防火墙外网ping不通,出现类似情况好几次,重新插拔网线后就正常了。这是什么问题
2022-11-16提问
  • 0收藏,756浏览
粉丝:0人 关注:43人
诊断信息在下面
粉丝:150人 关注:1人
不通的时候dis arp观察下能否看到对端arp信息
一口这个广播包是不是有点多了啊
zhiliao_DeeeBD 发表时间:2022-11-16
不多,主要看广播部除以单薄包,看占比
叫我靓仔 发表时间:2022-11-16
粉丝:127人 关注:8人
大概率物理层面问题,先换跟网线再观察
这种现象出现过好几次,昨天一次,前天一次
拔插网线好了,多半网线或接口问题,先换根网线试试
zhiliao_sEUyB 发表时间:2022-11-16
粉丝:0人 关注:43人
GigabitEthernet1/0/1
Current state: UP
Line protocol state: UP
Description: GigabitEthernet1/0/1 Interface
Bandwidth: 100000 kbps
Maximum transmission unit: 1500
Allow jumbo frames to pass
Broadcast max-ratio: 100%
Multicast max-ratio: 100%
Unicast max-ratio: 100%
Internet address: 119.57.100.25/28 (Primary)
IP packet frame type: Ethernet II, hardware address: c4c0-6376-3c75
IPv6 packet frame type: Ethernet II, hardware address: c4c0-6376-3c75
Media type is twisted pair, loopback not set, promiscuous mode not set
100Mb/s, Full-duplex, link type is autonegotiation
Output flow-control is enabled, input flow-control is enabled
Last link flapping: 1 days 2 hours 8 minutes
Last clearing of counters: Never
Current system time:2022-11-16 11:43:17 Lisbon+00:00:00
Last time when physical state changed to up:2022-11-15 09:34:31 Lisbon+00:00:00
Last time when physical state changed to down:2022-11-15 09:34:22 Lisbon+00:00:00
 Peak input rate: 7605192 bytes/sec, at 2022-11-16 10:59:01
 Peak output rate: 12211935 bytes/sec, at 2022-11-08 18:47:21
 Last 300 second input: 2701 packets/sec 3058776 bytes/sec 25%
 Last 300 second output: 1834 packets/sec 365251 bytes/sec 3%
 Input (total):  429220152 packets, 463945508064 bytes
         426632604 unicasts, 2028435 broadcasts, 559113 multicasts, 0 pauses
 Input (normal):  429220152 packets, 463945508064 bytes
 Input:  0 input errors, 0 runts, 0 giants, - throttles
         0 CRC, 0 frame, 0 overruns, 0 aborts
         0 ignored, - parity errors
 Output (total): 303189257 packets, 68716995481 bytes
         303140707 unicasts, 48550 broadcasts, 0 multicasts, 0 pauses
 Output (normal): 303189257 packets, 68716995481 bytes
 Output: 0 output errors, 0 underruns, - buffer failures
         0 aborts, 0 deferred, 0 collisions, 0 late collisions
         0 lost carrier, 0 no carrier
