ike协商不成功
2022-11-05提问
  • 0收藏,666浏览
%Nov 5 14:12:07:951 2022 JKPT_F IKE/6/IKE_P1_SA_ESTABLISH_FAIL: -COntext=1; Failed to establish phase 1 SA in Aggressive mode IKE_P1_STATE_SEND2 state. Reason: Retransmission timeout. SA information: Role: responder Local IP: 58.129.124.1 Local ID type: USER_FQDN Local ID: fengtai Local port: 500 Retransmissions: 5 Remote IP: 111.193.6.95 Remote ID type: FQDN Remote ID: cqyey-dong Remote port: 13326 Recived retransmissions: 0 Inside VPN instance: Outside VPN instance: Initiator COOKIE: fceb50888ecae6a6 Responder COOKIE: 57f259443bf83eb4 Connection ID: 1547896 Tunnel ID: 4294967295 IKE profile name: *Nov 5 14:12:07:951 2022 JKPT_F IKE/7/ERROR: -COntext=1; vrf = 0, local = 58.129.124.1, remote = 111.193.6.95/13326 Failed to negotiate IKE SA. *Nov 5 14:13:48:171 2022 JKPT_F IKE/7/ERROR: -COntext=1; vrf = 0, local = 58.129.124.1, remote = 111.193.6.95/13326 No HASH in notification payload, Rejected. *Nov 5 14:13:53:960 2022 JKPT_F IKE/7/ERROR: -COntext=1; vrf = 0, local = 58.129.124.1, remote = 111.193.6.95/13326 No HASH in notification payload, Rejected. *Nov 5 14:14:05:960 2022 JKPT_F IKE/7/ERROR: -COntext=1; vrf = 0, local = 58.129.124.1, remote = 111.193.6.95/13326 No HASH in notification payload, Rejected. *Nov 5 14:14:23:960 2022 JKPT_F IKE/7/ERROR: -COntext=1; vrf = 0, local = 58.129.124.1, remote = 111.193.6.95/13326 No HASH in notification payload, Rejected. *Nov 5 14:14:36:960 2022 JKPT_F IKE/7/ERROR: -COntext=1; vrf = 0, local = 58.129.124.1, remote = 111.193.6.95/13326 No HASH in notification payload, Rejected. *Nov 5 14:14:58:960 2022 JKPT_F IKE/7/ERROR: -COntext=1; vrf = 0, local = 58.129.124.1, remote = 111.193.6.95/13326 No HASH in notification payload, Rejected.
总部F5030固定IP,分部GR2200联通拨号网络内做vpn使用,协商参数一致,但是报错,请问该怎么解决?
粉丝:6人 关注:1人
您好,重传超时,感觉对端问题
请问下:对端是拨号网络下联的智能终端路由器,web界面配置的参数和F5030这段是相对应的,该怎么排查?谢谢了
zhiliao_2YIp0y 发表时间:2022-11-05
粉丝:137人 关注:8人
防火墙ipsec诊断功能,诊断一下。
粉丝:35人 关注:7人
IPSEC VPN故障排查:
1、检查公网地址的连通性
2、检查ipsec acl是否配置正确(两端ACL以互为镜像的方式配置)
3、检查ike keychain/ike profile 协商参数配置是否正确(工作模式、keychain、identity、本端/对端隧道地址或隧道名称、NAT穿越功能v7自适应)
4、检查ipsec proposal(v5平台) /ipsec  transform-set(v7平台)参数两端是否一致(封装模式、安全协议、验证算法、加密算法)
5、检查设备是否创建ipsec策略,并加载协商参数(acl、ike profile 、ipsec  transform-set、对端隧道IP)
6、检查ipsec策略是否应用在正确的接口上
IPSEC排查命令:
1、disp ipsec policy
2、disp acl
3、dis cu conf ike-profile
4、dis cu conf ike-keychain
5、display  ike proposal
6、display  ipsec  transform-set
7、disp ike sa (verbose)
8、disp ipsec sa
9、reset ipsec sa
10、reset ike sa
