交换机的日志,帮我看下是否正常
2022-11-11提问
  • 0收藏,902浏览
交换机的日志,帮我看下是否正常
%Nov 10 12:16:30:646 2022 JDJF-S6520X-CORE DRVPLAT/4/SOFTCAR DROP: -Slot=2; PktType=ARP, SrcMAC=5098-b815-a31f, Dropped from interface=Ten-GigabitEthernet2/0/10 at Stage=47, StageCnt=7680, TotalCnt=268997, MaxRateInt erface=Ten-GigabitEthernet2/0/42.
%Nov 10 11:37:17:339 2022 JDJF-S6520X-CORE DRVPLAT/4/SOFTCAR DROP: -Slot=2; PktType=IPV6_TTL, SrcMAC=5ca7-2170-7802, Dropped from interface=Ten-GigabitEthernet2/0/25 at Stage=0, StageCnt=1, TotalCnt=1, MaxRateInterfa ce=Ten-GigabitEthernet2/0/42
. %Nov 10 11:45:15:849 2022 JDJF-S6520X-CORE DRVPLAT/4/SOFTCAR DROP: -Slot=2; PktType=IPV6_ND_DEST, SrcMAC=44a6-426b-979a, Dropped from interface=Ten-GigabitEthernet2/0/10 at Stage=1, StageCnt=4464, TotalCnt=168954, Ma xRateInterface=Ten-GigabitEthernet2/0/10.
 %Nov 10 12:00:56:043 2022 JDJF-S6520X-CORE DRVPLAT/4/SOFTCAR DROP: -Slot=2; PktType=IPV6_MC_OSPFV3_5, SrcMAC=5ca7-2170-7802, Dropped from interface=Ten-GigabitEthernet2/0/10 at Stage=47, StageCnt=9949, TotalCnt=56698 1, MaxRateInterface=Ten-GigabitEthernet2/0/25
. %Nov 10 12:02:15:344 2022 JDJF-S6520X-CORE DRVPLAT/4/SOFTCAR DROP: PktType=IPV6_MLD, SrcMAC=300d-9e76-6aaa, Dropped from interface=Ten-GigabitEthernet1/0/29 at Stage=63, StageCnt=880, TotalCnt=612170, MaxRat eInterface=Ten-GigabitEthernet1/0/29
佚名 九段
粉丝:22人 关注:0人
不正常,可能有攻击, 攻击报文是ARP和 IPV6_TTL, IPV6_TTL可能是路由环路导致
粉丝:127人 关注:8人
ARP和ipv6超限速丢弃。
日志内容
PktType= [STRINK], srcMAC=[STRING], Drop From Interface=[STRINK] at Stage=[UINT32], StageCnt=[UINT64], TotalCnt=[UINT64]
参数解释
$1:被丢弃报文的类型
$2:最近一次被丢弃报文的源MAC地址
$3:丢弃报文的端口号
$4:报文丢弃的统计周期,取值为0或非0
¡     0:表示统计周期为10分钟
¡     非0:表示统计周期为1小时。每10分钟被分为一个阶段,多个阶段均有报文丢弃时,此处显示为阶段和。例如:如果每个阶段均有报文丢弃,显示为 63(2^0 + 2^1 + 2^2 + 2^3 + 2^4 + 2^5);如果只有第1和第3阶段有丢包,显示为5(2^0 + 2^2)
$5:当前计数阶段被丢弃报文数
$6:被丢弃报文总数
日志等级
4
举例
DRVPLAT/4/SOFTCAR DROP: -MDC=1-Slot=2; PktType=ARP ,srcMAC=0010-9400-0002, Drop From Interface=Ten-GigabitEthernet2/0/23 at Stage=0, StageCnt=500, TotalCnt=500
日志说明
·     基于端口上送CPU的报文超过端口设定的阈值后,报文被丢弃
·     当日志显示被丢弃报文的类型为OAM时,实际也有可能是LACP协议类型的报文被丢弃
处理建议
请联系技术支持
aUtiSm 九段
粉丝:48人 关注:1人
日志不太正常,查看下有没有mac漂移,
solt2上面的数据包被丢弃了
