F1000防火墙如何做到公网与VRF互访
2022-11-01提问
  • 0收藏,819浏览
F1000防火墙如何做到公网与VRF互访,数据通过VRF接口访问公网中的服务器。
粉丝:14人 关注:0人
问题描述
组网拓扑:PC1PC2PC3分别连交换机的vlan,10vlan11vlan100;且电脑的网关都在此交换机上(即交换机vlan虚接口地址);
vlan10虚接口绑定vpn实例vpn10vlan11虚接口绑定vpn实例vpn11vlan100虚接口绑定vpn实例vpn100
现要实现vlan100可以和vlan10互访,vlan100可以和vlan11互访,即跨vpn实例互访
解决方法
注意要保证各个电脑与交换机之间互联的网段不在同一个网段,否则该方法不能使用
1vpn10vpn11vpn100之间RT值打通。
ip vpn-instance vpn10
route-distinguisher 100:1
vpn-target 100:1 300:1 import-extcommunity
vpn-target 100:1 export-extcommunity
ip vpn-instance vpn11
route-distinguisher 200:1
vpn-target 200:1 300:1 import-extcommunity
vpn-target 200:1 export-extcommunity
ip vpn-instance vpn100
route-distinguisher 300:1
vpn-target 300:1 100:1 200:1 import-extcommunity
vpn-target 300:1 export-extcommunity
2、配置vlan虚接口绑定vlan实例
interface Vlan-interface10
ip binding vpn-instance vpn10
ip address 10.1.1.1 255.255.255.252
interface Vlan-interface11
ip binding vpn-instance vpn11
ip address 10.1.1.5 255.255.255.252
interface Vlan-interface100
ip binding vpn-instance vpn100
ip address 10.1.1.253 255.255.255.252
3vpn实例中直接引入另外一个vpn实例的直连路由。在vpn视图下添加如下命令:
address-family ipv4
  route-replicate from vpn-instance vpn100 protocol direct
address-family ipv4
address-family ipv4
  route-replicate from vpn-instance vpn10 protocol direct
  route-replicate from vpn-instance vpn11 protocol direct
补充下:
公网路由表引入VPN实例路由,配置如下:
ip public-instance
 address-family ipv4
VPN实例路由表引入公网路由,配置如下:
 route-distinguisher 1:1
 address-family ipv4
  route-replicate from public protocol direct
