H3C S6520 Series 堆叠问题
  • 0收藏,703浏览
小熊 零段
客户这里有2台24口的S6520不知道是否可以组建堆叠,另外组建堆叠的具体配置在哪里查看呢?还有对端是思科的双活,做的VPC,我们这里应该做什么协议对接呢?
粉丝:171人 关注:8人
可以堆叠,6520版本一样就可以
另外组建堆叠的具体配置在哪里查看呢?
01-IRF配置
1.8.1 IRF典型配置举例(LACP MAD检测方式)
1.8.2 IRF典型配置举例(BFD MAD检测方式)
vPC对远端设备没有要求,只要远端设备支持802.3ad/LACP,本端设备均可以使用vPC与其互联。
粉丝:23人 关注:0人
堆叠就找个通用堆叠模板即可,堆叠配置见下方。
对端是Cisco VPC模式的话,就正常做Trunk即可,把华三这边看成单台设备,
或者你做个三层互联也是没问题的,(配置一个IP接口,思科那边也一样,做个ip三层接口,肯定可以对接的,但是记得写路由)
3.1.1 配置设备编号
# Device A保留缺省编号为1,不需要进行配置。同时,Device B上将设备的成员编号修改为2
<DeviceB> system-view
[DeviceB] irf member 1 renumber 2
Warning: Renumbering the switch number may result in configuration change or loss. Continue? [Y/N]:y
[DeviceB]
3.1.2 配置堆叠口
#将两台设备断电后,按组网图所示连接IRF链路,然后将两台设备上电Device A上创建设备的IRF端口2,与物理端口Ten-GigabitEthernet1/0/25 Ten-GigabitEthernet1/0/26绑定,并保存配置。
<DeviceA> system-view
[DeviceA] interface ten-gigabitethernet 1/0/25
[DeviceA-Ten-GigabitEthernet1/0/25] shutdown
[DeviceA-Ten-GigabitEthernet1/0/25] quit
[DeviceA] interface ten-gigabitethernet 1/0/26
[DeviceA-Ten-GigabitEthernet1/0/26] shutdown
[DeviceA-Ten-GigabitEthernet1/0/26] quit
[DeviceA] irf-port 1/2
[DeviceA-irf-port1/2] port group interface ten-gigabitethernet1/0/25
[DeviceA-irf-port1/2] port group interface ten-gigabitethernet1/0/26
[DeviceA-irf-port1/2] quit
[DeviceA-Ten-GigabitEthernet1/0/25] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/25quit
[DeviceA-Ten-GigabitEthernet1/0/26] undo shutdown
[DeviceA-Ten-GigabitEthernet1/0/26quit
[DeviceA] save force
Device B上创建设备的IRF端口1,与物理端口Ten-GigabitEthernet2/0/25Ten-GigabitEthernet2/0/26绑定,并保存配置。
[DeviceB] interface ten-gigabitethernet 2/0/25
[DeviceB-Ten-GigabitEthernet2/0/25] shutdown
[DeviceB-Ten-GigabitEthernet2/0/25] quit
[DeviceB] interface ten-gigabitethernet 2/0/26
[DeviceB-Ten-GigabitEthernet2/0/26] shutdown
[DeviceB-Ten-GigabitEthernet2/0/26] quit
[DeviceB] irf-port 2/1
[DeviceB-irf-port2/1] port group interface ten-gigabitethernet2/0/25
[DeviceB-irf-port2/1] port group interface ten-gigabitethernet2/0/26
[DeviceB-irf-port2/1] quit
[DeviceB-Ten-GigabitEthernet2/0/25] undo shutdown
[DeviceB-Ten-GigabitEthernet2/0/25quit
[DeviceB-Ten-GigabitEthernet2/0/26] undo shutdown
[DeviceB-Ten-GigabitEthernet2/0/26quit
[DeviceB] save force
激活DeviceAIRF端口配置。
[DeviceA] irf-port-configuration active
激活DeviceBIRF端口配置。
[DeviceB] irf-port-configuration active
#两台设备间将会进行Master竞选,竞选失败的一方将自动重启,重启完成后,IRF形成,系统名称统一为DeviceA
