WA4430+FIT模式Console启动时Ctrl-B按键无效
2022-10-10提问
  • 1收藏,618浏览
qs4xyf 零段
​想将FIT模式刷成FAT模式,通过Console口启动时,按Ctrl+B无效,这里的B不区分大小写吧?
启动日志(在加粗提示出现后按Ctrl+B无效,启动到最后Console就没有反应了,Enter键按了也没有任何反应):
System is starting... Press Ctrl+D to access BASIC-BOOTWARE MENU Booting Normal Extend BootWare The Extend BootWare is self-decompressing....................Done! **************************************************************************** * * * H3C WA4330-ACN BootWare, Version 1.15 * * * **************************************************************************** Copyright (c) 2004-2017 New H3C Technologies Co., Ltd. Compiled Date : Mar 27 2017 CPU Type : ATHEROS AR9557 CPU L1 Cache : 32KB CPU Clock Speed : 720MHz Memory Type : SDRAM Memory Size : 256MB Memory Speed : 560MHz BootWare Size : 512KB Flash Size : 32MB PCB Version : Ver.B BootWare Validating... Press Ctrl+B to enter extended boot menu... Starting to get the main application file--flash:/wa4300_fit.bin!........... ............................................................................ ................................. The main application file is self-decompressing............................. ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ ............................................................................ .........................................................Done! System application is starting... Startup configuration file does not exist. User interface con0 is available.
 Press ENTER to get started.
粉丝:137人 关注:8人
重启就开始按,不区分大小写,换个终端软件试试
4 个回答
粉丝:16人 关注:2人
波特率没改吧,改为9600试试?
就是9600。
qs4xyf 发表时间:2022-10-10
粉丝:21人 关注:0人
最好通电就不停的按 Ctrl+B 你按慢了  已经加载瘦模式了
如果能进入系统(在没有被AC纳管的情况下)
使用命令 ap-mode fat 也是可以转换的
粉丝:21人 关注:0人
qs4xyf 知了小白
最终结果:换了一台电脑,用同样的终端软件SecureCRT 6.7绿色版就可以正常按键了。
然后用tftp下载wa4300_fat.bin,将原来的wa4300_fit.bin改名后就搞定了。
