WX5560H本地转发多业务vlan,如果创建vlan-group,map文件怎么配置?
2022-09-27提问
  • 0收藏,483浏览
一共有100-107八个业务vlan,管理VLAN是4000;AP是WA6330,WA6320H两种,AP均手工配置,下发两个MAP文件,以下是我准备灌入AC的预配:
AC配置:
vlan-group A
vlan-list 100 to 107
wlan service-template 1
 ssid BJKJDX
 client forwarding-location ap vlan 100 to 107
 client vlan-alloc static
 akm mode psk
 cipher-suite ccmp
 security-ie rsn
 preshared-key pass-phrase cipher Admin@123456
 bss transition-management enable
 bss transition-management disassociation recommended timer 45
wlan ap-group default-group
 vlan 1
 rrop anti-bmc network ipv4-and-ipv6-simple enable
 rrop anti-bmc default-action deny
 ap-model WA6320H
 map-configuration cfa0:/6320H.txt
 radio 1
 max-power 15
 radar-detect disable
 sacp anti-sticky enable rssi 25 interval 2 forced-logoff
service-template 1 vlan-group A
 radio 2 max-power 12
 rate mandatory 11 rate supported 12 18 24 36 48 54
 rate disabled 1 2 5.5 6 9
 gigabitethernet 1
 gigabitethernet 2
 gigabitethernet 3
 gigabitethernet 4
 gigabitethernet 5
 ap-model WA6330
 map-configuration cfa0:/6330.txt
 radio 1
 max-power 15
 channel band-width 20
 radio 2
 max-power 15
 radio 3
 max-power 12
 rate mandatory 11
gigabitethernet 1
smartrate-ethernet 1
MAP文件如下,WA6330类似于WA6320H:
vlan 100
vlan 101
vlan 102
vlan 103
vlan 104
vlan 105
vlan 106
vlan 107
vlan 4000
 # interface GigabitEthernet1/0/2
 # interface Smartrate-Ethernet1/0/1
 port link-type trunk
 port trunk permit vlan 100 to 107 4000
 port-isolate enable
 user-isolation vlan 100 permit-mac XXXX-XXXX-XXXX
user-isolation vlan 100 enable
user-isolation vlan 101 permit-mac XXXX-XXXX-XXXX
user-isolation vlan 101 enable
user-isolation vlan 102 permit-mac XXXX-XXXX-XXXX
user-isolation vlan 102 enable
user-isolation vlan 103 permit-mac XXXX-XXXX-XXXX
user-isolation vlan 103 enable
user-isolation vlan 104 permit-mac XXXX-XXXX-XXXX
user-isolation vlan 104 enable
user-isolation vlan 105 permit-mac XXXX-XXXX-XXXX
user-isolation vlan 105 enable
user-isolation vlan 106 permit-mac XXXX-XXXX-XXXX
user-isolation vlan 106 enable
user-isolation vlan 107 permit-mac XXXX-XXXX-XXXX
user-isolation vlan 107 enable
手工配置AP:
WA6330
wlan ap s-westclou-2f-n1 model WA6330
serial-id 219801A23V8221XXXXX
map-configuration 6330.txt
radio 1
 radio enable
 channel 36 y
radio 2
 radio enable
channel 149 y
radio 3
 radio enable
channel 1
WA6320H
wlan ap s-westblou-106-1 model WA6320H
serial-id 219801A297821BXXXXX
map-configuration 6320H.txt
radio 1
radio enable
channel 36
radio 2
radio enable
channel 1
大佬们这个配置是否可行?求助求助
粉丝:39人 关注:3人
可以,就是map里写上所有的业务vlan并放通
