S5850与思科设备做端口聚合,无法通信。
2022-10-06提问
  • 0收藏,529浏览
S5850和思科的交换机用两个端口做静态的端口聚合,聚合口配置成trunk模式,但是虽然能看到建立聚合链路,但是S5850只有一条链路是UP,另一条链路做备用了,思科设备那边是两条链路都是UP。两端模式、速率一样,也无法通信。
4 个回答
粉丝:111人 关注:0人
建议看下我两条物理线路接口下的配置和聚合口下的配置是不是一致的,如果不一致再聚合口下将trunk等配置重新刷一遍。
粉丝:150人 关注:1人
聚合口下shutdown在no shutdown
粉丝:17人 关注:5人
建议配置动态链路聚合试试。
粉丝:35人 关注:7人
以下是与思科对接链路聚合的案例,请参考:
https://zhiliao.h3c.com/Theme/details/113400
本案例采用H3C S5820与思科2960对接二层链路聚合典型组网
H3C S5820版本信息如下:
H3C Comware Software, Version 7.1.045, Release 2418P06
Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C S5820V2-48S uptime is 240 weeks, 3 days, 2 hours, 10 minutes
Last reboot reason : USER reboot
思科2960版本信息如下:
do sh ve
Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 12.2(55)SE2, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 11-Jan-11 02:23 by prod_rel_team
Image text-base: 0x00003000,>
ROM: Bootstrap program is Alpha board boot loader
BOOTLDR: C2960S Boot Loader (C2960S-HBOOT-M) Version 12.2(53r)SE, RELEASE SOFTWARE (fc3)
SCW-T-1 uptime is 1 year, 30 weeks, 4 days, 18 hours, 16 minutes
System returned to ROM by power-on
System restarted at 18:29:43 UTC Mon Oct 22 2018
System image file is "flash:/c2960s-universalk9-mz.122-55.SE2/c2960s-universalk9-mz.122-55.SE2.bin"
This product contains cryptographic features and is subject to United
States and local country laws governing import, export, transfer and
use. Delivery of Cisco cryptographic products does not imply
third-party authority to import, export, distribute or use encryption.
Importers, exporters, distributors and users are responsible for
compliance with U.S. and local country laws. By using this product you
agree to comply with applicable laws and regulations. If you are unable
to comply with U.S. and local laws, return this product immediately.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html
If you require further assistance please contact us by sending email to
export@cisco.com.
cisco WS-C2960S-48TS-S (PowerPC) processor (revision D0) with 131072K bytes of memory.
Processor board ID FOC1517Y1E2
Last reset from power-on
3 Virtual Ethernet interfaces
1 FastEthernet interface
50 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 88:F0:77:74:C3:80
Motherboard assembly number     : 73-12424-06
Power supply part number        : 341-0327-03
Motherboard serial number       : FOC15151KUK
Power supply serial number      : LIT144432FT
Model revision number           : D0
Motherboard revision number     : A0
Model number                    : WS-C2960S-48TS-S
Daughterboard assembly number   : 73-11933-04
Daughterboard serial number     : FOC1516245W
System serial number            : FOC1517Y1E2
Top Assembly Part Number        : 800-32452-03
Top Assembly Revision Number    : A0
Version ID                      : V03
CLEI Code Number                : COMGK00ARC
Daughterboard revision number   : A0
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 50    WS-C2960S-48TS-S   12.2(55)SE2           C2960S-UNIVERSALK9-M
Configuration register is 0xF
配置步骤
S5820的XGE1/0/41、XGE2/0/41分别与思科2960的G0/49、G0/50互联
配置关键点
S5820二层链路聚合配置如下:
interface Bridge-Aggregation41
 port link-type trunk
 undo port trunk permit vlan 1
 port trunk permit vlan 2 to 4094
interface Ten-GigabitEthernet1/0/41
 port link-mode bridge
 stp root-protection
 port link-aggregation group 41
interface Ten-GigabitEthernet2/0/41
 stp root-protection
思科2960二层链路聚合配置如下:
interface Port-channel1
 switchport trunk allowed vlan 2,3,12,400
 switchport mode trunk
exit
interface GigabitEthernet0/49
 channel-group 1 mode on
exit
interface GigabitEthernet0/50
exit
查看S5820的链路聚合状态:
dis link-aggregation verbose Bridge-Aggregation 41
Flags:  A -- LACP_Activity, B -- LACP_Timeout, C -- Aggregation,
        G -- Defaulted, H -- Expired
Aggregate Interface: Bridge-Aggregation41
Aggregation Mode: Static
  Port             Status  Priority Oper-Key
  XGE1/0/41        S       32768    10
  XGE2/0/41        S       32768    10
查看思科2960链路聚合的状态:
show interfaces port-channel 1 status
Port      Name               Status       Vlan       Duplex  Speed Type
Po1                          connected    trunk      a-full a-1000
SCW-T-1#show interfaces port-channel 1 e
SCW-T-1#show interfaces port-channel 1 etherchannel
Age of the Port-channel   = 579d:18h:20m:02s
Logical slot/port   = 5/1          Number of ports = 2
GC                  = 0x00000000      HotStandBy port = null
Port state          = Port-channel Ag-Inuse
Protocol            =    -
Port security       = Disabled
Ports in the Port-channel:
Index   Load   Port     EC state        No of bits
  0     00     Gi0/49   On                 0
  0     00     Gi0/50   On                 0
Time since last port bundled:    60d:11h:41m:49s    Gi0/49
Time since last port Un-bundled: 60d:12h:13m:13s    Gi0/49
至此,S5820与思科2960对接二层链路聚合典型组网配置案例已完成!
