两台S7006X IRF堆叠
2022-10-06提问
  • 0收藏,700浏览
两台S7006X IRF 配置
粉丝:111人 关注:0人
要配置案例吗?
参考下面的案例:
https://zhiliao.h3c.com/Theme/details/45967
我做了堆叠后 VLAN 地址ping不通
zhiliao_ejFb0G 发表时间:2022-10-06
那肯定是配置的问题了,问题写清楚点,具体配置是什么,拓扑是怎么连得?光一句话看不出来什么问题呀
知了知了 发表时间:2022-10-06
两台S7006 都配有LSCM2G24GPTSSC8板块,通过两个万兆光口堆叠,按照参考案例配置。设备重启后显示变成了一台设备,端口都翻倍,用display irf命令显示也正常。做了几个VLAN接口,在VLAN 内部能Ping通,跨VLAN不能Ping通。用Console口进入,ping不通Vlan接口。
回复知了知了:
在做IRF绑定之前,没有关闭物理口,有影响么?
接irf-port口之前应该是必须关闭接口的,不然加不进去
# version 7.1.070, Release 7743P05 # sysname Com_Op_B1_Core_253.1 # fabric multicast-forwarding mode standard multicast forwarding-mode default # irf mac-address persistent always irf auto-update enable irf auto-merge enable undo irf link-delay irf member 1 priority 32 irf member 2 priority 1 # ip unreachables enable ip ttl-expires enable # lldp global enable # system-working-mode standard xbar chassis 1 load-balance xbar chassis 2 load-balance password-recovery enable # vlan 1 # vlan 19 description POS # vlan 20 description Store Traffic Flow Statistics System # vlan 22 description Information Release System # vlan 24 description PDS system # vlan 26 description Commercial OA # vlan 27 description Server for Commercial Operation # vlan 30 description Reserved1 # vlan 31 description Reserved2 # vlan 4094 description Switch Manegement # irf-port 1/2 port group interface Ten-GigabitEthernet1/0/0/39 mode enhanced port group interface Ten-GigabitEthernet1/0/0/40 mode enhanced # irf-port 2/1 port group interface Ten-GigabitEthernet2/0/0/39 mode enhanced port group interface Ten-GigabitEthernet2/0/0/40 mode enhanced # stp instance 0 root primary stp bpdu-protection stp global enable # interface NULL0 # interface Vlan-interface19 ip address 10.10.19.1 255.255.254.0 # interface Vlan-interface20 ip address 10.10.20.1 255.255.254.0 # interface Vlan-interface22 ip address 10.10.22.1 255.255.255.0 # interface Vlan-interface24 ip address 10.10.24.1 255.255.254.0 # interface Vlan-interface26 ip address 10.10.26.1 255.255.255.0 # interface Vlan-interface27 ip address 10.10.27.1 255.255.255.0 # interface Vlan-interface30 ip address 10.10.30.1 255.255.255.0 # interface Vlan-interface31 ip address 10.10.31.1 255.255.255.0 # interface Vlan-interface4094 ip address 10.0.253.1 255.255.255.0 # interface GigabitEthernet1/0/0/1 port link-mode bridge port access vlan 27 stp edged-port # interface GigabitEthernet1/0/0/2 port link-mode bridge port access vlan 27 stp edged-port # interface GigabitEthernet1/0/0/3 port link-mode bridge port access vlan 27 stp edged-port 。。。。。
堆叠过程中没报错
那就不用管了
粉丝:35人 关注:7人
如果是想要IRF的配置举例,可参考如下案例和连接:
https://www.h3c.com/cn/d_202208/1660770_30005_0.htm#_Toc110528455
1.14.2  IRF典型配置举例(VLAN接口配置BFD MAD)
由于网络规模迅速扩大,当前中心交换机(Device A)转发能力已经不能满足需求,现需要在保护现有投资的基础上将网络转发能力提高一倍,并要求网络易管理、易维护。
图1-18 IRF典型配置组网图(VLAN接口配置BFD MAD)
3. 配置思路
设备出厂为独立运行模式,为减少IRF搭建过程中设备重启的次数,本举例采用以下配置思路:
(1)     在独立运行模式下,完成IRF端口和参数的配置。
(2)     切换到IRF模式,在设备重启过程中,连接IRF物理接口。设备启动完成,IRF搭建成功。
(3)     配置MAD检测。
4. 配置注意事项
如果您采用先将设备切换到IRF模式,再绑定IRF端口的方式搭建IRF。请在完成IRF端口等参数配置后,执行save命令保存当前配置,再执行irf-port-configuration active命令手工激活IRF端口的配置,才能形成IRF。
5. 配置步骤
(1)     配置Device A
设置Device A的成员编号为1,创建IRF端口2,并将它与物理端口Ten-GigabitEthernet3/0/1绑定。
[Sysname] irf member 1
[Sysname] irf-port 2
[Sysname-irf-port2] port group interface ten-gigabitethernet 3/0/1
[Sysname-irf-port2] quit
将当前配置保存到下次启动配置文件。
[Sysname] quit
<Sysname> save
将设备的运行模式切换到IRF模式。
[Sysname] chassis convert mode irf
The device will switch to IRF mode and reboot. Continue? [Y/N]:y
You are recommended to save the current running configuration and specify the configuration file for the next startup. Continue? [Y/N]:y
Do you want to convert the content of the next startup configuration file flash:
/startup.cfg to make it available in IRF mode? [Y/N]:y
Now rebooting, please wait...
设备重启后Device A组成了只有一台成员设备的IRF。
(2)     配置Device B
配置Device B的成员编号为2,创建IRF端口1,并将它与物理端口Ten-GigabitEthernet3/0/1绑定。
[Sysname] irf member 2
[Sysname] irf-port 1
[Sysname-irf-port1] port group interface ten-gigabitethernet 3/0/1
[Sysname-irf-port1] quit
将当前配置保存到下次启动配置文件。
[Sysname] quit
<Sysname> save
参照图1-18进行物理连线。
将设备的运行模式切换到IRF模式。
设备B重启后与设备A形成IRF。
(3)     配置BFD MAD检测
修改IRF链路down延迟上报时间为0。
[Sysname] irf link-delay 0
# 创建VLAN 3,并将Device A(成员编号为1)上的端口1/4/0/1和Device B(成员编号为2)上的端口2/4/0/1加入VLAN中。
[Sysname] vlan 3
[Sysname-vlan3] port gigabitethernet 1/4/0/1 gigabitethernet 2/4/0/1
[Sysname-vlan3] quit
创建VLAN接口3,并配置MAD IP地址。
[Sysname] interface vlan-interface 3
[Sysname-Vlan-interface3] mad bfd enable
[Sysname-Vlan-interface3] mad ip address 192.168.2.1 24 member 1
[Sysname-Vlan-interface3] mad ip address 192.168.2.2 24 member 2
[Sysname-Vlan-interface3] quit
因为BFD MAD和生成树功能互斥,所以在GigabitEthernet1/4/0/1和GigabitEthernet2/4/0/1上关闭生成树协议。
[Sysname] interface gigabitethernet 1/4/0/1
[Sysname-gigabitethernet-1/4/0/1] undo stp enable
[Sysname-gigabitethernet-1/4/0/1] quit
[Sysname] interface gigabitethernet 2/4/0/1
[Sysname-gigabitethernet-2/4/0/1] undo stp enable
粉丝:148人 关注:1人
1 IRF
1.1 IRF简介
1.1.1 IRF组网示意图
1.1.2 IRF的优点
1.1.3 IRF基本概念
1.1.4 IRF的连接拓扑
1.1.5 角色选举
1.1.6 IRF中的接口命名规则
1.1.7 IRF中的文件系统命名规则
1.1.8 IRF中的配置文件同步
1.1.9 MAD功能
1.1.10 MAD检测机制
1.2 IRF配置限制和指导
1.2.1 硬件兼容性相关配置限制和指导
1.2.2 软件版本要求
1.2.3 IRF规模
1.2.4 确定IRF物理端口
1.2.5 选择连接IRF端口的模块或线缆
1.2.6 IRF物理端口连接要求
1.2.7 IRF物理端口配置限制和指导
1.2.8 IRF与其它软件特性的兼容性与限制
1.2.9 配置回滚限制
1.3 IRF配置任务简介
1.4 配置准备
1.5 搭建IRF
1.5.1 配置成员编号
1.5.2 配置成员优先级
1.5.3 配置IRF端口
1.5.4 将当前配置保存到设备的下次启动配置文件
1.5.5 连接IRF物理接口
1.5.6 切换到IRF模式
1.5.7 访问IRF
1.6 配置MAD
1.6.1 配置限制和指导
1.6.2 配置LACP MAD检测
1.6.3 配置BFD MAD检测
1.6.4 配置ARP MAD检测
1.6.5 配置ND MAD检测
1.6.6 配置保留接口
1.6.7 MAD故障恢复
1.7 调整和优化IRF
1.7.1 配置成员编号
1.7.2 配置成员优先级
1.7.3 配置IRF端口
1.7.4 快速配置IRF基本参数
1.7.5 开启IRF合并自动重启功能
1.7.6 配置成员设备的描述信息
1.7.7 配置IRF的桥MAC地址
1.7.8 开启启动文件的自动加载功能
1.7.9 配置IRF链路down延迟上报功能
1.8 IRF显示和维护
1.9 IRF典型配置举例
1.9.1 IRF典型配置举例(LACP MAD检测方式)
1.9.2 IRF典型配置举例(BFD MAD检测方式)
1.9.3 IRF典型配置举例(ARP MAD检测方式)
1.9.4 IRF典型配置举例(ND MAD检测方式)
1.9.5 将成员设备从IRF模式恢复到独立运行模式典型配置举例
