v5交换机802.1X认证不成功
2017-08-15提问
  • 1收藏,2875浏览
pr 26 19:20:39:117 2000 H3C 8021X/7/PACKET: Port:Ethernet1/0/1,Received an EAPOL packet.
*Apr 26 19:20:39:228 2000 H3C 8021X/7/PACKET: Port:Ethernet1/0/1,Received Packet Type: EAPOL-PACKET.
*Apr 26 19:20:39:352 2000 H3C 8021X/7/PACKET: Port:Ethernet1/0/1,EAP Type: Response.
*Apr 26 19:20:39:465 2000 H3C 8021X/7/EVENT: Port:Ethernet1/0/1,Auth:546,Resource exists.
*Apr 26 19:20:39:576 2000 H3C 8021X/7/PACKET: Port:Ethernet1/0/1,Auth:546,Code Type: Challenge.
*Apr 26 19:20:39:697 2000 H3C 8021X/7/EVENT: Port:Ethernet1/0/1,Auth:546,Sent EAP Msg to 802.1X-Msg-Queue successfully.
*Apr 26 19:20:39:848 2000 H3C 8021X/7/PACKET: Port:Ethernet1/0/1,End processing the packet received.
---Verbose information of the packet---
Destination Mac Address: 0180-c200-0003
Source Mac Address: 0024-7e0f-f1d1
Mac Frame Type: 888e.
Protocol Version ID: 1.
Packet Type: 0.
Packet Length: 127.
-----Packet Body-----
Code: 2.
Identifier: 2.
Length: 127.
*Apr 26 19:20:40:311 2000 H3C 8021X/7/EVENT: Auth:546,Msg: Continue.
*Apr 26 19:20:40:391 2000 H3C 8021X/7/EVENT: Port:Ethernet1/0/1,Auth:546,Received Msg:265, Current state:14
*Apr 26 19:20:40:522 2000 H3C 8021X/7/EVENT: Auth:546,Processing node EAP relay...
*Apr 26 19:20:40:623 2000 H3C RDS/7/DEBUG: Recv MSG,[MsgType=Auth request Index = 546, ulParam3=2217375456]
*Apr 26 19:20:40:754 2000 H3C RDS/7/DEBUG: Send attribute list:
*Apr 26 19:20:40:835 2000 H3C RDS/7/DEBUG:
[1  User-name                   ] [10] [01013147]
[12 Framed-MTU                  ] [6 ] [1450]
[79 EAP-Message                 ] [129] [0202007F0410E2EC976BFA40AF1489E09C29C512188D793031303133313437000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000038534136434B474332354A593652334336335348593636334B530000000000003634544842555138]
[80 Message-Autheticator        ] [18] [00000000000000000000000000000000]
[4  NAS-IP-Address              ] [6 ] [140.20.48.92]
[32 NAS-Identifier              ] [5 ] [H3C]
*Apr 26 19:20:41:606 2000 H3C RDS/7/DEBUG:
[5  NAS-Port                    ] [6 ] [16781313]
[87 NAS_Port_Id                 ] [34] [slot=1;subslot=0;port=1;vlanid=1]
[61 NAS-Port-Type               ] [6 ] [15]
[6  Service-Type                ] [6 ] [2]
[7  Framed-Protocol             ] [6 ] [1]
[31 Caller-ID                   ] [19] [30302D32342D37452D30462D46312D4431]
*Apr 26 19:20:42:087 2000 H3C RDS/7/DEBUG:
[44 Acct-Session-Id             ] [19] [1000326192020c010]
[24 State                       ] [18] [644EE1A29EDFAEFA9B1AAC3979F20D95]
*Apr 26 19:20:42:309 2000 H3C RDS/7/DEBUG:
Event: Send Packet,oem(0), send count(0), primary state(0).
*Apr 26 19:20:42:440 2000 H3C RDS/7/DEBUG:
Event: Modify NAS-IP to 140.20.48.92.
*Apr 26 19:20:42:541 2000 H3C RDS/7/DEBUG: Send: IP=[140.20.48.8], UserIndex=[546], ID=[104], RetryTimes=[0], Code=[1], Length=[308]
*Apr 26 19:20:42:701 2000 H3C RDS/7/DEBUG:
Event: Set socket VPN attribute, VPN index=0, Result=0!
*Apr 26 19:20:42:822 2000 H3C RDS/7/DEBUG: Recv MSG,[MsgType=PKT response Index = 62, ulParam3=2218090944]
*Apr 26 19:20:42:953 2000 H3C RDS/7/DEBUG: Receive Raw Packet is:
*Apr 26 19:20:43:034 2000 H3C RDS/7/DEBUG:
 02 68 00 3e 46 23 55 30 66 5e 6b 92 a6 d8 95 6b
 b8 d1 43 07 08 06 ff ff ff ff 0c 06 00 00 02 40
 06 06 00 00 00 02 4f 06 03 00 00 04 50 12 f0 18
 ae 5f 07 1b 21 0b c4 05 5b 41 7b 68 1e 52
*Apr 26 19:20:43:336 2000 H3C RDS/7/DEBUG: No pick-up Notify from Receive Raw Packet!
*Apr 26 19:20:43:447 2000 H3C RDS/7/DEBUG: Receive:IP=[140.20.48.8],Code=[2],Length=[62]
*Apr 26 19:20:43:558 2000 H3C RDS/7/DEBUG:
[8  Framed-Address              ] [6 ] [255.255.255.255]
[12 Framed-MTU                  ] [6 ] [576]
[79 EAP-Message                 ] [6 ] [03000004]
[80 Message-Autheticator        ] [18] [F018AE5F071B210BC4055B417B681E52]
*Apr 26 19:20:43:962 2000 H3C 8021X/7/EVENT: Auth:546,Msg: Auth request ack for failure, ACM->1X.
*Apr 26 19:20:44:083 2000 H3C 8021X/7/EVENT: Port:Ethernet1/0/1,Auth:546,Received Msg:261, Current state:14
*Apr 26 19:20:44:214 2000 H3C 8021X/7/EVENT: Auth:546,Processing node FAILURE...
*Apr 26 19:20:44:315 2000 H3C 8021X/7/ERROR: Auth:546,The user (01013147) authenciate failed.
*Apr 26 19:20:44:425 2000 H3C 8021X/7/EVENT: Port:Ethernet1/0/1,Auth:546,Processing node Unauthor action...
*Apr 26 19:20:44:556 2000 H3C 8021X/7/EVENT: Auth:546,Sending EAPoL-Failure...
*Apr 26 19:20:44:657 2000 H3C 8021X/7/PACKET: Port:Ethernet1/0/1,Transmitted a packet.
Destination Mac Address: 0024-7e0f-f1d1
Source Mac Address: ac74-09f0-6ca0
Packet Type: 0.
Packet Length: 31.
Code: 4.
Identifier: 3.
Length: 31.
*Apr 26 19:20:45:098 2000 H3C 8021X/7/EVENT: Port:Ethernet1/0/1,Auth:546,Author info is INVALID, not need unauthor operation.
*Apr 26 19:20:45:249 2000 H3C 8021X/7/EVENT: Auth:546,Processing node LOGOFF...
*Apr 26 19:20:45:352 2000 H3C 8021X/7/EVENT: Auth:546,Msg: Release request ack, ACM->1X.
*Apr 26 19:20:45:462 2000 H3C 8021X/7/EVENT: Port:Ethernet1/0/1,Auth:546,Received Msg:263, Current state:12
*Apr 26 19:20:45:605 2000 H3C 8021X/7/EVENT: Auth:546,For Authentication failure, go to AUTHFAIL state.
*Apr 26 19:20:45:736 2000 H3C 8021X/7/EVENT: Auth:546,Processing node AUTHFAIL...
*Apr 26 19:20:45:837 2000 H3C 8021X/7/EVENT: Port:Ethernet1/0/1,Auth:546,Authenticator is freed.
墨峰 九段
粉丝:51人 关注:6人
Cookie 七段
粉丝:6人 关注:3人
建议先看看1X认证模式对不对,中继or终结
另外这种认证失败的问题,RADIUS服务器应该有个报错信息吧?
