老的CR16k更换主控板备件,新备件比现网版本高,无法自动同步的情况,怎么同步
2022-10-16提问
  • 0收藏,565浏览
老的CR16k更换主控板备件,新备件比现网版本高,怎么同步
粉丝:22人 关注:1人
bootware升级bootware后,格式化FLASH,CF卡后,再传版本。
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System |
|<2> Enter Serial SubMenu |
|<3> Enter Ethernet SubMenu |
|<4> File Control |
|<5> Restore to Factory Default Configuration |
|<6> BootWare Operation Menu |
|<7> Clear Super Password |
|<8> Storage Device Operation |
|<9> Product Special Operation |
|<0> Reboot |
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Ctrl+F: Format File System
Enter your choice(0-9): 6
=========================<BootWare Operation Menu>==========================
|Note:the operating device is cfa0 |
|<1> Backup Full BootWare |
|<2> Restore Full BootWare |
|<3> Update BootWare By Serial |
|<4> Update BootWare By Ethernet |
|<0> Exit To Main Menu |
Enter your choice(0-4): 4
===================<BOOTWARE OPERATION ETHERNET SUB-MENU>===================
|<1> Update Full BootWare |
|<2> Update Extend BootWare |
|<3> Update Basic BootWare |
|<4> Modify Ethernet Parameter |
==========================<ETHERNET PARAMETER SET>==========================
|Note: '.' = Clear field. |
| '-' = Go to previous field. |
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :tftp
Load File Name :CR16000-CMW710-R7176.ipe
:CR16000lst1mrpnc9134_v2.19.btw
Target File Name :CR16000-CMW710-R7176.ipe
Server IP Address :192.168.0.2
Local IP Address :192.168.0.1
Gateway IP Address :192.168.0.2
Enter your choice(0-4): 1
Loading.................Done!
738004 bytes downloaded!
Updating Basic BootWare? [Y/N]Y
Updating Basic BootWare....Done!
Updating Extend BootWare? [Y/N]Y
Updating Extend BootWare...Done!
Enter your choice(0-4): 0
Will you backup the Basic BootWare? [Y/N]Y
Begin to backup the Basic BootWare..Done!
Will you backup the Extend BootWare? [Y/N]Y
Begin to backup the Extend BootWare.Done!
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 0
DDR2 SDRAM test successful.
Press Ctrl+T to start five-step full RAM test...
Press Ctrl+Y to start nine-step full RAM test...
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU...
Booting Normal Extended BootWare
The Extended BootWare is self-decompressing.................................
Done.
* H3C CR16000 BootWare, Version 2.19 *
Copyright (c) 2004-2013 Hangzhou H3C Technologies Co., Ltd.
Compiled Date : Jan 25 2013
CPU Type : MPC8548E
CPU L1 Cache : 32KB
CPU L2 Cache : 512KB
CPU Clock Speed : 1000MHz
Memory Type : DDR2 SDRAM
Memory Size : 4096MB
Memory Speed : 400MHz
BootWare Size : 4MB
Flash Size : 128MB
cfa0 Size : 999MB
NVRAM Size : 1024KB
BASIC CPLD Version : 004
EXTENDED CPLD Version : 004
PCB Version : Ver.B
Board self testing...........................
Board steady testing... [ PASS ]
Board SlotNo... [ 0 ]
Subcard exist testing... [ PASS ]
DX246 testing... [ PASS ]
PHY88E1111 testing... [ PASS ]
CPLD1 testing... [ PASS ]
CPLD2 testing... [ PASS ]
NS16550 register testing... [ PASS ]
The switch's Mac address... [58:66:BA:F9:F6:00]
CF Card testing... [ PASS ]
BootWare Validating...
Image program does not exist.
Password recovery capability is enabled.
Note: The current operating device is cfa0
Enter < Storage Device Operation > to select device.
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System |
|<4> File Control |
|<7> Skip Authentication for Console Login |
|<0> Reboot |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Enter your choice(0-9): 1
Loading the main image files...
The image does not exist!
Loading the backup image files...
Loading images fails.
Loading the main boot image...
Loading the backup boot image...
Loading boot image fails.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 8
==============================<DEVICE CONTROL>==============================
|<1> Display All Available Nonvolatile Storage Device(s) |
|<2> Set The Operating Device |
|<3> Set The Default Boot Device |
Enter your choice(0-3): 2
Please set the operating device:
|NO. Device Name File System Total Size Available Space |
|1 flash --- --- --- |
|2 cfa0 FAT 1021088KB 280012KB |
|0 Exit |
Enter your choice(0-2):1
Set the operation device successful!
Enter your choice(0-3): 0
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y.....
Format success.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
|Note:the operating device is flash |
|1 flash JFFS2 131072KB 125178KB |
|0 Exit |
Enter your choice(0-2):2
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Warning:All files on cfa0 will be lost! Are you sure to format? [Y/N]Y
Format success.
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 4
===============================<File CONTROL>===============================
|<1> Display All File(s) |
|<2> Set Image File type |
|<3> Delete File |
Enter your choice(0-3): 1
Display all file(s) in cfa0:
'M' = MAIN 'B' = BACKUP 'S' = SECURE 'N/A' = NOT ASSIGNED
|NO. Size(B) Time Type Name |
|<3> Delete File |
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Enter your choice(0-9): 3
==========================<Enter Ethernet SubMenu>==========================
|<1> Download Image Program To SDRAM And Run |
|<2> Update Main Image File |
|<3> Update Backup Image File |
|<4> Update User Private File |
|<5> Modify Ethernet Parameter |
|<Ensure The Parameter Be Modified Before Downloading!> |
Enter your choice(0-5): 5
| Ctrl+D = Quit. |
Protocol (FTP or TFTP) :TFTP
Load File Name :CR16000-CMW710-R6225P03.bin
Target File Name :CR16000-CMW710-R6225P03.bin
Server IP Address :192.168.1.2
Local IP Address :192.168.1.1
Subnet Mask :24
Gateway IP Address :0
| Ctrl+D = Quit. |
Server IP Address :192.168.1.2 192.168.0.2
Local IP Address :192.168.1.1 192.168.0.1
Subnet Mask :24
Gateway IP Address :0 192.168.0.2
Enter your choice(0-5): 2
Loading.....................................................................
..............Done.
268884992 bytes downloaded!
Image file CR16000-CMW710-BOOT-R7176.bin is self-decompressing...
Saving file cfa0:/CR16000-CMW710-BOOT-R7176.bin ............................
........Done.
Image file CR16000-CMW710-SYSTEM-R7176.bin is self-decompressing...
Saving file cfa0:/CR16000-CMW710-SYSTEM-R7176.bin ..........................
................................Done.
Enter your choice(0-5): 0
|<1> Boot System |
|<4> File Control |
|<0> Reboot |
Done.
CPU Type : MPC8548E
CPU L1 Cache : 32KB
BootWare Size : 4MB
Flash Size : 128MB
cfa0 Size : 999MB
NVRAM Size : 1024KB
PCB Version : Ver.B
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
Loading file cfa0:/CR16000-CMW710-SYSTEM-R7176.bin..........................
Loading file cfa0:/CR16000-CMW710-BOOT-R7176.bin............................
Extended BootWare Version is not equal,updating? [Y/N]
Updating Extended BootWare.......Done.
BootWare updated,System is rebooting now.
Done.
* H3C CR16000 BootWare, Version 2.22 *
Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd.
Compiled Date : Sep 22 2015
CPU Type : MPC8548E
CPU L1 Cache : 32KB
BootWare Size : 4MB
Flash Size : 128MB
cfa0 Size : 999MB
NVRAM Size : 1024KB
PCB Version : Ver.B
Normal Extended BootWare Version is newer than Backup Extended BootWare!
Begin to Update the Backup Extended BootWare.......Done.
Image file cfa0:/CR16000-CMW710-BOOT-R7176.bin is self-decompressing........
..........................................Done.
System image is starting...
Starting image at 0x02000008 ...Failed to get board power! p1=7, p2=252773633, p3=2260.
Cryptographic algorithms tests passed.
Failed to get board power! p1=9, p2=252773633, p3=2260.
Startup configuration file does not exist.
Started automatic configuration, press CTRL_C or CTRL_D to break.
Automatic configuration attempt: 1.
Not ready for automatic configuration: no interface available.
Waiting for the next...
Automatic configuration attempt: 2.
Interface used: M-Ethernet0/0/0.
Enable DHCP client on M-Ethernet0/0/0.
Automatic configuration is running, press CTRL_C or CTRL_D to break.
M-Ethernet0/0/0 failed to obtain IP address.
Automatic configuration is aborted.
Line con0 is available.
Press ENTER to get started.
<H3C>
<H3C>
<H3C>
<H3C>
<H3C>
<H3C>
<H3C>%Mar 4 05:44:18:650 2013 H3C SHELL/5/SHELL_LOGIN: -MDC=1; Console logged in from con0.
<H3C>
<H3C>
<H3C>
<H3C>
<H3C>dis ver
<H3C>dis version
H3C Comware Software, Version 7.1.045, Release 7176
Copyright (c) 2004-2015 Hangzhou H3C Tech. Co., Ltd. All rights reserved.
H3C CR16008 uptime is 0 weeks, 0 days, 0 hours, 1 minute
Last reboot reason : User reboot
Boot image: cfa0:/CR16000-CMW710-BOOT-R7176.bin
Boot image version: 7.1.045, Release 7176
Compiled Oct 27 2015 16:00:00
System image: cfa0:/CR16000-CMW710-SYSTEM-R7176.bin
System image version: 7.1.045, Release 7176
CR-MRP-I 0: uptime is 0 weeks, 0 days, 0 hours, 1 minute
3456 Mbytes SDRAM
1024 Kbytes NVRAM Memory
Type : CR-MRP-I
BootRom : 2.22
Software : CR16000-CMW710-R7176
PCB : Ver.B
Board Cpu:
Number of Cpld: 2
Cpld 0:
SoftWare : 004
<H3C>%Mar 4 05:44:46:607 2013 H3C SYSM/1/DRV_SYSM_PROMPT: -MDC=1; The device software does not support board in slot 7, type is unknown, please check and update device version.
%Mar 4 05:44:49:633 2013 H3C SYSM/1/DRV_SYSM_PROMPT: -MDC=1; The device software does not support board in slot 7, type is unknown, please check and update device version.
%Mar 4 05:44:52:659 2013 H3C SYSM/1/DRV_SYSM_PROMPT: -MDC=1; The device software does not support board in slot 7, type is unknown, please check and update device version.
%Mar 4 05:44:52:880 2013 H3C DEV/5/BOARD_STATE_NORMAL: -MDC=1; Board state changed to Normal on slot 2, type is CR-SPC-GT48LEF.
%Mar 4 05:44:53:214 2013 H3C DEV/5/BOARD_STATE_NORMAL: -MDC=1; Board state changed to Normal on slot 14, type is CR-SF08C.
%Mar 4 05:44:53:223 2013 H3C DEV/5/BOARD_STATE_NORMAL: -MDC=1; Board state changed to Normal on slot 15, type is CR-SF08C.
%Mar 4 05:44:53:234 2013 H3C DEV/5/BOARD_STATE_NORMAL: -MDC=1; Board state changed to Normal on slot 16, type is CR-SF08C.
%Mar 4 05:45:04:570 2013 H3C DEV/5/BOARD_STATE_NORMAL: -MDC=1; Board state changed to Normal on slot 5, type is CR-SPC-XP4LEF-I.
%Mar 4 05:45:38:841 2013 H3C SYSM/1/DRV_SYSM_PROMPT: -MDC=1; The device software does not support board in slot 7, type is unknown, please check and update device version.
%Mar 4 05:45:41:867 2013 H3C SYSM/1/DRV_SYSM_PROMPT: -MDC=1; The device software does not support board in slot 7, type is unknown, please check and update device version.
%Mar 4 05:45:44:893 2013 H3C SYSM/1/DRV_SYSM_PROMPT: -MDC=1; The device software does not support board in slot 7, type is unknown, please check and update device version.
<H3C>
<H3C>
<H3C>
<H3C>
<H3C>
<H3C>dis ver
<H3C>dis version
H3C CR16008 uptime is 0 weeks, 0 days, 0 hours, 4 minutes
CR-MRP-I 0: uptime is 0 weeks, 0 days, 0 hours, 4 minutes
3456 Mbytes SDRAM
Type : CR-MRP-I
BootRom : 2.22
PCB : Ver.B
Board Cpu:
Number of Cpld: 2
Cpld 0:
SoftWare : 004
Cpld 1:
SoftWare : 004
PowChipA : 005
CpuCard
Type : LSR1CPA
PCB : Ver.C
Number of Cpld: 1
Cpld 0:
SoftWare : 001
BootRom : 2.14
Mbus card
Type : LSR1MBCB
Software : 115
PCB : Ver.B
CR-SPC-GT48LEF 2: uptime is 0 weeks, 0 days, 0 hours, 2 minutes
1024 Mbytes SDRAM
0 Kbytes NVRAM Memory
Type : CR-SPC-GT48LEF
PCB : Ver.B
Board Cpu:
Number of Cpld: 1
Cpld 0:
SoftWare : 003
PowChipA : 004
PowChipB : 004
CpuCard
Type : LSR1CPAE
PCB : Ver.C
Number of Cpld: 1
Cpld 0:
SoftWare : 001
BootRom : 2.14
Mbus card
Type : LSR1MBCB
Software : 115
PCB : Ver.B
CR-SPC-XP4LEF-I 5: uptime is 0 weeks, 0 days, 0 hours, 2 minutes
1024 Mbytes SDRAM
Type : CR-SPC-XP4LEF-I
---- More ----%Mar 4 05:46:31:076 2013 H3C SYSM/1/DRV_SYSM_PROMPT: -MDC=1; The device software does not support board in slot 7, type is unknown, please check and update device version.
%Mar 4 05:46:34:102 2013 H3C SYSM/1/DRV_SYSM_PROMPT: -MDC=1; The device software does not support board in slot 7, type is unknown, please check and update device version.
%Mar 4 05:46:37:128 2013 H3C SYSM/1/DRV_SYSM_PROMPT: -MDC=1; The device software does not support board in slot 7, type is unknown, please check and update device version.
整体设备升级,或者咨询下400有无板卡单独升降级方法
粉丝:137人 关注:8人
升级在用的或者降级替换的板卡。
