H3C S5560-30F-EI-1309P06 端口镜像怎么做
2022-10-18提问
  • 0收藏,1025浏览
想做端口镜像
粉丝:22人 关注:0人
V7交换机本地端口镜像配置方法(命令行版)
参考:
3.1配置本地端口镜像
#进入系统视图,并创建本地镜像组1
<H3C>system-view
System View: return to User View with Ctrl+Z.
[H3C] mirroring-group 1 local
配置本地镜像组1的源端口为GigabitEthernet1/0/1GigabitEthernet1/0/2,目的端口为GigabitEthernet1/0/3
[H3C] mirroring-group 1 mirroring-port GigabitEthernet 1/0/1 GigabitEthernet 1/0/2 both
[H3C] mirroring-group 1 monitor-port GigabitEthernet 1/0/3
在目的端口GigabitEthernet1/0/3上关闭生成树协议。
[H3C] interface GigabitEthernet 1/0/3
[H3C-GigabitEthernet1/0/3] undo stp enable
[H3C-GigabitEthernet1/0/3] quit
3.2检查配置效果
显示所有镜像组的配置信息。
[H3C] display mirroring-group all
mirroring-group 1:
    type: local
    status: active
    mirroring port:
        GigabitEthernet1/0/1  both
        GigabitEthernet1/0/2  both
    monitor port: GigabitEthernet1/0/3
佚名 九段
粉丝:22人 关注:0人
1.7.1  本地端口镜像配置举例
Device通过端口GigabitEthernet1/0/1和GigabitEthernet1/0/2分别连接市场部和技术部,并通过端口GigabitEthernet1/0/3连接Server。
通过配置源端口方式的本地端口镜像,使Server可以监控所有进、出市场部和技术部的报文。
图1-5 本地端口镜像配置组网图
# 创建本地镜像组1。
[Device] mirroring-group 1 local
# 配置本地镜像组1的源端口为GigabitEthernet1/0/1和GigabitEthernet1/0/2,对源端口收发的报文都进行镜像,目的端口为GigabitEthernet1/0/3。
[Device] mirroring-group 1 mirroring-port gigabitethernet 1/0/1 gigabitethernet 1/0/2 both
[Device] mirroring-group 1 monitor-port gigabitethernet 1/0/3
# 在目的端口GigabitEthernet1/0/3上关闭生成树协议。
[Device] interface gigabitethernet 1/0/3
[Device-GigabitEthernet1/0/3] undo stp enable
[Device-GigabitEthernet1/0/3] quit
# 显示所有镜像组的配置信息。
[Device] display mirroring-group all
Mirroring group 1:
    Type: Local
    Status: Active
    Mirroring port:
        GigabitEthernet1/0/1  Both
        GigabitEthernet1/0/2  Both
    Monitor port: GigabitEthernet1/0/3
配置完成后,用户可以通过Server监控所有进、出市场部和技术部的报文。
<H3C>sys
[H3C]sysname SW1
[SW1]mirroring-group 1 local   //创建本地镜像组、组号为1
[SW1]mirroring-group 1 mirroring-port GigabitEthernet 1/0/2 both  //指定镜像口,监控进出流量
[SW1]mirroring-group 1 monitor-port GigabitEthernet 1/0/1  //指定监控口
[SW1]dis mirroring-group all   //查看镜像组信息
Mirroring group 1:
    Type: Local  //本地镜像
    Status: Active  //镜像状态为激活
    Mirroring port:
    Monitor port: GigabitEthernet1/0/1
粉丝:112人 关注:8人
