IMC portal认证,像设备发送请求超时
2022-09-24提问
  • 0收藏,815浏览
IMC服务器,认证测试设备,无线控制器三方的路由都是正常可达,中间没有安全设备,
我把认证起在虚接口下面,确认配对密钥和IMC侧一致
# interface Vlan-interface2000
ip address 192.168.233.254 255.255.255.0
 portal enable method direct
 portal domain mac-portal
 portal bas-ip 192.168.233.254
 portal apply web-server mac-portal
 portal apply mac-trigger-server mtc #
 portal free-rule 0 source ip any destination ip 218.108.248.0 255.255.255.0
 portal free-rule 1 source ip any destination ip 202.101.172.46 255.255.255.255
 portal free-rule 2 source ip any destination ip 114.114.114.114 255.255.255.255
 portal free-rule 3 source ip any destination ip 218.208.248.200 255.255.255.255
 portal free-rule 4 source ip any destination ip 10.0.1.2 255.255.255.255
 portal free-rule 5 source ip any destination ip 223.5.5.5 255.255.255.255
 portal free-rule 6 source ip any destination ip 192.168.8.156 255.255.255.255 #
 portal web-server mac-portal
 url http://192.168.8.156:8080/portal/
portal server mac-portal
portal mac-trigger-server enable
 ip 192.168.8.156 key cipher $c$3$lK7yiSD/KdFbX0tXAD6xkk+t7NTdU8c=
portal mac-trigger-server mtc ip 192.168.8.156 #
# radius scheme mac-portal
 primary authentication 192.168.8.156
 primary accounting 192.168.8.156
 key authentication cipher $c$3$Dbd19eG3leRFGHjk7TEEzpAfn5AqXac=
 key accounting cipher $c$3$9F8bRJla/MNE2Pb2E/cFZmLHBCJTKG8=
 user-name-format without-domain nas-ip 172.16.1.252
radius dynamic-author server
 client ip 192.168.8.156 key cipher $c$3$ZDkS5+fNgX1CJE05Iul8S2EvV5wmFwI=
domain name mac-portal
 authentication lan-access radius-scheme mac-portal
 authorization lan-access radius-scheme mac-portal
 accounting lan-access radius-scheme mac-portal
无线控制器旁挂在核心上,IMC服务器也接在核心是,用户网关在无线控制器,IMC网关在核心,两边路由是通的
paner 九段
粉丝:33人 关注:3人
这个案例比较多,可以参考下:
https://zhiliao.h3c.com/Theme/details/4812
https://zhiliao.h3c.com/Theme/details/8838
https://zhiliao.h3c.com/Theme/details/105211
粉丝:2人 关注:3人
可以确认Portal设备上配置的协议版本是否为iMC或Portal 2.0,一般无特殊情况不要配置成CMCC
这个要怎么确认
zhiliao_znvJL 发表时间:2022-09-24
可以看一下imc上接入策略管理-portal服务管理-设备配置里的高级信息里的版本
shenqi0704 发表时间:2022-09-24
回复shenqi0704:
确认配置的是portal 2.0
粉丝:126人 关注:8人
“向设备发送请求超时”为portal服务器给终端的错误提示。发生场景portal服务器将报文发送设备后,设备无回应报文。这里的设备就是做portal认证的网络设备。有几种可能。
1.  Portal服务器与设备通信异常。通信报文为UDP报文,服务器侧IPPortal服务器地址,端口为50100;设备侧未指定时,IP默认为网关IP(可在接口下配置“portal nas-ip”指定),端口默认为2000。可先检查配置和排查网络。
2.  设备收到portal服务器报文,并发起radius认证,但是radius服务器无回应。Radius报文为UDP报文,其中源地址可在对应radius scheme下配置nas-ip指定,默认为设备上最接近radius服务器的接口IP,源端口不定。目的地址为radius scheme中配置的地址,应该为radius服务器的地址,目的端口为1812(认证)、1813(计费)。
可通过设备收集信息、服务器抓包的方式确认设备发包和服务器收包的情况。若服务器未收到报文,排查设备配置和网络。若服务器收到报文不回应,排查radius服务器配置和状态。
服务器侧通常的原因有
1)未添加接入设备。查看“用户>接入策略管理>接入设备管理>接入设备配置”。其中必须有以radius报文源地址IP添加的设备。
2Radius服务器,认证端口1812被占用或异常。正常情况为此时可以通过如下命令确认:netstat –aon | findstr 1812,(linux系统netstat –apn |grep 1812)现场只需要将占用UDP 1812的进程杀掉即可。
1、若网络通信问题,检查设备配置排查网络环境。
2、若服务器问题,检查接入设备配置,查看服务器端口状态。
