15 10:40:42,986 - INFO: Workspace 1204 HCL - 1 [f:\1\1] 2022-09-15 10:40:42,986 - INFO: Workspace 1205 f:\1\1\***.*** 2022-09-15 10:40:42,989 - INFO: Create the topology now for the path f:\1\1 2022-09-15 10:40:42,993 - INFO: Simware server set the base UDP port(10000) 2022-09-15 10:40:43,006 - INFO: Workspace--createignoreFile sourignorePath---- .\.gitignore 2022-09-15 10:40:43,018 - INFO: NETFile::__init__() 2022-09-15 10:40:43,018 - INFO: ('NETFile.py: export_net_file() dynagen.running_cOnfig= ', ConfigObj({'vbox 127.0.0.1:16600': {'workingdir': None, 'udp': 10000}})) 2022-09-15 10:40:43,018 - INFO: ('NETFile.py: writing... dynagen.running_cOnfig= ', ConfigObj({'version': '5.1.0', 'vbox 127.0.0.1:16600': {'workingdir': None, 'udp': 10000}})) 2022-09-15 10:40:47,049 - INFO: Try to create the simware slot(PC_1,1,0,PC,512,{0:(None,None),1:(3,'GE_0/1')}) 2022-09-15 10:40:47,375 - WARNING: Dynagen::_update_running_config_for_simware_device(<GNS3.Dynagen.simware_lib.SimwareVBox object at 0x00000249580C1310>, <GNS3.Dynagen.simware_lib.LIB_VirtualPC object at 0x000002495A2D2E50>, False) 2022-09-15 10:40:47,375 - WARNING: Dynagen::_update_running_config_for_simware_adapter(vbox 127.0.0.1:16600, PC PC_1, <GNS3.Dynagen.simware_lib.BaseSlot object at 0x0000024900130D60>)
kH23EEC 知了小白
软件名称:HCL_Setup_V5.1.0
粉丝:126人 关注:8人
HCL安装完成后,启动HCL,启动设备报错,提示:“设备启动失败
1) 主要是VirtualBox关闭时出现残留导致的,同问题5:清除设备残留结束掉vBoxSVC.exe进程,再重新打开HCL问题即可解决。
2) VirtualBox版本过低。
任务管理器里没有vBoxSVC.exe进程,VirtualBox从官网下新的也没用
kH23EEC 发表时间:2022-09-15
回复kH23EEC:
设置兼容win 7 运行,更换virtual box 版本,试下4.2.24或5.1.30,;
zhiliao_sEUyB 发表时间:2022-09-15
