H3C路由器配置后无法通过DHCP获取IP地址,手动就可以上网
2022-09-23提问
  • 0收藏,2875浏览
绱君 零段
H3C路由器配置后无法通过DHCP获取IP地址,手动就可以上网,不记得型号,以下是配置参数,由于没有WEB界面,无法核实配置是否合理
version 5.20, Release 2514P14
 sysname H3C
 nat address-group 1
 address 192.168.1.1 192.168.1.254
 domain default enable system
 dar p2p signature-file flash:/p2p_default.mtd
 port-security enable
 undo ip http enable
 password-recovery enable
acl number 2000
 rule 0 permit
 rule 5 permit source 192.168.1.0 0.0.0.255
vlan 1
 vlan 100
domain system
access-limit disable
state active
idle-cut disable
self-service-url disable
dhcp server ip-pool 100 extended
network ip range 192.168.1.2 192.168.1.254
gateway-list 192.168.1.1
dns-list 211.138.240.100 211.138.245.180
user-group system
group-attribute allow-guest
local-user admin
password cipher $c$3$40gC1cxf/wIJNa1ufFPJsjKAof+QP5aV
 authorization-attribute level 3
 service-type telnet
cwmp
 undo cwmp enable
interface Aux0
 async mode flow
 link-protocol ppp
interface Cellular0/0
 async mode protocol
 link-protocol ppp
interface NULL0
interface Vlan-interface100
 dhcp server apply ip-pool 100
interface GigabitEthernet0/0
 port link-mode route
 nat outbound 2000
 ip address 192.168.137.2 255.255.255.0
interface GigabitEthernet0/1
 interface GigabitEthernet0/2
 port link-mode bridge
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
 port access vlan 100
 speed 1000
 stp disable
interface GigabitEthernet0/9
ip route-static 0.0.0.0 0.0.0.0 192.168.137.1
 dhcp enable
 load xml-configuration
 load tr069-configuration
user-interface tty 12
user-interface aux 0
user-interface vty 0 4
 authentication-mode scheme
return
粉丝:1人 关注:1人
终端无法从我们设备上获取地址?建议终端和我们设备同时抓包看下dhcp的报文,我们是否正常应答dhcp报文
接口没有应答客户电脑的数据,如下图:
绱君 发表时间:2022-09-24
没有dhcp报文到G0/8口
绱君 发表时间:2022-09-24
61 412.708689 0.0.0.0 255.255.255.255 DHCP 342 DHCP Discover - Transaction ID 0xfd79b17c
绱君 发表时间:2022-09-24
在G0/8抓到了这样的数据包,请问是dhcp的广播吗?为什么会获取不到呢
绱君 发表时间:2022-09-24
绱君 知了小白
粉丝:35人 关注:7人
无法通过DHCP自动获取IP地址,以下是排查要点,请参考:
1、检查DHCP功能是否已经使能。
2、检查DHCP内的IP地址是否和VLAN或接口的IP地址在同一个子网内。
3、检查DHCP内的IP地址是否足够使用。
4、检查终端接入的端口是否划分到了相应的VLAN中。
