6520X 交换机频繁报错告警,连接console线登录,报错一直刷屏,无法操作
2022-10-26提问
  • 0收藏,2204浏览
交换机告警如下,请问怎么解决
%Oct 26 15:49:08:603 2022 CMB_36F_HX_01&02 STP/4/STP_DISPUTE: Instance 0's port Ten-GigabitEthernet1/0/11 received an inferior BPDU from a designated port which is in forwarding or learning state. The designated bridge ID contained in the BPDU is 32768.7cde-7816-caa2, and the designated port ID contained in the BPDU is 128.44. %Oct 26 15:49:08:880 2022 CMB_36F_HX_01&02 STP/4/STP_DISPUTE: Instance 0's port Ten-GigabitEthernet1/0/12 received an inferior BPDU from a designated port which is in forwarding or learning state. The designated bridge ID contained in the BPDU is 32768.7cde-7816-49a2, and the designated port ID contained in the BPDU is 128.29.
核心交换机报错,有关接口对应的是直连交换机,单上联;其他正常交换机是双上联
粉丝:94人 关注:0人
收到次优bpdu,可能是下面有环路
核心做的堆叠,接入交换机还是单上联,接入交换机下联都是终端,这种情况哪里会有环呢?
zhiliao_Ua9aCC 发表时间:2022-10-26
粉丝:121人 关注:8人
排除下是不是单通了
如果是disputed,那么表示端口收到了非阻塞指定端口发出的低优先级消息。需要排查网络中是否有设备没有开启STP,导致BPDU被到作普通报文透传,但是有些接口又没有放通BPDUVLAN,导致BPDU报文不能正常转发,这种情况下就容易发生接口disputed功能生效、接口被阻塞的情况。
这种情况通常都是因为单通导致的,上层设备发送了最优的BPDU给下层,下层没有收到、以为自己是最优的、往上层发送次优BPUD。从而触发了上层设备的disputed功能生效。解决单通问题后,接入层设备阻塞环路的对应接口,其他接口不会受到影响。
