<ttxs_Core>dis interface GigabitEthernet1/3/0/32 GigabitEthernet1/3/0/26 Current state: UP Line protocol state: UP IP packet frame type: Ethernet II, hardware address: 7cde-7835-a600 Description: To jtgs Bandwidth: 1000000 kbps Loopback is not set Media type is optical fiber, port hardware type is 1000_BASE_LX_SFP 1000Mbps-speed mode, full-duplex mode Link speed type is autonegotiation, link duplex type is autonegotiation Flow-control is not enabled Maximum frame length: 9216 Allow jumbo frames to pass Broadcast max-ratio: 100% Multicast max-ratio: 100% Unicast max-ratio: 100% PVID: 666 MDI type: Automdix Port link-type: Access Tagged VLANs: None Untagged VLANs: 666 Port priority: 0 Last link flapping: 3 days 23 hours 35 minutes Last clearing of counters: Never Current system time:2022-09-29 09:55:13 Last time when physical state changed to up:2022-09-25 10:19:53 Last time when physical state changed to down:2022-09-25 10:19:28 Peak input rate: 2557115 bytes/sec, at 2022-09-28 21:03:32 Peak output rate: 7005121 bytes/sec, at 2022-09-28 17:35:43 Last 300 seconds input: 3125 packets/sec 1342610 bytes/sec 1% Last 300 seconds output: 5595 packets/sec 6968520 bytes/sec 6% Input (total): 1135795478 packets, 564198170794 bytes 1135534803 unicasts, 88695 broadcasts, 171980 multicasts, 0 pauses Input (normal): 1135795478 packets, - bytes 1135534803 unicasts, 88695 broadcasts, 171980 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, 0 throttles 0 CRC, 0 frame, - overruns, 0 aborts - ignored, - parity errors Output (total): 1913291103 packets, 2287305080117 bytes 1913073115 unicasts, 45 broadcasts, 217943 multicasts, 0 pauses Output (normal): 1913291103 packets, - bytes 1913073115 unicasts, 45 broadcasts, 217943 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions 0 lost carrier, - no carrier IPv4 traffic statistics: Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec Input: 0 packets, 0 bytes Output: 0 packets, 0 bytes IPv6 traffic statistics: Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec Input: 0 packets, 0 bytes Output: 0 packets, 0 bytes
这是我一个三层交换机的端口信息 他是管数视频数据上传的,图像都正常
从这个看 数据正常Input (total): 1135795478 packets, 564198170794 bytes 1135534803 unicasts, 88695 broadcasts, 171980 multicasts, 0 pauses Input (normal): 1135795478 packets, - bytes 1135534803 unicasts, 88695 broadcasts, 171980 multicasts, 0 pauses Input: 0 input errors, 0 runts, 0 giants, 0 throttles 0 CRC, 0 frame, - overruns, 0 aborts - ignored, - parity errors Output (total): 1913291103 packets, 2287305080117 bytes 1913073115 unicasts, 45 broadcasts, 217943 multicasts, 0 pauses Output (normal): 1913291103 packets, - bytes 1913073115 unicasts, 45 broadcasts, 217943 multicasts, 0 pauses Output: 0 output errors, - underruns, - buffer failures 0 aborts, 0 deferred, 0 collisions, 0 late collisions 0 lost carrier, - no carrier
为什么 IPv4 traffic statistics: Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec Input: 0 packets, 0 bytes Output: 0 packets, 0 bytes 都是0呢?
这 Input 、Output和 IPv4 traffic statistics: 有什么区别? 看数据流量正不正常 看那一个? 谢谢!
(0)
<Sysname> display interface gigabitethernet 1/0/1
GigabitEthernet1/0/1
Current state: DOWN
Line protocol state: DOWN
IP packet frame type: Ethernet II, hardware address: 000c-2963-b767
Description: GigabitEthernet1/0/1 Interface
Bandwidth: 100000 kbps
Loopback is not set
Media type is twisted pair, port hardware type is 1000_BASE_T_AN_SFP
Allow jumbo frame to pass
Unknown-multicast max-ratio: 100%
PVID: 1
MDI type: Automdix
Tagged VLANs: None
UnTagged VLANs: 1
Port priority: 2
Last link flapping: 6 hours 39 minutes 25 seconds
Last clearing of counters: 14:34:09 Tue 11/01/2011
Current system time:2019-01-08 14:50:06
Last time when physical state changed to up:2019-01-08 14:49:45
Last time when physical state changed to down:2019-01-08 14:49:45
Last 300 seconds input: 0 packets/sec 0 bytes/sec -%
Last 300 seconds output: 0 packets/sec 0 bytes/sec -%
Input (total): 0 packets, 0 bytes
Input (normal): 0 packets, 0 bytes
0 CRC, 0 frame, 0 overruns, 0 aborts
0 ignored, 0 parity errors
Output (normal): 0 packets, 0 bytes
Output: 0 output errors, 0 underruns, 0 buffer failures
0 lost carrier, 0 no carrier
表1-2 display interface命令显示信息描述表
字段 | 描述 |
GigabitEthernet1/0/1 | 接口GigabitEthernet1/0/1的相关信息 |
Current state | 接口的物理状态,状态可能为: · Administratively DOWN:表示该接口已经通过shutdown命令被关闭,即管理状态为关闭 · DOWN:表示该接口的管理状态为开启,但物理状态为关闭(可能因为没有物理连线或者线路故障) · DOWN ( Link-Aggregation interface down ):表示该接口所属的聚合接口已经通过shutdown命令被关闭 · STP DOWN:表示接口由于触发了STP BPDU保护而自动关闭 · UP:该端口的管理状态和物理状态均为开启 |
Line protocol state | 接口的链路层协议状态。其值由链路层经过参数协商决定,取值为: · UP:表示数据链路层协议状态为开启 · UP(spoofing):表示该接口的数据链路层协议状态为开启,但实际可能没有对应的链路,或者所对应的链路不是永久存在而是按需建立。通常NULL、LoopBack等接口会具有该属性 · DOWN:表示数据链路层协议状态为关闭 · DOWN(protocols):表示接口的数据链路层被协议模块关闭。protocols为LAGG等组合: ¡ LAGG:表示聚合接口中没有选中的成员端口而关闭接口的数据链路层 |
Description | 接口的描述信息 |
Bandwidth | 接口的期望带宽 |
Internet protocol processing | 接口未配置IP地址时,接口的网络协议配置参数: · Disabled:不能处理IP报文 · Enabled:可以处理IP报文 |
Internet address: ip-address/mask-length (Type) | 接口IP地址。Type表示地址获取方式,取值如下: · Primary:手动配置的主地址 · Sub:手动配置的从地址。当配置了主地址时,仅显示主地址;仅配置从地址时,才显示本信息 · DHCP-allocated:通过DHCP获取的IP地址,详细介绍请参见“网络互通”中的“DHCP” · BOOTP-allocated:通过BOOTP获取的IP地址,详细介绍请参见“网络互通”中的“DHCP” · Unnumbered:借用其他接口的IP地址 |
IP packet frame type | IPv4报文发送帧格式 |
hardware address | 接口的MAC地址 |
IPv6 packet frame type | IPv6报文发送帧格式 |
Media type is | 接口的介质类型 |
Port hardware type is | 接口的硬件类型 |
Port priority | 接口优先级 |
Loopback is set internal | 以太网接口正在进行对内环回测试,该显示信息与用户的配置有关 |
Loopback is set external | 对以太网接口进行对外环回测试,该显示信息与用户的配置有关 |
Loopback is not set | 接口上未配置环回测试,该显示信息与用户的配置有关 |
100Mbps-speed mode | 接口速率为100Mbps,该显示信息与用户的配置以及链路参数的协商结果有关 |
1000Mbps-speed mode | 接口速率为1000Mbps,该显示信息与用户的配置以及链路参数的协商结果有关 |
10Gbps-speed mode | 接口速率为10Gbps,该显示信息与用户的配置以及链路参数的协商结果有关 |
Unknown-speed mode | 速率未知,可能因为速率协商失败或者接口物理未连通 |
half-duplex mode | 接口工作在半双工模式,该显示信息与用户的配置以及链路参数的协商结果有关 |
full-duplex mode | 接口工作在全双工模式,该显示信息与用户的配置以及链路参数的协商结果有关 |
unknown-duplex mode | 未知双工模式,可能因为双工模式协商失败或者接口物理未连通 |
Link speed type is autonegotiation | 当用户配置了speed auto时显示该信息 |
Link speed type is force link | 当用户使用speed命令配置了具体的速率时显示该信息,例如1000M等 |
link duplex type is autonegotiation | 当用户配置了duplex auto时显示该信息 |
link duplex type is force link | 当用户使用duplex命令配置了具体的双工模式时显示该信息,例如half或者full |
Maximum frame length | 接口允许通过的最大以太网帧长度 |
Allow jumbo frame to pass | 允许长帧通过 |
PVID | 接口所在的缺省VLAN ID |
Port link-type | 链路类型,取值为access、trunk或hybrid,与用户的配置有关 |
Tagged VLANs | 通过该接口后携带Tag的VLAN |
UnTagged VLANs | 通过该接口后不再携带Tag的VLAN |
VLAN Passing | 该接口实际可以通过的VLAN(接口允许通过并且已创建的VLAN) |
VLAN permitted | 接口允许通过的VLAN报文 |
Trunk port encapsulation | Trunk接口的封装格式 |
Last link flapping | 接口最近一次物理状态改变到现在的时长。Never表示接口从设备启动后一直处于down状态(没有改变过) |
Last clearing of counters | 最近一次使用reset counters interface命令清除接口下的统计信息的时间(如果从设备启动一直没有执行reset counters interface命令清除过该接口下的统计信息,则显示Never) |
Current system time | 当前系统时间,时间显示格式为YYYY-MM-DD HH:MM:SS 如果配置了时区,当前系统时间后面会追加显示时区的配置,格式为YYYY-MM-DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称 |
Last time when physical state changed to up | 最近一次接口物理状态变为UP的时刻 如果配置了时区,该时间后面会追加显示时区的配置,格式为YYYY-MM-DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称 “-”表示接口物理状态没有发生过变化 |
Last time when physical state changed to down | 最近一次接口物理状态变为DOWN的时刻 如果配置了时区,该时间后面会追加显示时区的配置,格式为YYYY-MM-DD HH:MM:SS zone-name±HH:MM:SS,其中zone-name为本地时区名称 “-”表示接口物理状态没有发生过变化 |
Last 300 seconds input: 0 packets/sec 0 bytes/sec 0% Last 300 seconds output: 0 packets/sec 0 bytes/sec 0% | 端口在最近300秒接收和发送报文的平均速率,单位分别为数据包/秒和字节/秒,以及实际速率和接口带宽的百分比 如果值显示为“-”,则表示不支持该统计项 |
Input(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses | 端口接收报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数 端口接收的单播报文、广播报文、组播报文和PAUSE帧的数量 如果值显示为“-”,则表示不支持该统计项 |
Input(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses | 端口接收的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数 端口接收的正常单播报文、广播报文、组播报文和PAUSE帧的数量 如果值显示为“-”,则表示不支持该统计项 |
input errors | 端口接收的错误报文的统计值 |
runts | 接收到的超小帧的数量 超小帧是指长度小于64字节、格式正确且包含有效的CRC字段的帧 |
giants | 接收到的超大帧的数量 超大帧是指有效长度大于端口允许通过最大报文长度的帧: · 对于禁止长帧通过的以太网端口,超大帧是指有效长度大于1518字节(不带VLAN Tag)或大于1522字节(带VLAN Tag报文)的帧 · 对于允许长帧通过的以太网端口,超大帧是指有效长度大于指定最大长帧长度的帧 |
throttles | 接收到的长度为非整数字节的帧的个数 |
CRC | 接收到的CRC校验错误、长度正常的帧的数量 |
frame | 接收到的CRC校验错误、且长度不是整字节数的帧的数量 |
overruns | 当端口的接收速率超过接收队列的处理能力时,导致报文被丢弃 |
aborts | 接收到的非法报文总数,非法报文包括: · 报文碎片:长度小于64字节(长度可以为整数或非整数)且CRC校验错误的帧 · jabber帧:有效长度大于端口允许通过的最大报文长度,且CRC校验错误的帧(长度可以为整字节数或非整字节数)。如对于禁止长帧通过的以太网端口,jabber帧是指大于1518(不带VLAN Tag)或1522(带VLAN Tag)字节,且CRC校验错误的帧;对于允许长帧通过的以太网端口,jabber帧是指有效长度大于指定最大长帧长度,且CRC校验错误的帧 · 符号错误帧:报文中至少包含1个错误的符号 · 操作码未知帧:报文是MAC控制帧,但不是Pause帧 · 长度错误帧:报文中802.3长度字段与报文实际长度(46~1500字节)不匹配 |
ignored | 由于端口接收缓冲区不足等原因而丢弃的报文数量 |
parity errors | 接收到的奇偶校验错误的帧的数量 |
Output(total): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses | 端口发送报文的统计值,包括正常报文、异常报文和正常PAUSE帧的报文数、字节数 端口发送的单播报文、广播报文、组播报文和PAUSE帧的数量 如果值显示为“-”,则表示不支持该统计项 |
Output(normal): 0 packets, 0 bytes 0 unicasts, 0 broadcasts, 0 multicasts, 0 pauses | 端口发送的正常报文的统计值,包括正常报文和正常PAUSE帧的报文数、字节数 端口发送的正常单播报文、广播报文、组播报文和PAUSE帧的数量 如果值显示为“-”,则表示不支持该统计项 |
output errors | 各种发送错误的报文总数 |
underruns | 当端口的发送速率超过了发送队列的处理能力,导致报文被丢弃,是一种非常少见的硬件异常 |
buffer failures | 由于端口发送缓冲区不足而丢弃的报文数量 |
aborts | 发送失败的报文总数,即报文已经开始发送,但由于各种原因(如冲突)而导致发送失败 |
deferred | 延迟报文的数量,延迟报文是指发送前检测到冲突而被延迟发送的报文 |
collisions | 冲突帧的数量,冲突帧是指在发送过程中检测到冲突的而停止发送的报文 |
late collisions | 延迟冲突帧的数量,延迟冲突帧是指帧的前512 bits已经被发送,由于检测到冲突,该帧被延迟发送 |
IPv4 traffic statistics | IPv4报文统计信息 |
IPv6 traffic statistics | IPv6报文统计信息 |
Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec | 端口在最近300秒接收报文的平均速率,单位分别为数据包/秒和字节/秒 如果值显示为“-”,则表示不支持该统计项 |
Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec | 端口在最近300秒发送报文的平均速率,单位分别为数据包/秒和字节/秒 如果值显示为“-”,则表示不支持该统计项 |
Input: 0 packets, 0 bytes | 端口接收报文的统计值,包括报文数、字节数 如果值显示为“-”,则表示不支持该统计项 |
Output: 0 packets, 0 bytes | 端口发送报文的统计值,包括报文数、字节数 如果值显示为“-”,则表示不支持该统计项 |
(0)
确定你的邮箱还未认证,请认证邮箱或绑定手机后进行当前操作
