防火墙账号和密码忘记了,如何重置
2022-11-02提问
  • 0收藏,1579浏览
防火墙账号和密码忘记了,如何重置
粉丝:127人 关注:8人
console里修改:
<H3C>system-view          //进入系统视图
[H3C]local-user admin         //
进入admin账号设置
[H3C-luser-admin]password simple admin  //
修改密码为admin
如果console也有密码:
可以通过从BOOTROM中选择“忽略配置”启动设备来获取和重新设备console的密码!
具体操作如下:
第一步:重启路由器,按CtrlB进入BOOTROM菜单
Starting at 0x1c00000...
* Quidway Series Routers Boot ROM, V9.07 *
Copyright(C) 1997-2004 by HUAWEI TECH CO., LTD.
Compiled at 18:10:29 , Oct 14 2004.
Testing memory...OK!
128M bytes SDRAM
32768k bytes flash memory
Hardware Version is MTR 1.0
CPLD Version is CPLD 1.0
Press Ctrl-B to enter Boot Menu
Please input Bootrom password: /默认密码为空/
Boot Menu:
1: Download application program with XMODEM
2: Download application program with NET
3: Set application file type
4: Display applications in Flash
5: Clear application password
6: Start up and ignore configuration
7: Enter debugging environment
8: Boot Rom Operation Menu
9: Do not check the version of the software
a: Exit and reboot
Enter your choice(1-a):
第二步:选择第六项“6: Start up and ignore configuration”,并确认
Boot Menu:
a: Exit and reboot
Enter your choice(1-a): 6
Start up and ignore configuration, Are you sure?[Y/N]y
Set Succeeds
第三步:选择a项重启系统
Boot Menu:
a: Exit and reboot
Enter your choice(1-a): a
Exit and reboot,are you sure?[Y/N]y
Start to reboot...
第四步:当系统以空配置起来以后,使用“more config.cfg”查看配置脚本
dir
Directory of flash:/
0 -rw- 5748224 Nov 19 2004 17:23:05 main.bin
1 -rw- 5746199 Nov 30 2004 14:51:21 v330-0008.bin
2 -rw- 8650414 Nov 22 2004 12:26:57 system
3 -rw- 1053 Dec 15 2004 18:46:41 config.cfg
4 -rw- 8695261 Dec 15 2004 09:59:45 340-0006.bin
31877 KB total (3706 KB free)
more config.cfg
sysname RTA
FTP server enable
local-server nas-ip 127.0.0.1 key huawei
domain default enable system
radius scheme system
server-type huawei
primary authentication 127.0.0.1 1645
primary accounting 127.0.0.1 1646
user-name-format without-domain
domain system
access-limit disable
state active
local-user aaa
password cipher ;)<01%^&;YGQ=^Q`MAF4<1!!
service-type terminal
level 3
local-user admin
password cipher .]@USE=B,53Q=^Q`MAF4<1!!
service-type telnet terminal
level 3
service-type ftp
interface Aux0
async mode flow
link-protocol ppp
interface Ethernet0/0
ip address dhcp-alloc
interface Serial0/0
clock DTECLK1
link-protocol ppp
ip address ppp-negotiate
interface NULL0
user-interface con 0
authentication-mode scheme
user-interface aux 0
user-interface vty 0 4
return
如果是采用simple方式配置口令,则可以直接显示出密码。
如果是采用cipher方式配置口令,按照以下方法处理:
1)将查看到的配置文件复制保存成一个文本文件。
2)修改该文件中对应帐号的密码“password cipher ;)<01%^&;YGQ=^Q`MAF4<1!!”为类似“password simple aaa”的口令
3)将修改过的脚本,复制粘贴到当前路由器中
4disp cur确认当前配置和以前的配置一致后,save配置后重新启动系统
5)重启后,就可以通过修改过的帐号口令登录系统
1、请注意设备的配置脚本和口令的备份保存。以免带来不必要的麻烦!
