Linux增加永久路由的配置步骤
2022-11-10提问
  • 0收藏,778浏览
Linux 增加永久路由的方法和步骤,有详细的文档吗?
三条 九段
粉丝:14人 关注:3人
最好确认一下系统版本,联系系统工程师支持
粉丝:127人 关注:8人
版本不通方法不同,根据版本找一下度娘
粉丝:150人 关注:1人
举例:
Adding permanent route configuration on Ubuntu
On Ubuntu, there are three ways of adding a permanent route to your Linux machine :
  • You can add it to your Network Manager configuration file;
  • You can edit your Netplan YAML configuration file;
  • You can add your route to the “/etc/network/interfaces” file if you are using an old Ubuntu distribution.
Using Network Manager
To add a permanent route to the Network Manager, you have to navigate to the connection file located at “/etc/NetworkManager/system-connections”.
listing network manager connections
Edit your “Wired connection” file and add a “route1” property in the IPv4 part of the network configuration.
route1 property linux
The route has to be defined as : the network IP address followed by the CIDR, next the default gateway and finally the next-hop.
In order for the changes to be applied, you can restart your network connection, and execute the “route -n” command in order to see your route.
$ sudo nmcli connection reload
reload network manager connection
Awesome, you have added a permanent route to your Linux server!
