MSR36-20双线路接入
2022-11-18提问
  • 1收藏,566浏览
fanety 零段
现使用MSR36-20路由器的三个接口
G0/0 配置了3个子接口G0/0.10,G0/0.20,G0/0.30,下联二层交换机配置了3个Vlan,10、20和30。
G0/1配置PPPOE上网。
G0/2配置固定地址上专网。
vlan20和vlan30可以走G0/2上互联网。 vlan10和vlan30可以走G0/2上专网。 配置好后,出口两个方向均通畅。 问题请教:专网没有问题,但部分互联网站可以打开,好多网页打打不开,不知道是什么原因。
version 7.1.064, Release 0615P10
sysname Router
clock timezone Beijing add 08:00:00
clock protocol ntp
telnet server enable
dialer-group 1 rule ip permit
ip ttl-expires enable
dhcp enable
dhcp server always-broadcast
dns proxy enable
password-recovery enable
vlan 1
dhcp server ip-pool Double
gateway-list 192.168.30.254
network 192.168.30.0 mask 255.255.255.0
address range 192.168.30.1 192.168.30.100
dns-list 114.114.114.114 61.128.114.166
dhcp server ip-pool internet
gateway-list 192.168.20.254
network 192.168.20.0 mask 255.255.255.0
address range 192.168.20.1 192.168.20.100
dhcp server ip-pool intranet
gateway-list 192.168.10.254
network 192.168.10.0 mask 255.255.255.0
address range 192.168.10.1 192.168.10.100
controller Cellular0/0
controller Cellular0/1
interface Aux0
interface Dialer0
ppp chap password cipher $c$3$fUx8hIBRCBuB2uIif/hTEsBVUiuJhZXqXbPC
ppp chap user test
ppp ipcp dns admit-any
ppp ipcp dns request
ppp pap local-user test password cipher $c$3$AdItN7aQSaVQ4PL6x6Q/rXIwfpcRlTlM/QUy
dialer bundle enable
dialer-group 1
dialer timer idle 0
dialer timer autodial 5
ip address ppp-negotiate
nat outbound 2001
interface Virtual-Template0
interface NULL0
interface GigabitEthernet0/0
port link-mode route
combo enable copper
interface GigabitEthernet0/0.10
ip address 192.168.10.254 255.255.255.0
vlan-type dot1q vid 10
interface GigabitEthernet0/0.20
ip address 192.168.20.254 255.255.255.0
vlan-type dot1q vid 20
interface GigabitEthernet0/0.30
ip address 192.168.30.254 255.255.255.0
vlan-type dot1q vid 30
interface GigabitEthernet0/1
description Multiple_Line
pppoe-client dial-bundle-number 0
interface GigabitEthernet0/2
ip address 192.168.88.252 255.255.255.248
nat outbound 2002
undo dhcp select server
security-zone name Local
security-zone name Trust
security-zone name DMZ
security-zone name Untrust
security-zone name Management
scheduler logfile size 16
line class aux
user-role network-admin
line class tty
user-role network-operator
line class vty
line aux 0
authentication-mode scheme
line vty 0 4
line vty 5 63
ip route-static 0.0.0.0 0 Dialer0 preference 80
ip route-static 10.0.0.0 16 GigabitEthernet0/2 192.168.88.254
ssh server enable
ssh server compatible-ssh1x enable
ntp-service enable
acl basic 2001
rule 0 permit source 192.168.20.0 0.0.0.255
rule 1 permit source 192.168.30.0 0.0.0.255
rule 2 deny
acl basic 2002
rule 0 permit source 192.168.10.0 0.0.0.255
rule 2 deny
password-control enable
undo password-control aging enable
undo password-control history enable
password-control length 6
password-control login-attempt 3 exceed lock-time 10
password-control update-interval 0
password-control login idle-time 0
password-control complexity user-name check
domain system
domain default enable system
role name level-0
description Predefined level-0 role
role name level-1
description Predefined level-1 role
role name level-2
description Predefined level-2 role
role name level-3
description Predefined level-3 role
role name level-4
description Predefined level-4 role
role name level-5
description Predefined level-5 role
role name level-6
description Predefined level-6 role
role name level-7
description Predefined level-7 role
role name level-8
description Predefined level-8 role
role name level-9
description Predefined level-9 role
role name level-10
description Predefined level-10 role
role name level-11
description Predefined level-11 role
role name level-12
description Predefined level-12 role
role name level-13
description Predefined level-13 role
role name level-14
description Predefined level-14 role
user-group system
local-user admin class manage
service-type ssh terminal http https
ip http enable
wlan global-configuration
wlan ap-group default-group
cloud-management server domain oasis.h3c.com
return
粉丝:6人 关注:0人
电脑先nslookup +域名看能不能解析
可以的话,改一下tcp mss,进入接口敲tcp mss 1200
fanety 知了小白
nslookup可以解析到域名,在拔号口上加了此条命令,网络明显正常了,高手给解释一下吧。
