RBM+VRRP业务故障
2022-10-21提问
  • 0收藏,748浏览
防火墙1和防火墙2采用三层RBM组网,要求业务192.168.1.1和业务192.168.2.1互通。拓扑和配置如下,请教大佬故障点在哪里。(俩端交换机接口配置均为access,互联IP地址配置在vlanif下,业务地址在loopback0下)
现象:1.业务地址不互通,
          2.交换机ping不通防火墙的互联地址,
          3.防火墙自己ping不通自己的vrid 地址
RBM_P[f1]dis cu   主管理设备配置文件如下
 version 7.1.064, Alpha 7164
 sysname f1
context Admin id 1
 telnet server enable
 irf mac-address persistent timer
 irf auto-update enable
 undo irf link-delay
 irf member 1 priority 1
 xbar load-single
 password-recovery enable
 lpu-type f-series
vlan 1
interface Route-Aggregation1
 ip address 10.1.1.1 255.255.255.252
interface NULL0
interface GigabitEthernet1/0/0
 port link-mode route
 combo enable copper
 ip address 1.1.1.11 255.255.255.0
 vrrp vrid 1 virtual-ip 1.1.1.10 active
 combo enable copper
 ip address 2.2.2.11 255.255.255.0
 vrrp vrid 2 virtual-ip 2.2.2.10 active
 combo enable copper
 port link-aggregation group 1
 combo enable copper
interface GigabitEthernet1/0/4
 combo enable copper
interface GigabitEthernet1/0/5
 combo enable copper
interface GigabitEthernet1/0/6
 combo enable copper
interface GigabitEthernet1/0/7
 combo enable copper
interface GigabitEthernet1/0/8
 combo enable copper
interface GigabitEthernet1/0/9
 combo enable copper
interface GigabitEthernet1/0/10
 combo enable copper
interface GigabitEthernet1/0/11
 combo enable copper
interface GigabitEthernet1/0/12
 combo enable copper
interface GigabitEthernet1/0/13
 combo enable copper
interface GigabitEthernet1/0/14
 combo enable copper
interface GigabitEthernet1/0/15
 combo enable copper
interface GigabitEthernet1/0/16
 combo enable copper
interface GigabitEthernet1/0/17
 combo enable copper
interface GigabitEthernet1/0/18
 combo enable copper
interface GigabitEthernet1/0/19
 combo enable copper
interface GigabitEthernet1/0/20
 combo enable copper
interface GigabitEthernet1/0/21
 combo enable copper
interface GigabitEthernet1/0/22
 combo enable copper
interface GigabitEthernet1/0/23
 combo enable copper
security-zone name Local
security-zone name Trust
 import interface GigabitEthernet1/0/0
security-zone name DMZ
security-zone name Untrust
 import interface GigabitEthernet1/0/1
security-zone name Management
 scheduler logfile size 16
line class aux
 user-role network-operator
line class console
 user-role network-admin
line class tty
line class vty
line aux 0
line con 0
 authentication-mode scheme
line vty 0 4
line vty 5 63
 ip route-static 192.168.1.0 24 1.1.1.1
 ip route-static 192.168.2.0 24 2.2.2.1
 info-center loghost 127.0.0.1 port 3301 format default
 info-center source CFGLOG loghost level informational
domain system
 aaa session-limit ftp 16
 aaa session-limit telnet 16
 aaa session-limit ssh 16
 domain default enable system
role name level-0
 description Predefined level-0 role
role name level-1
 description Predefined level-1 role
role name level-2
 description Predefined level-2 role
role name level-3
 description Predefined level-3 role
role name level-4
 description Predefined level-4 role
role name level-5
 description Predefined level-5 role
role name level-6
 description Predefined level-6 role
role name level-7
 description Predefined level-7 role
role name level-8
 description Predefined level-8 role
role name level-9
 description Predefined level-9 role
role name level-10
 description Predefined level-10 role
role name level-11
 description Predefined level-11 role
role name level-12
 description Predefined level-12 role
role name level-13
 description Predefined level-13 role
role name level-14
 description Predefined level-14 role
user-group system
local-user admin class manage
 password hash $h$6$UbIhNnPevyKUwfpm$LqR3+yg1IjNct39MkOR0H0iQXLkYB3jMqM4vbAeoXOhbabIIFnjJPEGR00YiYA1Sz4LiY3FmEdru2fOLMb1shQ==
 service-type telnet terminal http
 authorization-attribute user-role level-3
 ip http enable
 ip https enable
security-policy ip
 rule 1 name 1
  action pass
  source-zone Trust
  destination-zone Untrust
 rule 2 name 2
  action pass
  source-zone Untrust
  destination-zone Trust
 rule 3 name 3
  action pass
  source-zone Local
  service vrrp
 rule 4 name 4
  action pass
  source-zone Trust
  destination-zone Local
  service vrrp
 rule 5 name 5
  action pass
  source-zone Local
  service vrrp
 rule 6 name 6
  action pass
  source-zone Untrust
  service vrrp
remote-backup group
 data-channel interface Route-Aggregation1
 configuration sync-check interval 12
 delay-time 1
 local-ip 10.1.1.1
 remote-ip 10.1.1.2
 device-role primary
RBM_P[f1]display  remote-backup-group status   查看主管理设备RBM状态
Remote backup group information:
  Backup mode: Active/standby
  Device management role: Primary
  Device running status: Active
  Data channel interface: Route-Aggregation1
  Local IP: 10.1.1.1
  Remote IP: 10.1.1.2    Destination port: 60064
  Control channel status: Connected
  Keepalive interval: 1s
  Keepalive count: 10
  Configuration consistency check interval: 12 hour
  Configuration consistency check result: Not Performed
  Configuration backup status: Auto sync enabled
  Session backup status: Hot backup enabled
  Delay-time: 1 min
  Uptime since last switchover: 0 days, 0 hours, 4 minutes
  Switchover records:
    Time                  Status change        Cause
    2022-10-21 11:20:44   Standby to Active    Interface status changed
    2022-10-21 11:18:55   Active to Standby    Interface status changed
    2022-10-21 11:00:48   Active to Active     Keepalive link established
    2022-10-21 10:58:56   Initial to Active    HA Configuration changed
RBM_P[f1]dis
RBM_P[f1]display  vr
RBM_P[f1]display  vrrp     查看主管理设备vrrp状态
 Running mode      : Standard
 RBM control channel is established
   VRRP active group status : Master
   VRRP standby group status: Master
 Interface          VRID  State        Running Adver   Auth             Virtual
                                       Pri     Timer   Type             IP
 GE1/0/0            1     Master       100     100     Not supported    1.1.1.10
 GE1/0/1            2     Master       100     100     Not supported    2.2.2.10
RBM_S[f2]display  current-configuration   从设备配置文件如下
 sysname f2
context Admin id 1
 undo irf link-delay
 xbar load-single
 lpu-type f-series
vlan 1
 ip address 10.1.1.2 255.255.255.252
interface NULL0
 combo enable copper
 ip address 1.1.1.12 255.255.255.0
 vrrp vrid 1 virtual-ip 1.1.1.10 standby
 combo enable copper
 ip address 2.2.2.12 255.255.255.0
 vrrp vrid 2 virtual-ip 2.2.2.10 standby
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
 combo enable copper
line class aux
line class console
line class tty
line class vty
line aux 0
line con 0
line vty 0 4
line vty 5 63
domain system
role name level-0
role name level-1
role name level-2
role name level-3
role name level-4
role name level-5
role name level-6
role name level-7
role name level-8
role name level-9
role name level-10
role name level-11
role name level-12
role name level-13
role name level-14
user-group system
 ip http enable
 ip https enable
security-policy ip
 rule 1 name 1
  action pass
  source-zone Trust
 rule 2 name 2
  action pass
  source-zone Untrust
 rule 3 name 3
  action pass
  source-zone Local
  service vrrp
 rule 4 name 4
  action pass
  source-zone Trust
  service vrrp
 rule 5 name 5
  action pass
  source-zone Local
  service vrrp
 rule 6 name 6
  action pass
  source-zone Untrust
  service vrrp
remote-backup group
 delay-time 1
 local-ip 10.1.1.2
 remote-ip 10.1.1.1
 device-role secondary
BM_S[f2]display  remote-backup-group status     查看从设备rbm状态
  Device management role: Secondary
  Device running status: Standby
  Local IP: 10.1.1.2
  Remote IP: 10.1.1.1    Destination port: 60064
  Keepalive count: 10
  Delay-time: 1 min
  Uptime since last switchover: 0 days, 0 hours, 5 minutes
  Switchover records:
    2022-10-21 11:26:17   Active to Standby    Interface status changed
    2022-10-21 11:24:17   Standby to Active    Interface status changed
    2022-10-21 11:04:22   Active to Standby    Keepalive link established
    2022-10-21 11:04:21   Initial to Active    HA Configuration changed
RBM_S[f2] dis vr
RBM_S[f2]dis vrrp   查看从设备vrrp状态
   VRRP active group status : Backup
   VRRP standby group status: Backup
                                       Pri     Timer   Type             IP
 GE1/0/0            1     Backup       100     100     Not supported    1.1.1.10
 GE1/0/1            2     Backup       100     100     Not supported    2.2.2.10
RBM_S[f2]
可以看一下会话是否正常
没有会话,感觉像是缺点配置,手册里没有写,麻烦大佬帮看看配置有没有问题
在路上 发表时间:2022-10-21
