sw1(vlan 90)-----运营商(只能透传vlan1500)---sw2(vlan1500),如何做vlan mapping
2022-10-10提问
  • 0收藏,759浏览
pc----sw1(vlan 90)-----运营商(只能透传vlan1500)---sw2(vlan1500),如何做vlan mapping
sw1连pc端口为access
sw1连sw2端口为trunk,允许vlan 90和500,配置vlanmapping 90转为500
sw2和sw1连端口配置为trunk,允许vlan500,pc的网关在sw2上
配置后不通,要如何配置,求教,谢谢!
sw1连pc端口为access
配置后不通,要如何配置,求教,谢谢!
粉丝:35人 关注:7人
以下是配置举例,请参考:
1.8  VLAN映射典型配置举例
1.8.1  1:1 VLAN映射配置举例
·     在某小区,服务提供商为每个家庭都提供了PC、VoD和VoIP这三种数据服务,每个家庭都通过各自的家庭网关接入楼道交换机。
·     服务提供商希望实现以下网络规划:在家庭网关上,分别将PC、VoD和VoIP业务依次划分到VLAN 1~3;在楼道交换机上,为了隔离不同家庭的同类业务,将每个家庭的每种业务都划分到不同的VLAN。
图1-6 1:1 VLAN映射配置组网图
(1)     配置Switch A
# 配置下行端口GigabitEthernet1/0/1和GigabitEthernet1/0/2为Trunk端口且允许原始VLAN及转换后VLAN通过,同时在端口上配置1:1 VLAN映射。
[SwitchA] vlan 2 to 3
[SwitchA] vlan 101 to 102
[SwitchA] vlan 201 to 202
[SwitchA] vlan 301 to 302
[SwitchA-GigabitEthernet1/0/1] port link-type trunk
[SwitchA-GigabitEthernet1/0/1] port trunk permit vlan 1 2 3 101 201 301
[SwitchA-GigabitEthernet1/0/1] vlan mapping 1 translated-vlan 101
[SwitchA-GigabitEthernet1/0/1] vlan mapping 2 translated-vlan 201
[SwitchA-GigabitEthernet1/0/1] vlan mapping 3 translated-vlan 301
[SwitchA-GigabitEthernet1/0/1] quit
[SwitchA] interface gigabitethernet 1/0/2
[SwitchA-GigabitEthernet1/0/2] port link-type trunk
[SwitchA-GigabitEthernet1/0/2] port trunk permit vlan 1 2 3 102 202 302
[SwitchA-GigabitEthernet1/0/2] vlan mapping 1 translated-vlan 102
[SwitchA-GigabitEthernet1/0/2] vlan mapping 2 translated-vlan 202
[SwitchA-GigabitEthernet1/0/2] vlan mapping 3 translated-vlan 302
[SwitchA-GigabitEthernet1/0/2] quit
# 配置上行端口GigabitEthernet1/0/3为Trunk端口,且允许转换后VLAN通过。
[SwitchA] interface gigabitethernet 1/0/3
[SwitchA-GigabitEthernet1/0/3] port link-type trunk
[SwitchA-GigabitEthernet1/0/3] port trunk permit vlan 101 201 301 102 202 302
[SwitchA-GigabitEthernet1/0/3] quit
(2)     配置Switch B
Switch B的配置与Switch A相似,配置过程略。
(1)     查看Switch A上的VLAN映射配置信息
[SwitchA] display vlan mapping
Interface GigabitEthernet1/0/1:
  Outer VLAN    Inner VLAN    Translated Outer VLAN    Translated Inner VLAN
  1             N/A           101                      N/A
  2             N/A           201                      N/A
  3             N/A           301                      N/A
Interface GigabitEthernet1/0/2:
  1             N/A           102                      N/A
  2             N/A           202                      N/A
  3             N/A           302                      N/A
(2)     查看Switch B上的VLAN映射配置信息
Switch B上的VLAN映射配置信息与Switch A相似,显示信息略。
以上信息表明,Switch A和Switch B上的1:1 VLAN映射配置成功。
1.8.2  1:2 VLAN映射配置举例
·     Site 1和Site 2是某公司的两个分支机构,且利用VLAN 10和VLAN 20承载不同业务类型的数据。由于分处不同地域,这两个分支机构采用SP所提供的VPN接入服务,SP将VLAN 100和VLAN 200分配给该公司使用。
·     该公司希望其下属的这两个分支机构可以跨越SP的网络实现互通。
·     用户不同业务类型的数据使用不同的外层VLAN Tag在运营商网络中传输。
图1-7 1:2映射配置组网图
(1)     配置PE 1
# 创建VLAN 10、VLAN 20、VLAN 200和VLAN 100。
<PE1> system-view
[PE1] vlan 10
[PE1-vlan10] quit
[PE1] vlan 20
[PE1-vlan20] quit
[PE1] vlan 100
[PE1-vlan100] quit
[PE1] vlan 200
[PE1-vlan200] quit
# 在下行端口GigabitEthernet1/0/1上配置1:2 VLAN映射,为VLAN 10的报文添加VLAN 100的外层VLAN Tag,为VLAN 20的报文添加VLAN 200的外层VLAN Tag。
[PE1-GigabitEthernet1/0/1] vlan mapping nest single 10 nested-vlan 100
[PE1-GigabitEthernet1/0/1] vlan mapping nest single 20 nested-vlan 200
# 配置GigabitEthernet1/0/1为Hybrid端口VLAN 100和VLAN200的报文不携带VLAN Tag通过。
[PE1-GigabitEthernet1/0/1] port link-type hybrid
[PE1-GigabitEthernet1/0/1] port hybrid vlan 100 200 untagged
# 配置上行端口GigabitEthernet1/0/2为Trunk端口且允许VLAN 100和VLAN 200通过。
[PE1] interface gigabitethernet 1/0/2
[PE1-GigabitEthernet1/0/2] port link-type trunk
[PE1-GigabitEthernet1/0/2] port trunk permit vlan 100 200
[PE1-GigabitEthernet1/0/2] quit
(2)     配置PE 2
PE 2的配置与PE 1相似,配置过程略。
(1)     查看PE 1上的VLAN映射配置信息
[PE1] display vlan mapping
  10             N/A           100                      10
  20             N/A           200                      20
(2)     查看PE 2上的VLAN映射配置信息
[PE2] display vlan mapping
  10             N/A           100                      10
  20             N/A           200                      20
以上信息表明,PE 1和PE 2上的1:2 VLAN映射配置成功。
如果做VLAN MAPPING的交换机如果还有接口配置了转换前的VLAN的ACCESS口就不会通,所以是有限制的
粉丝:2人 关注:0人
参考官网案例测试下
https://www.h3c.com/cn/d_202205/1614959_30005_0.htm
