ap组服务模板
2022-11-09提问
  • 0收藏,938浏览
ap组内绑定的服务模板删除后无法再添加,显示Number of service templates bound to the radios exceeded the limit of the AC.
怎么才能再添加上服务模板
粉丝:127人 关注:8人
超过限制了,或者该radio不支持,删一个再试试
删了不行,还是加不上
zhiliao_Do6Bt9 发表时间:2022-11-09
能不能扩充限制上限
扩充不了,设备限制
zhiliao_sEUyB 发表时间:2022-11-09
回复zhiliao_sEUyB:
原先组内添加了3个模板,限制应该没有那么少现在删到两个,还有一个加不进去
什么型号的ap,开没开wips功能
不应该那么少,至少也得8个,看下加别的模板能不能加进去。或者直接到ap加试试
回复zhiliao_sEUyB:
单ap是怎么绑定模板的请问有命令吗
跟在组里配置一样,无非就是到ap视图的radio下绑定
if-match ip 6.183.42.0 255.255.255.0 vlan 1 ap-model WA4320-ACN-SI map-configuration cfa0:/map-conf/lantingzhenzhongxinxiaoxue-4320.txt radio 1 rate mandatory 12 24 rate supported 18 36 48 54 rate disabled 6 9 radio enable channel band-width 40 option client reject enable rssi 20 service-template 30 vlan 1412 service-template 40 vlan 1412 service-template 50 vlan 1402 radio 2 rate mandatory 11 rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 radio enable option client reject enable service-template 30 vlan 1412 service-template 40 vlan 1412 ap-model WA5530 map-configuration cfa0:/map-conf/lantingzhenzhongxinxiaoxue-5530.txt radio 1 rate mandatory 12 24 rate multicast 24 rate supported 18 36 48 54 rate disabled 6 9 radio enable channel band-width 40 option client reject enable rssi 20 client max-count 100 service-template 30 vlan 1412 service-template 40 vlan 1412 radio 2 rate mandatory 12 24 rate multicast 24 rate supported 18 36 48 54 rate disabled 6 9 radio enable channel band-width 40 option client reject enable rssi 20 client max-count 100 service-template 30 vlan 1412 service-template 40 vlan 1412 radio 3 rate mandatory 11 rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 radio enable option client reject enable client max-count 100 service-template 30 vlan 1412 service-template 40 vlan 1412 module 1 gigabitethernet 1 gigabitethernet 2
太乱啦
回复zhiliao_sEUyB:
wlan ap-group lantingzhenzhongxinxiaoxue if-match ip 6.183.42.0 255.255.255.0 vlan 1 ap-model WA4320-ACN-SI map-configuration cfa0:/map-conf/lantingzhenzhongxinxiaoxue-4320.txt radio 1 rate mandatory 12 24 rate supported 18 36 48 54 rate disabled 6 9 radio enable channel band-width 40 option client reject enable rssi 20 service-template 30 vlan 1412 service-template 40 vlan 1412 service-template 50 vlan 1402 radio 2 rate mandatory 11 rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 radio enable option client reject enable service-template 30 vlan 1412 service-template 40 vlan 1412 ap-model WA5530 map-configuration cfa0:/map-conf/lantingzhenzhongxinxiaoxue-5530.txt radio 1 rate mandatory 12 24 rate multicast 24 rate supported 18 36 48 54 rate disabled 6 9 radio enable channel band-width 40 option client reject enable rssi 20 client max-count 100 service-template 30 vlan 1412 service-template 40 vlan 1412 radio 2 rate mandatory 12 24 rate multicast 24 rate supported 18 36 48 54 rate disabled 6 9 radio enable channel band-width 40 option client reject enable rssi 20 client max-count 100 service-template 30 vlan 1412 service-template 40 vlan 1412 radio 3 rate mandatory 11 rate supported 12 18 24 36 48 54 rate disabled 1 2 5.5 6 9 radio enable option client reject enable client max-count 100 service-template 30 vlan 1412 service-template 40 vlan 1412 module 1 gigabitethernet 1 gigabitethernet 2
所有radio都加不上?
回复zhiliao_sEUyB:
是的,都加不上
一共几个服务模板,把没用的删了,再加试试
回复zhiliao_sEUyB:
一共6个服务模板
把没用的删除吧,在ap视图下绑定试试
回复zhiliao_sEUyB:
ap视图下绑定也绑定不上
报错一样的么
回复zhiliao_sEUyB:
是的
AC什么型号
回复zhiliao_sEUyB:
WX5560H
 vlan 1
  radio 1
   rate disabled 6 9
   radio enable
  radio 2
   rate mandatory 11
   radio enable
 ap-model WA5530
  radio 1
   rate multicast 24
   rate disabled 6 9
   radio enable
  radio 2
   rate multicast 24
   rate disabled 6 9
   radio enable
  radio 3
   rate mandatory 11
   radio enable
  module 1
  gigabitethernet 1
  gigabitethernet 2
