HPE Synergy 660 Gen9中最多可以支持添加多少个网卡
2022-10-27提问
  • 0收藏,625浏览
阿白 零段
三条 九段
粉丝:14人 关注:3人
Mezzanine connectors
Six (6) I/O expansion mezzanine connectors:
Mezzanine connector 1 is x16 PCIe 3.0 Type D (supports Type C and Type D mezzanine cards) for fabric 1.
NOTE: This mezzanine connector supports dual-port mezzanine cards: one port is routed to interconnect module bay 1 and the other to bay 4.
Mezzanine connector 2 is x16 PCIe 3.0 Type D (supports Type C and Type D mezzanine cards) for fabric 2.
NOTE: This mezzanine connector supports dual-port mezzanine cards:. one port is routed to interconnect module bay 2 and the other to bay 5.
NOTE: The HPE Synergy 660 Gen9 supports 2 or 4 processors.? Mezzanine 2 and 5 are only supported when 4 processors are installed.
Mezzanine connector 3 is x16 PCIe 3.0 Type C (supports Type C mezzanine cards) for fabric 3.
NOTE: This mezzanine connector supports dual-port mezzanine cards: one port is routed to interconnect module bay 3 and the other to bay 6.
Mezzanine connector 4 is x16 PCIe 3.0 Type D (supports Type C and Type D mezzanine cards) for fabric 1.
NOTE: This mezzanine connector supports dual-port mezzanine cards: one port is routed to interconnect module bay 1 and the other to bay 4,
Mezzanine connector 5 is x16 PCIe 3.0 Type D (supports Type C and Type D mezzanine cards for fabric 2.
Mezzanine connector 6 is x16 PCIe 3.0 Type C (supports Type C mezzanine cards) for fabric 3.
Mezzanine options include:
Dual-port 10/20Gb compute module mezzanine adapter options for additional network ports
Dual-port 16Gb Fibre Channel HBA for SAN connectivity
2GB FBWC storage adapter for direct-attached storage
粉丝:18人 关注:1人
Six (6) I/O expansion mezzanine connectors:最多可以接6个mezz卡需要注意刀箱的模块也要匹配
